March 06, 2026, 06:43:55 18:43
Author Topic: Why MikroC's simulator doesn't work?  (Read 11565 times)
jlian168
« on: April 01, 2010, 08:58:51 08:58 »
Dear all:
I'm write a simply program to test MikroC for PIC.
I only open timer 1 to use,Then i set a breakpoint in the interrupt,
But the interrupt never be break,I don't why?
Can anyone tell me why?
void interrupt(void) {
     if(TMR1IE_bit)
               if(TMR1IF_bit)
                         TMR1IF_bit=0;
                         TMR1H=(65536-time1_base)/256;
                         TMR1L=(65536-time1_base)%256;
                         if(!(--A))
                                          A=10;
void main() {
     initial();
     while(1)
             CLRWDT();
             r_cnt++;
void initial(void) {
     PORTA=0;
     PORTC=0;
     T1CON=5;
     CMCON0=7;
     OSCCON=0x67;
     OPTION_REG=0xcf;
     ANSEL=0;
     WPUA=0;
     TRISA=0x38;
     TRISC=0x30;
     //TMR1IE_bit=1;
     PIE1=0x01;
     FSR=0x20;
clr_ram:
     INDF=0;
     if(FSR<0x60)
                 FSR++;
                 goto clr_ram;
     A=10;
     PEIE_bit1;
     GIE_bit=1;
Thank ypu very much.
piccolo
-Given: 927
-Receive: 1050
« Reply #1 on: April 01, 2010, 11:43:00 11:43 »
Interrupt is not automatic in debug mode.
You must manually enter in interrupt function with the key F2.
Or with menu -> Run -> Jump to interrupt.
sam_des
-Given: 138
-Receive: 161
« Reply #2 on: April 01, 2010, 05:28:49 17:28 »
mikroC's debugger is just an "Instruction Set Simulator". That's why it can execute the individual instructions of PIC core but it has no understanding of PIC's peripherals like the Timer you are trying to simulate.
Better use MPLAB or ISIS or even better switch to some other sensible compiler such as cc5x/hi-tech/iar  Tongue
But AFAIK mikroC doesn't output cod/coff/elf or any other files that can be loaded into ISIS or MPLAB. If I remember correctly there was a tool that can convert mikroC files to coff. Search forum or net, you'll get it, but don't how much it works Undecided
Hope that helps,
regards,
sam_des
tAhm1D
-Given: 103
-Receive: 180
« Reply #3 on: April 01, 2010, 08:06:20 20:06 »
mikroC does output coff files. Just get the new one.
FlvAnm
-Given: 29
« Reply #4 on: April 02, 2010, 09:35:40 09:35 »
In mikroC PRO for PIC you can generate coff file to debug C, for example in MPLAB. To generate coff file : Tools -> Opitons -> Output Settings and check Generate COFF file.
Flvanm
