March 12, 2025, 07:53:26 19:53
Author Topic: SC480 power amp full  (Read 6046 times)
gevv
-Given: 156
-Receive: 534
« on: February 14, 2007, 08:07:58 20:07 »
Performance
Output Power 50 watts into 8ohm 70 watts into 4ohm
Music Power 77 watts into 8ohm ;105 watts into 4ohm
Frequency response -1dB at 14Hz and 70kHz (at 1W- see Fig.1)
Input sensitivity 0.875V for 50ohm into 8ohm
Harmonic distortion <.05% from 20Hz to 20kHz; typically <.003%
Signal-to-Noise Ratio -114dB unweighted (22Hz to 22kHz); -119dB A-weighted, both with respect to 50W into 8ohm
Damping factor >140dB at 100Hz & 1kHz, with respect to 8ohm and without PTC thermistor
Protection fuses plus "Polyswitch" PTC thermistor
Stability unconditional
Download
http://rapidshare.com/files/16471851/sc480.rar.html
yada
http://w11.easy-share.com/880754.html
Umarım gelmez ilham perilerimin sonu... ! Modifiye uzmanı web üzerinde 320volt.com ile yaktı mumu....
