You think I am funny guy huh?
December 21, 2024, 03:59:18 15:59
Author Topic: (RQ)Help about RF TX-RX modules  (Read 6828 times)
sam_des
-Given: 128
-Receive: 151
« on: January 14, 2010, 06:06:39 18:06 »
I am currently trying to do RF comm. between 2 micros. My local shop offered me a TX-RX module pair. I tried to find some more data about  these, but haven't got much.
The TX module is numbered R433M & has no visible IC & has pin config - GND, DATA, VCC, ANT.
The RX module has an IC- HIMARK RX3400-LF & has pin config -GND, DATA, DATA, +5V, +5V, GND,GND,ANT.
I figured out that both are 433MHz modules. But I need more information, especially datasheet and app. notes, so that I can start experimenting with modules. Any examples will be an added advantage.
regards,
sam_des
nighthunter
-Given: 11
« Reply #1 on: January 14, 2010, 07:13:22 19:13 »
here are the datasheets, i used google, it took 10 secs to find the specs,
& here is some discussion about experimenting using RX/TX modules http://www.8051projects.net/forum-t20068.html
« Last Edit: January 14, 2010, 07:16:38 19:16 by nighthunter » Logged
maduran
-Given: 511
« Reply #2 on: January 14, 2010, 07:48:40 19:48 »
I used a Polygon nRF905 OEM Carrier Module:
http://www.rfdesign.co.za/pages/5645456/Products/Wireless-Integrated-Circuits/Transceiver-ICs-433-to-915-MHz.asp
The nRF905 is a robust communications solution (ShockBurst) : http://www.nordicsemi.com
It is recommended to buy a module : http://www.gsmcommander.com/downloads/files/Cxxx%20manual1.1.pdf
cipiloi
-Given: 223
-Receive: 22
« Reply #3 on: January 14, 2010, 08:13:01 20:13 »
Hi, this is super! http://amber-wireless.de/files/amb8420_ds.pdf
Jeckson
-Given: 54
« Reply #4 on: January 15, 2010, 01:38:18 13:38 »
Hai
Great sonsivri
Also I'm looking TRX module.At frecuencies 50-60-70Mhz to get long distance and almost silent here.
jeckson
king
-Receive: 21
Jack of All But Master of One
« Reply #5 on: January 16, 2010, 10:37:12 10:37 »
Hi!
Why don't you use TRW24G modules to Transmit and Receive Data at the Distance of 180 Meters,
also the complete project has been uploaded on Sonsivri (Projects)
Jeckson
-Given: 54
« Reply #6 on: January 16, 2010, 02:00:10 14:00 »
Hai
King
Too short distance.
Something with 500mW but have distance 100Km ~ and the characteristic between HF and VHF to avoid F and E layer problem(depends on sun and day).
Jeckson
manish12
-Given: 44
-Receive: 39
« Reply #7 on: January 16, 2010, 03:53:52 15:53 »
i generally use 4 sw rf module for transmitting upto 500meters ,
it is great to transmit without error ,
logic is >>
4 sw has upto 16 combination
convert the hex number into decimal , use 1-A for 0-9 and use B-F for transmitting start and stop of byte .
it is also use in bi direction communication ,
tested ok... no doubt
if find helpful  press tanks button
>>  i always face an environment, which demand must design with available resources
Jeckson
-Given: 54
« Reply #8 on: January 21, 2010, 01:51:43 13:51 »
Manish12
500 meters to short...
manish12
-Given: 44
-Receive: 39
« Reply #9 on: January 21, 2010, 03:15:31 15:15 »
a cheap walkies tokes may solve your problem for 10-20km
if you need more than that , just buy a fm transmitter 4-5w
oldvan
-Receive: 107
If the van is a Rockin'...
« Reply #10 on: February 04, 2010, 09:32:38 21:32 »
Impressive range for cheap walkie-talkies, where can I buy such a pair?
Any of the cheap ones I've encountered claim 2 km range and are somewhat likely to work for about a city block on a good day.
