I did nothing except change the "16c84" to "16f84a" and it compiles fine.
TITLE "CTCSS Encoder v1.4 for 16F84A "
; Assemble with MPASM
LIST P=16F84A
__CONFIG 3FF9H ;XTAL OSC @4Mhz,NO WATCHDOG,PWRRST,NO CP.
__IDLOCS 1234
ERRORLEVEL -302
CNT1 EQU 0CH ;PRESCALLER COUNTER REG 1
CNT2 EQU 0DH ;PRESCALLER COUNTER REG 2
CNT3 EQU 0EH ;PRESCALLER COUNTER REG 3
TONREG EQU 0FH ;REGISTER FOR TONE NUMBER
PRES1 EQU 10H ;PRESCALLER STORE 1
PRES2 EQU 11H ;PRESCALLER STORE 2
PRES3 EQU 12H ;PRESCALLER STORE 3
PORTA EQU 5
PORTB EQU 6
TRISA EQU 85H
TRISB EQU 86H
OPTREG EQU 81H
PC EQU 2
PULLUP EQU 7
STATUS EQU 3
INTCON EQU 0BH
GIE EQU 7
RBIE EQU 3
RBIF EQU 0
RP0 EQU 5
OUT EQU 2
PTT EQU 7
GOTO START
ORG 00C8
START BSF STATUS,RP0 ;SELECT REG BANK 1
BSF TRISB,PTT ;SETUP RB7 AS INPUT FOR PTT
BCF TRISA,OUT ;SETUP RA2 AS OUTPUT FOR TONE
BCF OPTREG,PULLUP ;SET PULLUP RESISTORS ON PORTB
MOVLW 0xFF ; SET PORTB AS I/Ps
MOVWF TRISB ; RB0-RB5 FOR SWITCH INPUTS
BCF STATUS,RP0 ;SELECT REG BANK 0
BCF INTCON,GIE ;DISABLE GIE INTERUPTS
BSF INTCON,RBIE ;ENABLE PORT B CHANGE INTERUPT
MOVF TRISB,W ;READ DIP SWITCHES INTO W
MOVWF TONREG ;STORE IN 0F REG
BCF TONREG,6 ; CLEAR BITS 6&7 AS
BCF TONREG,7 ; THEY ARE IRRELAVANTS
MOVF TONREG,W ;RE-STORE INTO W
ADDWF TONREG,F ; MULTIPLY BY 3
ADDWF TONREG,F ; FOR TONE TABLE OFFSET
MOVF TONREG,W ;RELOAD TO W FOR OFFSET
CALL TONTBL ;GOTO TONE LOOKUP TABLE
MOVWF PRES1 ;STORE FIRST VALUE FROM TABLE
INCF TONREG,F ;INCREMENT FOR NEXT TABLE VALUE
MOVF TONREG,W ;RELOAD W FOR OFFSET
MOVWF PRES2 ;STORE SECOND VALUE FROM TABLE
MOVWF PRES3 ;STORE THIRD VALUE FROM TABLE
RELOAD
MOVF PRES1,W ;LOAD W WITH PRESET FOR 1
MOVWF CNT1 ;PRELOAD PRESCALLER 1
MOVF PRES2,W ;LOAD W WITH PRESET FOR 3
MOVWF CNT3 ;PRELOAD PRESCALLER 3
MOVF PRES3,W ;LOAD W WITH PRESET FOR 2 READY
PTTCHK
BTFSC PORTB,PTT ;TEST PTT LINE
GOTO WAIT ;SLEEP TILL LOW
CALL CHORUS ;DO DIVIDER/PRESCALLER ROUTINE
OUTPUT
BTFSS PORTA,OUT ;TEST O/P HI OR LO AT PRESENT
GOTO HI ;IF LO GO SET HI
GOTO LO ;IF HI GO SET LO
HI
NOP ;BALANCE OUT CYCLE TIME MARK&SPACE
BSF PORTA,OUT ;MAKE O/P HI
GOTO RELOAD ;RETURN TO START OF CYCLE
LO
BCF PORTA,OUT ;MAKE O/P LO
CHORUS
PRE1
DECFSZ CNT1,F ;DECREMENT PRESCALLER 1
GOTO PRE2
GOTO FINE ;CALL FINE ADJUST SUBROUTINE
PRE2 MOVWF CNT2 ;RELOAD PRESCALLER 2
PREE DECFSZ CNT2,F ;DECREMENT PRESCALLER 2
GOTO PREE ;GO BACK AND DECREMENT PRE2 TILL 00
GOTO PRE1 ;GO BACK AND DECREMENT PRE1 TILL 00
FINE DECFSZ CNT3,F ;DECREMENT PRESCALLER 3
GOTO FINE ;GO BACK AND DECREMENT PRE3 TILL 00
RETURN ;RETURN TO CHANGE O/P AND CHECK PTT ETC
WAIT
BCF INTCON,RBIF ;CLEAR PORT B CHANGE INT FLAG
SLEEP ;SLEEP AND WAIT FOR PTT
NOP
BCF INTCON,GIE ;DISABLE GLOBAL INTERUPTS AGAIN
GOTO PTTCHK ;CHECK IF PTT PASSES TEST
;TONES TABLE AT 0008H
ORG 0007H
TONTBL
ADDWF PC,F ; W+PC ->PC, JUMP DOWN TABLE
; 16c84 PIN
; 11 10 9 8 7 6
; TONE FREQ RB5 RB4 RB3 RB2 RB1 RB0
DT 02,01,0x9D ; 000 1Khz TEST 0 0 0 0 0 0
DT 86,82,10 ; 001 67.0 0 0 0 0 0 1
DT 81,85,10 ; 002 69.4 * 0 0 0 0 1 0
DT 84,80,0x0F ; 003 71.9 0 0 0 0 1 1
DT 7F,85,0x0F ; 004 74.4 0 0 0 1 0 0
DT 7B,7C,0x0F ; 005 77.0 0 0 0 1 0 1
DT 76,86,0x0F ; 006 79.7 0 0 0 1 1 0
DT 72,82,0x0F ; 007 82.5 0 0 0 1 1 1
DT 74,8F,0x0E ; 008 85.4 0 0 1 0 0 0
DT 63,91,10 ; 009 88.5 0 0 1 0 0 1
DT 5F,9A,10 ; 010 91.5 0 0 1 0 1 0
DT 5B,47,11 ; 011 94.8 0 0 1 0 1 1
DT 55,88,11 ; 012 97.4 0 0 1 1 0 0
DT 56,49,11 ; 013 100.0 0 0 1 1 0 1
DT 09,6E,0xB9 ; 014 103.5 0 0 1 1 1 0
DT 08,81,0xC9 ; 015 107.2 0 0 1 1 1 1
DT 0A,71,98 ; 016 110.9 0 1 0 0 0 0
DT 0B,76,83 ; 017 114.8 0 1 0 0 0 1
DT 0A,0xCA,83 ; 018 118.8 0 1 0 0 1 0
DT 0A,9A,83 ; 019 123.0 0 1 0 0 1 1
DT 09,0xF1,83 ; 020 127.3 0 1 0 1 0 0
DT 08,93,9D ; 021 131.8 0 1 0 1 0 1
DT 07,94,0xB0 ; 022 136.5 0 1 0 1 1 0
DT 07,7C,0xAD ; 023 141.3 0 1 0 1 1 1
DT 07,85,0xA5 ; 024 146.2 0 1 1 0 0 0
DT 08,7B,89 ; 025 151.4 0 1 1 0 0 1
DT 08,80,83 ; 026 156.7 0 1 1 0 1 0
DT 07,0xA2,90 ; 027 159.8 * 0 1 1 0 1 1
DT 08,47,86 ; 028 162.2 0 1 1 1 0 0
DT 07,60,95 ; 029 165.5 * 0 1 1 1 0 1
DT 08,86,78 ; 030 167.9 0 1 1 1 1 0
DT 07,92,87 ; 031 171.3 * 0 1 1 1 1 1
DT 07,90,85 ; 032 173.8 1 0 0 0 0 0
DT 07,7D,85 ; 033 177.3 * 1 0 0 0 0 1
DT 09,5A,66 ; 034 179.9 1 0 0 0 1 0
DT 09,48,66 ; 035 183.5 * 1 0 0 0 1 1
DT 07,9E,78 ; 036 186.2 1 0 0 1 0 0
DT 08,0xBB,60 ; 037 189.9 * 1 0 0 1 0 1
DT 09,4C,60 ; 038 192.8 1 0 0 1 1 0
DT 08,9D,60 ; 039 196.6 * 1 0 0 1 1 1
DT 09,2F,60 ; 040 199.5 * 1 0 1 0 0 0
DT 07,82,70 ; 041 203.5 1 0 1 0 0 1
DT 07,76,70 ; 042 206.5 * 1 0 1 0 1 0
DT 07,66,70 ; 043 210.7 1 0 1 0 1 1
DT 07,6F,6A ; 044 218.1 1 0 1 1 0 0
DT 06,0xA3,70 ; 045 225.7 1 0 1 1 0 1
DT 06,98,70 ; 046 229.1 * 1 0 1 1 1 0
DT 06,8A,70 ; 047 233.6 1 0 1 1 1 1
DT 06,72,70 ; 048 241.8 1 1 0 0 0 0
DT 04,0xC3,99 ; 049 250.3 1 1 0 0 0 1
DT 04,0xB9,99 ; 050 254.1 * 1 1 0 0 1 0
DT 05,1C,99 ; 051 255 * 1 1 0 0 1 1
DT 03,15,20 ; 052 1750 Eu Tone 1 1 0 1 0 0
DT 05,0F,10 ; 053 1800 Eu Tone 1 1 0 1 0 1
DT 01,84,9D ; 054 1200 Packet 1 1 0 1 1 0
DT 02,13,30 ; 055 2200 Packet 1 1 0 1 1 1
DT 03,26,50 ; 056 800 * 1 1 1 0 0 0
DT 03,0F,50 ; 057 900 * 1 1 1 0 0 1
DT 02,3F,50 ; 058 1100 * 1 1 1 0 1 0
DT 03,36,20 ; 059 1300 * 1 1 1 0 1 1
DT 01,68,20 ; 060 1500 * 1 1 1 1 0 0
DT 03,09,20 ; 061 2000 * 1 1 1 1 0 1
DT 02,1A,20 ; 062 2500 * 1 1 1 1 1 0
DT 02,07,20 ; 063 3500 * 1 1 1 1 1 1
; * Indicates non EIA standard tone
ORG 2100H
DE "CTCSSENC v 1.4 "
END
