November 23, 2024, 07:21:30 07:21
Author Topic: HİGH SPEED COUNTER  (Read 3818 times)
enen
« on: December 24, 2009, 05:51:00 17:51 »
Hi everybody,
I want to detect 60 dry contact in a second from pic 16f84 it seems possible.But hoe csn simulate in proteus. What should i use for dry contact
-Given: 834
-Receive: 4321
« Reply #1 on: December 25, 2009, 11:18:42 23:18 »
if by dry you mean relay/switch contacts, then you could make a part by pulse generater mode @ 60hz into driver and a relay, crude but will work.
oldvan
-Receive: 107
If the van is a Rockin'...
« Reply #2 on: December 26, 2009, 01:29:10 01:29 »
Need clarification here.
Are the pulses FROM the PIC, or headed TO the PIC?
Do we want to be sure they are 60 per second or Huh?
king
-Receive: 21
Jack of All But Master of One
« Reply #3 on: December 26, 2009, 08:21:24 08:21 »
you should have to connect the resistor from 'NO' contact to Ground in order to make the real clock of high and low pulses, by reading the schematic i have observed that CLK pin receives only high pulse not low pulse, the state is not chaning from high to low and then low to high.
