November 21, 2024, 09:49:29 09:49
Pages: 1 [2]  All
Author Topic: LABVIEW USB Interfacing with PIC 18F4550 using HID  (Read 88695 times)
CocaCola
-Given: 169
« Reply #25 on: May 25, 2014, 06:32:34 18:32 »
The topic fits. I'm interfacing a PIC 18F4550 to LabView. The PIC side is solved but for LabView I'm  locking for a solution.
Hmm, as suggested multiple times now, did you bother reading the post above your inital post, I suspect not since it has EVERYTHING you are asking for!!!
http://www.sonsivri.to/forum/index.php?topic=26537.msg133404#msg133404
CocaCola
-Given: 169
« Reply #26 on: May 25, 2014, 08:35:50 20:35 »
I'm again, post #22 uses NI Visa with the disadvantage that everything stops working when the port is changed.
Labview uses NI-Visa by default to communicate it's kind of a package deal, and since NI-Visa is pretty much the de-facto industry standard it's not a bad thing...
-Given: 405
-Receive: 545
« Reply #27 on: May 25, 2014, 08:49:28 20:49 »
I don't know if I should laugh or cry , but my mute finger is getting awful itchy  Shocked
biomed12
-Given: 67
« Reply #28 on: November 19, 2016, 11:22:26 23:22 »
I wonder, what is the better side of HID over CDC? It is very simple to communicate with labview via serial protocol. I have one project like that. It is about real time chart plotting. Its costumization is not perfect but the protocol works properly.
motox
-Given: 257
-Receive: 322
« Reply #29 on: November 20, 2016, 12:07:37 00:07 »
With HID it is much easier to do auto-detect and to auto-run a program or a subprogram when the device is connected.
Forcing the user to open the Device Danager to see the port number, insert that number in a box and click on the ‘open port’ button is not very professional. Imagine that for a ‘normal’ Windows user that doesn’t even know what Device Manager is…
« Reply #30 on: November 20, 2016, 06:25:26 06:25 »
For a "professional" option you can simply detect your serial port automagically.  It's not that hard.  See 3.6 below for an example with FTDI
http://www.ftdichip.com/Support/Documents/AppNotes/AN_123_How%20COM%20Ports_Are%20Allocated%20on%20Driver_Installation.pdf
motox
-Given: 257
-Receive: 322
« Reply #31 on: November 20, 2016, 10:29:28 10:29 »
How do you implement that in LabVIEW without using FTDI chips?
I don't have any doubts about its possibility, but I think it is much easier with HID, WinUSB or a custom driver.
Martin Miranda
-Given: 8
« Reply #32 on: February 15, 2020, 11:49:36 11:49 »
Moved  & stickyed
Have you looked at the Bitwacker
http://www.schmalzhaus.com/UBW/
THANKS! i think i still have some few 18f2550's around.
Posted on: February 15, 2020, 05:47:49 05:47 - Automerged
i concur.
Pages: 1 [2]  All
