November 26, 2024, 12:47:24 12:47
Author Topic: Full USB ICD2 clone  (Read 18957 times)
crazyduck
-Given: 129
-Receive: 131
« on: January 23, 2007, 09:06:14 21:06 »
There is everything to make an USB ICD2 with programming module.
You'll find schematic, firmware and PCB for the both realization
CD:D
pablov
-Given: 55
« Reply #1 on: January 23, 2007, 09:32:31 21:32 »
Thank's crazyduck
johan_tr2000
« Reply #2 on: January 29, 2007, 05:50:09 05:50 »
Thanks Roll Eyes
riteshjain_82
-Given: 31
-Receive: 33
« Reply #3 on: January 29, 2007, 06:28:10 06:28 »
but whare is the link ..
please post it again
thanks
crazyduck
-Given: 129
-Receive: 131
« Reply #4 on: January 29, 2007, 12:48:48 12:48 »
Here it is
CD:D
crazyduck
-Given: 129
-Receive: 131
« Reply #5 on: January 29, 2007, 12:52:16 12:52 »
sorry
http://rapidshare.com/files/13927936/ICD2.rar
ducky2002
« Reply #6 on: January 29, 2007, 05:34:27 17:34 »
Hi...
Better you look at
www.icd2clone.com
There you can download all designs which are available at the moment.
I prefer Potyo2 schematic and board because of dspic33 support...but you can read the whole developement story at http://www.edaboard.com/ftopic161641.html.
@Crazyduck: is this the board you posted at edaboard? i did not compare the schematics...only the timestamp of the pdf and the pdf at page 36 (http://www.edaboard.com/ftopic161641-0-asc-1050.html) is newer
Taner
-Given: 299
-Receive: 59
« Reply #7 on: February 14, 2007, 09:34:29 09:34 »
Thnaks friends
 Smiley
akutisarizar
« Reply #8 on: March 20, 2007, 09:24:08 21:24 »
please check also below address
http://www.electoday.com/
robban
-Given: 34
-Receive: 38
Warrior
« Reply #9 on: April 04, 2007, 08:05:17 20:05 »
Great...
Code Warrior
ramesh_rahu
« Reply #10 on: April 05, 2007, 01:34:04 01:34 »
here is the wiki for it with full implementations (same as edaboard one, but consolidated for people who do not wish to read how it works)
http://www.icd2clone.com/wiki/Main_Page
Raju
robban
-Given: 34
-Receive: 38
Warrior
« Reply #11 on: April 16, 2007, 04:34:45 16:34 »
Hi!
Has anybody built some of the examples? I found some inconsistincies between schematics and boards in Potyos ex. and don't know how to resolve it. F. ex. where is the USB-drossel found in the schematic but not in the board?
Code Warrior
ducky2002
« Reply #12 on: May 23, 2007, 11:20:34 23:20 »
I've build the newest version of potyos design...its not available at www.icd2clone.com.
You can look at http://potyo.uw.hu/forum/viewtopic.php?t=4 or download the following eagle board http://potyo.uw.hu/icd2/mpi2.zip.
The ZIP does not include the schematic only the board.
It works fine...no problems until now.
jose
-Given: 342
-Receive: 12
« Reply #13 on: May 24, 2007, 12:10:34 12:10 »
hello ducky , can you upload the files, for to make the PCB board, and finware of PIC?
ducky2002
« Reply #14 on: May 26, 2007, 01:23:40 13:23 »
Sorry for the late answer but here are the requested files...
http://rapidshare.com/files/33487592/ICD2_Newest_Potyo_Version_26.05.2007.zip
If you want to use the 24 mhz firmware you must change the crystal from 20 mhz to 24 mhz and perhaps the caps if the pic does not run...
Have fun
ducky2002
« Reply #15 on: May 26, 2007, 01:32:10 13:32 »
the firmware files with CP in the filename are CP protected (boot block code protection)...
i've used the cp files for my icd2....don't know if the firmware without the cp works properly
bk3e
« Reply #16 on: February 14, 2008, 02:57:02 02:57 »
The file not found. Please upload this file once agian. Many thanks
pama
-Receive: 28
« Reply #17 on: February 14, 2008, 05:43:25 05:43 »
but the last one is there:
http://potyo.extra.hu/icd2/potyo2-rev1.zip
