April 22, 2025, 05:45:08 05:45
Author Topic: REQ: IAR Systems PIC16 v2.21C  (Read 9927 times)
cjeffries1
-Given: 252
-Receive: 176
« on: December 03, 2009, 06:31:56 18:31 »
If ne1 can put up a link to the old IAR PIC16/17 version 2.21C I would appreciate it. I have got the old v2.21A but the 2.21C is 2 years newer so if ne1 has it with a patch pls. upload it somewhere. All the previous links to this version are no longer working.
TIA
mris99
-Given: 8
-Receive: 16
« Reply #1 on: December 03, 2009, 09:03:34 21:03 »
Here is the update to 2.21C:
http://depositfiles.com/files/vw3usapwa
« Last Edit: December 12, 2009, 10:23:14 10:23 by mris99 » Logged
cjeffries1
-Given: 252
-Receive: 176
« Reply #2 on: December 03, 2009, 10:39:46 22:39 »
That is really appreciated. Exactly what I needed.
I have clicked the thank you button. I wish I could click it 100 times.
cjeffries1
-Given: 252
-Receive: 176
« Reply #3 on: December 03, 2009, 11:59:56 23:59 »
Hmm!
I have a small problem. I also downloaded Hex patch for
IAR Embedded Workbench for PICmicro V2.21C
made by zuisti (2004.12.30) from one of the other threads. There are 4 files that need patching
iccpic.dll
iccpic.exe
spic16.cdr
spic17.cdr
When I opened the hex editor to look for the locations, the data in the locations for the first 2 files does not match the info in Zuisti. readme file. The cdr files are ok and do match but it appears Zuisti developed his patch for the dll and exe files that are dated one month later than the ones provided in the 2.21C update. So I can't patch the two main v2.21c files as I have no way of locating the correct entry points to change the hex values.
Does anyone have these files v2.21C already patched or alternatively can someone provide a patch or crack for the update files just posted? Otherwise I'm sort of screwed. Cry
mris99
-Given: 8
-Receive: 16
« Reply #4 on: December 04, 2009, 07:31:50 19:31 »
Sorry, but I have never tried it.
For the 2.21A I have patched exe, but not for C.
« Last Edit: December 05, 2009, 10:27:18 10:27 by mris99 » Logged
Top
-Given: 52
-Receive: 1719
« Reply #5 on: December 05, 2009, 12:29:49 00:29 »
If you install a license then you can update to 2.21C without worrying about modifying files.
I refer you to this post: http://www.ourdev.cn/bbs/bbs_content.jsp?bbs_sn=3401303&bbs_page_no=1&bbs_id=1028, look at 7th message.
h0nk
-Given: 248
-Receive: 233
« Reply #6 on: May 14, 2015, 03:51:08 15:51 »
has someone the update to 2.21C available and would reupload it?
I am working on an old project and 2.21A doesnt like it.
Best Regards
zuisti
-Given: 242
-Receive: 780
« Reply #7 on: May 15, 2015, 09:00:57 09:00 »
Hi;
Found in my archive but it's the full v2.21c, not the update.
Please choose what do you want to get:
(1) the original four critical files:
     iccpic.dll
     iccpic.exe
     spic16.cdr
     spic17.cdr
(2) these files but modified (patched) by me as I wrote here in the attached txt:
     http://www.sonsivri.to/forum/index.php?topic=11465.msg52908#msg52908
(3) the complete, ready to run (patched and installed) compiler with the EWB23 files (the IDE).
I will upload the (compressed) files on the 4shared.com after you answered.
  or ... see top's post (and the linked chinese site):
http://www.sonsivri.to/forum/index.php?topic=26262.msg88804#msg88804
Note, it's a 'bit' old and supports only few legacy PIC16/17 devices. But ... this is an IAR compiler ...  Cool
zuisti
h0nk
-Given: 248
-Receive: 233
« Reply #8 on: May 15, 2015, 09:49:12 09:49 »
Hello zuisti,
Hi;
     iccpic.dll
     iccpic.exe
     spic16.cdr
     spic17.cdr
zuisti
My installation of 2.21A had a valid license. So i can run the unmodified versions.
Thanks a lot for Your help.
4shared will be fine.
Best Regards
zuisti
-Given: 242
-Receive: 780
« Reply #9 on: May 15, 2015, 12:11:25 12:11 »
Hi h0nk;
See attached file ...
