April 22, 2025, 09:51:43 21:51
Author Topic: Convergence problem in simulation with Cadance  (Read 3753 times)
arash_tah
« on: November 21, 2009, 11:36:09 11:36 »
Hi every body
I have canvergence problem in my simulation with Cadance
Yesterday when I ran simulation I saw The message of convergence problem unfortunetly I couldn't solve this problem
Does any one here know how to solve this problem?
I can share my circuit if u want
dennis78
-Given: 276
-Receive: 155
« Reply #1 on: November 21, 2009, 12:25:28 12:25 »
Reason for convergence problem can be type of circuits topology (H bridges, systems with several grounds, etc.) or simulation algorithm. If you want acceptable results, sometime you must have enough experience how to define circuit in form which is good for simulator. Cadence 16.x has improve simulation algorithm (about convergence problems) and in some cases it give good results. You must enable this option in simulation profile. If you want more help, attach your circuit.
masa
« Reply #2 on: December 06, 2009, 01:45:43 01:45 »
Messing around with some of the settings usually helps.
