yasir9909
-Receive: 107
« on: November 17, 2009, 09:17:26 09:17 » |
I have stored GPS data (without parsing) in a text file through hyper terminal in Laptop. I need to process that data in Proteus Simulation.
I want that data to be read by PIC18F4520 from 'File' model of Proteus and then perform the necessary Parsing for extracting desired information from data strings stored in text file and read from 'File' model in Proteus.
Could somebody please help me in this regard,how to use 'FILE' model in Proteus.
I do not have any idea how to use this 'FILE' model in Proteus for above mentioned purpose
regards m.yasir
yasir9909
-Receive: 107
« Reply #1 on: November 19, 2009, 05:01:20 05:01 » |
No body know? how to read data from a text file in Proteus using 'FILE' model in Proteus? I urgently need help on this issue...
regards m.yasir
-Receive: 4460
« Reply #2 on: November 20, 2009, 11:37:01 23:37 » |
I don't see how you can read a text file with the 18f2445, but you could put your data in say an eprom. and then read that.
johnri
-Given: 32
-Receive: 12
« Reply #3 on: November 21, 2009, 06:24:54 06:24 » |
I don't know anything about the FILE model in Proteus, but I have an idea that might work. I believe Proteus has a serial port model that can be used to send data to any micro. You can use a terminal program to send your text file to the serial port in Proteus. Here is a terminal program that you can use for free: http://hw-server.com/software/termv19b.htmlSee the attached pic.
frasenci
Translator
-Given: 142
-Receive: 85
« Reply #4 on: November 21, 2009, 10:26:44 10:26 » |
As far as I know , the " File Generator " is one way of getting info into simulation , through a Text file. It is an option for the different signal generators there are.
Attached picture of VSM manual.
Hope it helps you
Greetings
yasir9909
-Receive: 107
« Reply #5 on: November 21, 2009, 11:23:19 11:23 » |
I have got one solution to this issue.I have used Eltima Virtual Serial Port Driver and COMPIM model in Proteus to send text file (upon which GPS data has been saved) through Hyper Terminal to the COMPIM model in Proteus simulation I have attached snap shots of these entities
regards m.yasir
yasir9909
-Receive: 107
« Reply #6 on: November 21, 2009, 12:30:25 12:30 » |
One issue with this approach is that i cannot simulate the complete behavior of GPS engine as GPS engine normally update data after one second delay. However,baud rate may be set at will.
I have used this type of file (generator) model in multisim.where the source generator reading data from the text file needs two columns of data one for time steps and the other for data points corresponding to that time steps.However, GPS data is different from simple two colum data...
« Last Edit: November 21, 2009, 12:33:16 12:33 by yasir9909 »
regards m.yasir
yasir9909
-Receive: 107
« Reply #7 on: November 21, 2009, 02:55:46 14:55 » |
johnri
I have tried to use the 'terminal program' program that you have mentioned about but could not figure it out how to use it... how to use this terminal program?
I would try it again...
regards m.yasir
yasir9909
-Receive: 107
« Reply #8 on: November 23, 2009, 09:43:09 09:43 » |
johnri
I have tried this terminal software again,it also requires virtual serial port driver the way i have used,the only difference being that this terminal software may be used in place of hyper terminal that i have used in above mentioned technique
regards m.yasir
johnri
-Given: 32
-Receive: 12
« Reply #9 on: November 25, 2009, 11:46:17 23:46 » |
@yasir9909
Yes, there is no difference in using the HyperTerminal or the other Terminal program, I had posted it when I read that you wanted to get a text file into a micro.
I can't think of any way to simulate the periodic outputing of the GPS lines of text.
Maybe you could write a VB program to continuously send a line of GPS text (reading from a file) after a periodic delay and when that is sent into the Proteus COMPIM serial port it should model the behavior of a GPS device.
It would be much easier to just get a real GPS device to interface with the Proteus model.
yasir9909
-Receive: 107
« Reply #10 on: November 26, 2009, 07:48:50 07:48 » |
johnri
Well,i am also thinking about physically connecting GSP engine with RS-232 interface to PC and get data directly from GPS engine in Proteus through ComPIM module
I don't know programming in VB.I know only C and C++,can it be done with C and C++ as well...? I think it can done with C and C++ as well...
regards m.yasir
frasenci
Translator
-Given: 142
-Receive: 85
« Reply #11 on: November 26, 2009, 12:10:03 12:10 » |
Ones I was developing an instrument based on Pocket Pc that received serial data over bluetooth from an 877A Pic based PCB meant to be far away on the machine it was sensing.
1.- For developing the PIC side of the software I simply put TWO PIC processors in the same DSN on Proteus , the second one only run a loop sending the simulated serial data to the MAIN PIC. Connected directly from Tx/Rx pins of each other. Each PIC on proteus can have his own program running. That was great help.
2.- On the Pocket Pc side I used MS Visual Studio , can be VBasic or VC ,C+,... etc. Recommend use Visual Studio 2003 as on recent Framework has complicated things a bit. Can also use same development for generating an Pc side application.
3.- Also developed a Pc side with Labview using VISA Serial interface. This one included as early as Labviev 6.
Just wanted to share my experience and highliting the solution to use 2 PIC in same Proteus simulation, the second one simulating the GPS Satellite sending "ssd ,221, 123, etc,..." data on a timed manner.
Greetings Francisco
yasir9909
-Receive: 107
« Reply #12 on: December 07, 2009, 07:00:52 19:00 » |
I have got the solution.I have got a friend of mine to develop application for me in VB,which reads GPS data from text file and sends it to the COMPIM port at a baud rate of 4800 and with delay of 1sec between GPS data strings and serves like a virtual GPS.This VB application is used in place of Hyper Terminal in previously mentioned solution
The image of the GUI for this VB application is attached with this post.
I would post the code for this VB application later so that it may be helpful to others as well
regards m.yasir
regards m.yasir
yasir9909
-Receive: 107
« Reply #13 on: December 08, 2009, 10:06:45 10:06 » |
Here is the VB code for the above application for GPS data: Dim PortNo As Integer Dim BaudRate As Long Dim FilePath As String Dim completeFileData As String Dim allGPSLines() As String Dim curLineCounter As Long Dim totalGPSStrings As Long
Private Sub Baud_Click(Index As Integer) Select Case Index Case 0 BaudRate = 4800 Case 1 BaudRate = 9600 Case 2 BaudRate = 19200 Case 3 BaudRate = 57600 Case 4 BaudRate = 115200 Case Else BaudRate = 4800 End Select
End Sub
Private Sub btnSelectFile_Click() On Error GoTo ErrorHandler: Dim readGPSFile As New TextFiles CommonDialog1.CancelError = True CommonDialog1.Filter = "Text Files(*.txt)|*.txt|" CommonDialog1.ShowOpen If CommonDialog1.FileName <> "" Then FilePath = CommonDialog1.FileName btnStart.Enabled = True lblPath.Caption = FilePath readGPSFile.TextFilePath = FilePath completeFileData = readGPSFile.completeFile allGPSLines = Split(completeFileData, "$GPGGA") totalGPSStrings = UBound(allGPSLines) curLineCounter = 0 lblStatus.Caption = "Total GPS strings: " & totalGPSStrings Exit Sub End If ErrorHandler: MsgBox Err.Description btnStart.Enabled = False Exit Sub End Sub
Private Sub btnStart_Click()
On Error GoTo ErrorHandler: If btnStart.Caption = "Start Sending Data" Then MSComm1.CommPort = PortNo MSComm1.Settings = BaudRate & ", n, 8, 1" MSComm1.PortOpen = True curLineCounter = 0 Timer1.Enabled = True btnStart.Caption = "Stop Sending Data" Else btnStart.Caption = "Start Sending Data" Timer1.Enabled = False MSComm1.PortOpen = False End If
Exit Sub ErrorHandler: MsgBox "Error opening Com port... Either it is not a valid port or is already openend by another application.", vbCritical, "Port Open Error" MsgBox Err.Description End Sub
Private Sub ComPort_Click(Index As Integer) PortNo = Index + 1 End Sub
Private Sub Form_Load() PortNo = 1 BaudRate = 4800 End Sub
Private Sub Timer1_Timer() MSComm1.Output = "$GPGGA" & allGPSLines(curLineCounter) curLineCounter = curLineCounter + 1 lblStatus.Caption = "Sending: " & curLineCounter & "/" & totalGPSStrings End Sub
regards m.yasir
