February 28, 2025, 02:00:33 02:00
Author Topic: Progressive Resources LLC FlashFile  (Read 18750 times)
diaz
-Given: 41
« on: November 11, 2005, 03:16:19 15:16 »
Has anyone got a copy of the Flashfile source code by Progressive Resources LLC for PIC18 parts that they would like to share with me :rolleyes:
Details at:
http://www.prllc.com/productcart/pc/viewPrd.asp?idcategory=17&idproduct=51
diaz
-Given: 41
« Reply #1 on: November 12, 2005, 10:51:11 10:51 »
Seek and yee shall find. (more than you needed in my case)
http://forum.electronix.ru/index.php?showtopic=6918
http://forum.electronix.ru/lofiversion/index.php/t1037-50.html
Ignite
« Reply #2 on: November 14, 2005, 08:43:06 20:43 »
Hi!! I've downloaded the files but the password doesn't work. Have you test it?
Ankarius
« Reply #3 on: November 15, 2005, 03:48:27 15:48 »
You need the program 'Advanced Archive Password Recovery'. Use the option 'Plain-text' and
fill the encryption keys ...
Regards, Ank.
cddx
« Reply #4 on: November 16, 2005, 01:18:34 13:18 »
I can't setup 'Advanced Archive Password Recovery'. and anyone can tell me how to use it, thanks.
diaz
-Given: 41
« Reply #5 on: November 21, 2005, 07:13:48 19:13 »
I did indeed check the de-cryption keys minutes before my second post. I have just checked them again with freshly downloaded files and they still work.
 I think the confusion is the [ 2af65e9f xxxxxxxx xxxxxxxx ] type strings are decryption keys for use with PKCrack and NOT passwords.
 Download and extract this file (it's freeware):
 http://www.unix-ag.uni-kl.de/~conrad/krypto/pkcrack/pkcrack-1.2.2-win32.zip
 Put the Progressive Resources LLC file of your choice in the same directory.
(Use the links in my second post to find the links to the Progressive Resources LLC files, I have not posted the links here to stop PRLLC geting web log referer entries pointing to sonsivri)
 Open a command prompt and goto the same directory you just put the PRLLC file in. If you type dir it should look something like:
 21/11/2005  18:51			  .
 21/11/2005  18:51  ..
 12/11/2005  01:02  doc
 05/01/2003  16:22   107,580 extract.exe
 04/01/2003  16:55 97,503 findkey.exe
 21/11/2005  18:32 2,048,733 FlashFileSD-PIC.zip
 04/01/2003  16:55 82,021 makekey.exe
12/11/2005 01:04 83 PkCrack - Breaking PkZip-encryption.URL
 05/01/2003  16:22   144,329 pkcrack.exe
 12/11/2005  01:03 18,126 Zip Cracking - by Crashtest.pdf
 11/11/2005  17:14    80 Zip Cracking - by Crashtest.URL
 05/01/2003  16:22   113,606 zipdecrypt.exe
 Now at the command prompt type:
 zipdecrypt [ 2af65e9f xxxxxxxx xxxxxxxx ] Flash-FileSD-PIC.zip decrypted.zip
 and hit return, hey presto a decrypted zip file.
 You will have to substitue the xxxxxxxx's for the full numbers as on the pages I linked to in my second post.
Obviously if you are going to use a different file to Flash-FileSD-PIC.zip then you will have to change the file name in the "zipdecrypt" command and the decryption keys. The other decryption keys can be found by following the links in my second post.
 That's it.
« Last Edit: November 21, 2005, 07:19:53 19:19 by diaz » Logged
cddx
« Reply #6 on: November 22, 2005, 02:52:36 14:52 »
thank you! diaz.
diaz
-Given: 41
« Reply #7 on: November 24, 2005, 12:14:06 00:14 »
No problem, my pleasure.
tavioman
« Reply #8 on: February 27, 2006, 04:22:46 16:22 »
How can I simply read a a file from MMC and simply transmitted over USART??
Using FlashFileSd-PIC
ThankYou
- Brain juice -
