January 11, 2025, 11:57:59 11:57
Author Topic: DCF77 on PIC  (Read 7105 times)
0 Members and 4 Guests are viewing this topic.
pki
« on: November 01, 2009, 12:06:12 12:06 »
Hi there.
Looking for some source PICBASIC or Hi_TECH C with decoding of the DCF77 time signal. Doing a nixie clock, but will like it with DCF77  Grin
Thx.
have a nice weekend
ipek
-Given: 60
-Receive: 79
« Reply #1 on: November 01, 2009, 01:55:43 13:55 »
my little archive
Re Again and spare
http://rapidshare.com/files/301069961/Atomic.rar.html
http://rapidshare.com/files/301071867/DCF_Atomic.rar.html
« Last Edit: November 01, 2009, 08:40:25 20:40 by ipek » Logged
cicos
-Given: 132
« Reply #2 on: November 07, 2009, 04:08:46 16:08 »
This file is neither allocated to a Premium Account, or a Collector's Account, and can therefore only be downloaded 10 times.
Shocked(
Poz
JaMi
tromop
 Warned
« Reply #3 on: December 20, 2009, 12:16:24 12:16 »
Here the sourcefile from a guy from the Netherlands who did a project with a Conrad DCF-77 receiver and Picbasic. Look at his fabulous site www.picbasic.nl
I personally prefer to use C but for the first steps i did use this for the trial-and-error period and it worked right away.
The source can be found at http://www.picbasic.nl/downloads/DCF16UKD_V-2.bas:
;V-2
;Compile with Crownhill Proton+ PIC Basic compiler.
;Receives DCF77 data from a standard DCF module and shows date/time on a LCD.
;It is important that the DCF77 reception is optimal.
;For DCF77 info, schematic diagram and control: www.picbasic.nl
;           PIC16F628A:                 +--v--+
;                    Pulse for gong E1 <[     ]> One pulse per second
;                    Pulse for gong E2 <[     ]> Daylight saving, high when it's summer
;                    Volume level gong <[     ]< Connect LDR to +5V, 1M potmeter to GND
;                                       [     ]< 12:00 (AM/PM) or 24:00 notation
;                                  GND  [     ]  +5V
;                  DCF77 module signal >[     ]> DB7 LCD
;        Normaly open, for test to GND >[     ]> DB6 LCD
;                               LCD EN <[     ]> DB5 LCD
;                               LCD RS <[     ]> DB4 LCD
;Er is ook een Nederlandse versie / There is a Dutch version too
;www.picbasic.nl / Frits Kieftenbelt, Raalte, Netherlands (Frizie)
DEVICE = 16F628A
CONFIG INTRC_OSC_NOCLKOUT, WDT_OFF, PWRTE_ON, LVP_OFF, MCLRE_OFF ;On-chip RC-oscillator
ALL_DIGITAL TRUE
;Normal aliases (constants)
SYMBOL CharType    = 255      ;Maximal   255: 255 is the ASCII code for a block in the LCD time bar
SYMBOL LCD_Char    = 16       ;Minimal    16: Number of characters of each line (dependence on LCD device)
SYMBOL MaxFindTime = 65       ;Minimal    65: (Sec)  Time to find the startsequence (second 00)
SYMBOL PulseLength = 740      ;Minimal 500! Maximal 750: (mSec)
SYMBOL PulseLengthX= PulseLength / 10
SYMBOL StartUpTime = 45000    ;Maximal 65535: (mSec) 45 seconds startup time for the DCF77 receiver after power-on
;Logical aliases (constants)
SYMBOL AAN         = 0        ;Reversed ON
SYMBOL FALSE       = 0
SYMBOL OFF         = 0
SYMBOL ON          = 1
SYMBOL TRUE        = 1
SYMBOL UIT         = 1        ;Reversed OFF
;Port aliases
SYMBOL DaylightSav = PORTA.0  ;High when it's summer
SYMBOL SecondPulse = PORTA.1  ;Pulses every second a half second
SYMBOL Gong1       = PORTA.2  ;Pulses high every whole hour, to steer the gong
SYMBOL Gong2       = PORTA.3  ;Pulses high every whole and half hour, to steer the gong
SYMBOL Volume      = PORTA.4  ;Changing between output (GND) and input (3-state) for regulate the volume level from the gong
SYMBOL AM_PM       = PORTA.6  ;Connect for 24 hours mode to +5V, for 12 hours AM/PM notation to GND
SYMBOL LDR         = PORTA.7  ;When it's dark (LDR sensor), sounds the gong softly
SYMBOL DCF_Signal  = PORTB.0  ;Input for the DCF77 module (receiver) signal (i.e. Conrad BN641138)
SYMBOL Test        = PORTB.1  ;Input leave normaly open, for adjusting LDR, make low BEFORE startup the PIC, for adjusting gong, make low AFTER startup the PIC
;        76543210
TRISA = %11100000
TRISB = %11111111
PORTB_PULLUPS ON              ;Pull-up for DCF77 receiver and Test button
;WORD
DIM SignalCheck    AS WORD
DIM Teller         AS WORD    ;Teller = Counter
;BYTE
DIM BitNumber      AS BYTE
DIM CursorPos      AS BYTE    ;Cursor x-position on LCD
DIM Day            AS BYTE
DIM GeneralCounter AS BYTE
DIM Hour           AS BYTE
DIM HourDCF        AS BYTE
DIM HourLCD        AS BYTE
DIM Minute         AS BYTE
DIM MinuteDCF      AS BYTE
DIM Month          AS BYTE
DIM ReceiveByte    AS BYTE
DIM Second         AS BYTE
DIM WeekDay        AS BYTE
DIM Year           AS BYTE
DIM BD1            AS BYTE    ;Byte Dummy 1
;BIT
DIM Initialize     AS BIT     ;TRUE when initializing
DIM ParityBit      AS BIT
DIM ParityError    AS BIT
DIM ReceiveBit     AS BIT
DIM Signal         AS BIT     ;TRUE when signal is found
DIM ID1            AS BIT     ;Bit Dummy 1
PORTA = 0
PORTB = 0
CLEAR
DELAYMS 200                   ;LCD stabilize
CLS
PRINT "www.picbasic.nl"
DELAYMS 3000
CLS
PRINT "DCF16UKD  V-2"         ;Version number
DELAYMS 2000
CLS
PRINT "Adjust LDR"
WHILE Test = AAN              ;If Test = LOW when startup the PIC, the LDR can adjust with the indication from the Daylightsave LED
  IF LDR = ON THEN
    DaylightSav = TRUE
  ELSE
    DaylightSav = FALSE
  ENDIF
WEND
CLS
PRINT "Search signal"
Initialize = TRUE
LOW  Volume                   ;When startup the PIC, the gong volume is loud
GOTO MainLoop                 ;Jump over the subroutines
;SUBROUTINES
ReceiveBitNumber:             ;Fill the receivebyte with the requested amount of bits in BCD mode
 CLEAR ReceiveByte
 FOR BD1 = 0 TO BitNumber - 1
   GOSUB ReceiveOneBit
   IF ReceiveBit = 1 THEN SETBIT ReceiveByte, BD1
 NEXT
 ReceiveByte = ((ReceiveByte >> 4) * 10) + (ReceiveByte & 15) ;BCD (Binary-Coded Decimal) to byte conversion
RETURN
ReceiveOneBit:                ;Receive a bit and store it in ReceiveBit
 CLEAR Teller
 WHILE DCF_Signal = AAN
   DELAYMS 1
   INC Teller
   IF Teller > 3000 THEN ReceiveError
 WEND
 DELAYMS 155                  ;135 - 175msec
 ReceiveBit = DCF_Signal
 IF Initialize = TRUE THEN
   CursorPos = (Second * LCD_Char) / 58 ;Calculate where the cursor position must be (dependence on waittime and LCD device)
   PRINT AT 2, CursorPos, CharType      ;Make time bar actual
 ELSE
   PRINT AT 1, CursorPos, DEC2 Second   ;Print the seconds on LCD
   ParityBit = ParityBit + ReceiveBit   ;Bit, thus 0+0=0 / 0+1=1 / 1+1=0 / 1+0=1 On the end you can see if it is even or uneven
 ENDIF
 INC Second                   ;Because we are in this routine every second, we can use it to count seconds
 SecondPulse = ON             ;Outputsignal second pulse
 DELAYMS 500
 SecondPulse = OFF
 DELAYMS PulseLength - 500
RETURN
;MAINPROGRAM
MainLoop:
 CLEAR GeneralCounter
 Second = 00                  ;Start with first second
 Signal = FALSE
 WHILE Signal = FALSE         ;Wait while DCF_Signal is high
   CLEAR Teller
   WHILE DCF_Signal = UIT
     INC Teller
     DELAYMS 1
     IF Teller > StartUpTime THEN ReceiveError ;Startup time for the DCF77 receiver by power-on
   WEND
   CLEAR Teller
   WHILE DCF_Signal = AAN     ;Start counting time between pulses
     INC Teller
     DELAYMS 10
     IF Initialize = FALSE THEN
       SELECT CASE Teller
         CASE 85 - PulseLengthX       ;85 = (1000mSec - 155mSec) / 10
           PRINT AT 1, CursorPos, "59";xx:xx:59, Print the missing second on LCD
         CASE 25
           SecondPulse = ON
         CASE 75
           SecondPulse = OFF
         CASE 250
           GOTO ReceiveError  ;Signal doesn't change within time
       ENDSELECT
     ELSE
       IF Teller > (StartUpTime / 10) THEN ReceiveError ;Startup time for the DCF77 receiver by power-on
     ENDIF
   WEND
   IF GeneralCounter >= MaxFindTime THEN ReceiveError ;If more then 'MaxFindTime' seconds counted then we have a problem
   INC GeneralCounter
   IF Teller > 100 THEN Signal = TRUE ;We count per 10mSec, so we need at least 100x10mSec for finding the startsequence
     CursorPos = (GeneralCounter * LCD_Char) / MaxFindTime ;Calculate where the cursor position must be (dependence from first waittime and LCD type)
     PRINT AT 1, 1, "Found signal "
     PRINT AT 2, CursorPos , CharType ;Put block characters on LCD while waiting for initialize signal
   ENDIF
 WEND
   CLS
   PRINT "Initialize..."
   PRINT AT 2, 1, REP "_" \ LCD_Char ;Draw the waiting time bar length
 ELSE
   CursorPos = LCD_Char - 9   ;X-position from time on LCD
   CURSOR 1, CursorPos
   IF ParityError = TRUE THEN ;Tijd not 100%, the PIC self calculates the time now for actualising
     IF Minute < 59 THEN
       INC Minute
     ELSE
       Minute = 00            ;\
       IF Hour < 23 THEN      ;-Time is synchronized, in spite of parityerror
         INC Hour             ;/
       ELSE
         Hour = 00            ;Actualising the date have no sense, when an error occured then it isn't gonna changed
       ENDIF
     ENDIF
   ELSE                       ;No error, put the normal DCF time on LCD
     Minute = MinuteDCF
     Hour   = HourDCF
   ENDIF
   IF AM_PM = AAN THEN        ;If AM/PM notation is selected then...
     SELECT CASE Hour
       CASE 0   :HourLCD = 12        ;If it's 00:xx then put on LCD: 12:xx
       CASE > 12:HourLCD = Hour - 12 ;If it's between 13:xx and 23:xx then put on LCD: 1:xx / 11:xx
     END SELECT
   ELSE                       ;...else, it's 24 hour notation...
     HourLCD = Hour           ;The hour which comes on LCD is equal to the DCF hour
     PRINT "  "               ;Erase AM/PM when switching from 12 hours notation to 24 hours notation
   ENDIF
   IF HourLCD < 10 THEN PRINT " " ;Clear leading zero (08:00:00 --> 8:00:00) (Null suppression)
   PRINT DEC HourLCD, ":", DEC2 Minute, ":00" ;Put actual time on LCD every minute
     IF Hour < 12 THEN        ;...if it's AM then...
       PRINT "am"             ;...put AM on LCD next to the time...
     ELSE                     ;...anders (afternoon)...
       PRINT "pm"             ;...put PM on LCD next to the time
     ENDIF
     CursorPos = LCD_Char - 3 ;Put cursor position already for the seconds, 2 more to the left for AM/PM
   ELSE
     CursorPos = LCD_Char - 1 ;Put cursor position already for the seconds
   ENDIF
   IF Minute = 00 OR Minute = 30 OR Test = AAN THEN GongSignal ;Every whole and half hour a gong signal (and every minute if Test is enabled)
 ENDIF
 IF Signal = TRUE THEN        ;Startbit succesfull received, start filling data
   GOSUB ReceiveOneBit        ;0: Bit 0 (reserved (DCF77 protocol))
Further:                      ;When the gong sounds, bit 0 is ignored, after a gong, it goes further here
   FOR BD1 = 1 TO 14          ;1...14: first 15 bits are reserved (info see www.picbasic.nl --> DCF77 info)
     GOSUB ReceiveOneBit
   NEXT
   CLEAR ParityBit            ;If ParityError is set, then ParityBit is also mutated, thus reset
   CLEAR ParityError          ;Reset PariteitsError (Leave these 2 resets on this place, because when a parityerror happens during initializing)
   GOSUB ReceiveOneBit        ;15: Which send antenna is used?
;  IF ReceiveBit = 0 THEN...  ;Signal is sended by the standard antenna, this bit is not used in this program
;  IF ReceiveBit = 1 THEN...  ;Signal is sended by a reserve antenna, this bit is not used in this program
   GOSUB ReceiveOneBit        ;16: Switch summer/winter next hour?
;  IF ReceiveBit = 1 THEN...  ;This bit is not used in this program
   GOSUB ReceiveOneBit        ;17: Daylight Savings Time?
     DaylightSav = ON         ;Summer
   ELSE
     DaylightSav = OFF        ;Winter
   ENDIF
   FOR BD1 = 18 TO 19         ;18...19: Skip bits (Time Zone bit 2 and leap-second bit)
     GOSUB ReceiveOneBit
   NEXT
   GOSUB ReceiveOneBit        ;20: Startbit, must always be a 1, not used in this program
;  IF ReceiveBit = 0 THEN...  ;This bit is not used in this program
   BitNumber = 7              ;21...27: Receive Minute (7 bits)
   GOSUB ReceiveBitNumber
   MinuteDCF = ReceiveByte
   GOSUB ReceiveOneBit        ;28: Parity bit 1, minutes
   IF ParityBit = ON THEN ParityError = TRUE
   BitNumber = 6              ;29...34: Receive Hour (6 bits)
   HourDCF   = ReceiveByte
   GOSUB ReceiveOneBit        ;35: Parity bit 2, hours
   BitNumber = 6              ;36...41: Receive Day (6 bits)
   Day       = ReceiveByte
   BitNumber = 3              ;42...44: Receive WeekDay (3 bits)
   WeekDay   = ReceiveByte
   BitNumber = 5              ;45...49: Receive Month (5 bits)
   Month     = ReceiveByte
   BitNumber = 8              ;50...57: Receive Year (8 bits)
   Year      = ReceiveByte
   GOSUB ReceiveOneBit        ;58: Parity bit 3, date
     IF ParityError = FALSE THEN ;If there is NO parityerror, then we are...
       Initialize  = FALSE       ;...ready with initializing (If there IS a parityerror while initializing, then initialize again)
     ENDIF
     CLS
   ENDIF
   IF ParityError = FALSE THEN;Only actualise the date when there is no parity error
'    PRINT AT 1, 1, REP " " \ 9        ;Erase the day on LCD (Only necessary with full name of the day)
     PRINT AT 2, 1, REP " " \ LCD_Char ;Erase the whole 2nd line
     CURSOR 1, 1
     SELECT CASE WeekDay
       CASE 1: PRINT "Mon"
       CASE 2: PRINT "Tue"
       CASE 3: PRINT "Wed"
       CASE 4: PRINT "Thu"
       CASE 5: PRINT "Fry"
       CASE 6: PRINT "Sat"
       CASE 7: PRINT "Sun"
     ENDSELECT
     PRINT AT 2, 1, DEC Day, " "
     SELECT CASE Month
       CASE  1: PRINT "January"
       CASE  2: PRINT "February"
       CASE  3: PRINT "March"
       CASE  4: PRINT "April"
       CASE  5: PRINT "May"
       CASE  6: PRINT "June"
       CASE  7: PRINT "July"
       CASE  8: PRINT "August"
       CASE  9: PRINT "September"
       CASE 10: PRINT "October"
       CASE 11: PRINT "November"
       CASE 12: PRINT "December"
     END SELECT
     IF Month = 9 THEN
       PRINT " '", DEC2 Year  ;Else September (9 characters) doesn't fit on a 16 characters LCD
     ELSE
       PRINT " 20", DEC2 Year
     ENDIF
   ENDIF
 ELSE                         ;Else 'Signal' = FALSE, we have no signal found
   GOTO ReceiveError
 ENDIF
GOTO MainLoop
GongSignal:
 IF LDR = ON THEN             ;If there is daylight or the shadedlamps are switched on, then...
   LOW   Volume               ;...Volumepin low = Volume from gong louder...
 ELSE                         ;...else (is it dark in the living-room)...
   INPUT Volume               ;...Volumepin 3-state = Volume from gong softly
 ENDIF
 DELAYMS 155
 IF Minute   = 00 OR Test = AAN THEN Gong1 = ON ;On the whole hours (and with Test) follows a 3-tone signal
 Gong2       = ON             ;On the half hours only a 2-tone signal
 SecondPulse = ON             ;Ondertussen gaat ook de seconde puls gewoon door
 DELAYMS 500
 Gong1       = OFF
 Gong2       = OFF
 SecondPulse = OFF
 DELAYMS 330                  ;985 - 500 - 155
 INC Second
; When using the method underneath (with time instead of LDR), then erase the LDR syntax part above
; IF Hour > 5 THEN             ;Between 0:30 and 6:30 is the gong volume not loud
;   LOW   Volume               ;Volumepin low = Volume louder
; ELSE
;   INPUT Volume               ;Volumepin 3-state = Volume softly
; ENDIF
GOTO Further                  ;Go further with receiving the DCF bits from bit 15 (we omit bits 0...14)
ReceiveError:
 CLS
 PRINT "No signal"            ;Startbit not found or no signal?
 REPEAT
   CLEAR                      ;Erase all RAM
   ID1 = DCF_Signal
   WHILE DCF_Signal = ID1     ;Wait for signal changing
     INC SignalCheck
     DELAYMS 1
   WEND
   ID1 = ID1 ^ 1
     INC SignalCheck
     DELAYMS 1
   WEND
 UNTIL SignalCheck < 990
 Initialize = TRUE            ;Initialize again after the error
GOTO MainLoop
;V-2 to V-1:
;With parity check
;PulseLength as long as possible
;SecondPulse is now precise 0,5 sec
« Last Edit: December 22, 2009, 12:59:54 00:59 by pickit2 » Logged
Is there life after Moto Guzzi, Microchip PIC and Music?Huh??
