April 30, 2025, 02:16:34 02:16
Author Topic: Speech Compression & Decompression using ADPCM with AVR microcontroller  (Read 9899 times)
yasir9909
-Receive: 107
« on: October 23, 2009, 08:25:19 20:25 »
I have implemented Adaptive Differential Pulse Code Modulation (ADPCM) based speech compression algorithm (with decompression implemented on PC side) on ATmega8535.I have got this project work published in an article in 'Electronics World Magazine' (http://www.electronicsworld.co.uk/).
I would like to share this implementation with this community.The scanned pages of my article published in 'Electronics World Magazine'  are :
I would elaborate the implementation details of this MCU application in my next posts.
m.yasir
Posted on: October 23, 2009, 09:14:12 21:14 - Automerged
Note : The publisher of this magazine has committed a mistake in publishing this article,she has placed the diagram of Encoder in place of Decoder and has placed the diagram of Decoder in place of Encoder
« Last Edit: November 09, 2009, 07:18:01 19:18 by yasir9909 » Logged
m.yasir
yasir9909
-Receive: 107
« Reply #1 on: November 08, 2009, 04:44:40 16:44 »
Generic C code for ADPCM Speech Encoding Function:
ADPCMEncoder() FUNCTION
/* Table of index changes */
const int IndexTable[16] = {
0xff, 0xff, 0xff, 0xff, 2, 4, 6, 8,
/* Quantizer step size lookup table */
const long StepSizeTable[89] = {
7, 8, 9, 10, 11, 12, 13, 14, 16, 17,
19, 21, 23, 25, 28, 31, 34, 37, 41, 45,
50, 55, 60, 66, 73, 80, 88, 97, 107, 118,
130, 143, 157, 173, 190, 209, 230, 253, 279, 307,
337, 371, 408, 449, 494, 544, 598, 658, 724, 796,
876, 963, 1060, 1166, 1282, 1411, 1552, 1707, 1878, 2066,
2272, 2499, 2749, 3024, 3327, 3660, 4026, 4428, 4871, 5358,
5894, 6484, 7132, 7845, 8630, 9493, 10442, 11487, 12635, 13899,
15289, 16818, 18500, 20350, 22385, 24623, 27086, 29794, 32767
signed long diff; /* Difference between sample and predicted sample */
long step; /* Quantizer step size */
signed long predsample; /* Output of ADPCM predictor */
signed long diffq; /* Dequantized predicted difference */
int index; /* Index into step size table */
* ADPCMEncoder - ADPCM encoder routine *
* Input Variables: *
* signed long sample - 16-bit signed speech sample *
* Return Variable: *
* char - 8-bit number containing the 4-bit ADPCM code *
char ADPCMEncoder( signed long sample )
int code; /* ADPCM output value */
int tempstep; /* Temporary step size */
/* Restore previous values of predicted sample and quantizer step
size index
predsample = state.prevsample;
index = state.previndex;
step = StepSizeTable[index];
/* Compute the difference between the actual sample (sample) and the
the predicted sample (predsample)
diff = sample - predsample;
if(diff >= 0)
code = 0;
else
code = 8;
diff = -diff;
/* Quantize the difference into the 4-bit ADPCM code using the
the quantizer step size
tempstep = step;
if( diff >= tempstep )
code |= 4;
diff -= tempstep;
tempstep >>= 1;
code |= 2;
diff -= tempstep;
tempstep >>= 1;
code |= 1;
/* Inverse quantize the ADPCM code into a predicted difference
using the quantizer step size
diffq = step >> 3;
if( code & 4 )
diffq += step;
if( code & 2 )
diffq += step >> 1;
if( code & 1 )
diffq += step >> 2;
/* Fixed predictor computes new predicted sample by adding the
old predicted sample to predicted difference
if( code & 8 )
predsample -= diffq;
else
predsample += diffq;
/* Check for overflow of the new predicted sample
if( predsample > 32767 )
predsample = 32767;
else if( predsample < -32768 )
predsample = -32768;
/* Find new quantizer stepsize index by adding the old index
to a table lookup using the ADPCM code
index += IndexTable[code];
/* Check for overflow of the new quantizer step size index
if( index < 0 )
index = 0;
if( index > 88 )
index = 88;
/* Save the predicted sample and quantizer step size index for
next iteration
state.prevsample = predsample;
state.previndex = index;
/* Return the new ADPCM code */
return ( code & 0x0f );
Generic C code for ADPCM Speech Decoding Function:
ADPCMDecoder() FUNCTION
* ADPCMDecoder - ADPCM decoder routine *
* char code - 8-bit number containing the 4-bit ADPCM code *
* signed long - 16-bit signed speech sample *
signed long ADPCMDecoder(char code )
size index
/* Find quantizer step size from lookup table using index
/* Inverse quantize the ADPCM code into a difference using the
quantizer step size
diffq = step >> 3;
if( code & 4 )
diffq += step;
if( code & 2 )
diffq += step >> 1;
if( code & 1 )
diffq += step >> 2;
/* Add the difference to the predicted sample
if( code & 8 )
else
predsample = 32767;
/* Find new quantizer step size by adding the old index and a
if( index < 0 )
index = 0;
if( index > 88 )
index = 88;
/* Save predicted sample and quantizer step size index for next
iteration
/* Return the new speech sample */
return( predsample );
[/code][/code]
« Last Edit: November 08, 2009, 05:50:56 17:50 by yasir9909 » Logged
m.yasir
