Bamsalt
-Given: 359
-Receive: 330
« Reply #125 on: April 03, 2015, 11:41:56 11:41 » |
File updated ....
Posted on: March 20, 2015, 01:32:51 13:32 - Automerged
SolidCAM 2015 SP2 - 64bits
« Last Edit: April 03, 2015, 03:27:39 15:27 by Bamsalt »
biko4710
-Given: 45
-Receive: 40
« Reply #126 on: April 09, 2015, 02:57:27 02:57 » |
This is only an update to SP2, not full. SOLIDWORKS 2015 SP2.1 products fix SPR 862458 (Save operation may not save complete files, which may result in file corruption.). This problem is specific to SOLIDWORKS 2015 products. The random problem may occur when saving in SOLIDWORKS CAD or when saving a file in an application that uses the SOLIDWORKS Document Manager such as, but not limited to, SOLIDWORKS Enterprise PDM, SOLIDWORKS Workgroup PDM, and SOLIDWORKS Pack and Go. Customers currently using any 2015 Service Pack older than SP2.1 should upgrade to SP2.1.
SP2.1 torrent is at #124 !
circuit77
-Receive: 16
« Reply #127 on: April 13, 2015, 01:34:35 01:34 » |
Hi Jesse, are you referring to the activator from your 2014 June 23 post ( http://www.sonsivri.to/forum/index.php?topic=25408.msg163249#msg163249)? This latest link only has the official exe, and the original activator link is offline --- any chance you can repost the activator? I'd be happy to mill you some aluminum gratitude = ) Lattest release as of March 01 2015
Activation is the same is working ok until now, install as usual, offline, then activate, and block acces to the net.
Saludos
Bamsalt
-Given: 359
-Receive: 330
« Reply #128 on: May 03, 2015, 04:20:23 04:20 » |
SolidCAM 2015 SP2 HF3 is already out. I made a search in the net, there are lots of link out there .....
If you do encounter problem, just make a request ...
hosmis
-Given: 334
-Receive: 243
« Reply #129 on: May 03, 2015, 07:09:03 07:09 » |
SolidCAM 2015 SP2 HF3 Multilanguage 32/64 torrent
Bamsalt
-Given: 359
-Receive: 330
« Reply #130 on: May 05, 2015, 12:28:28 12:28 » |
SP1.1 update for "CAMWorks 2015 for Solidworks".
CAMWorks 2015 SP1.1 Win64 - SSQ
« Last Edit: May 05, 2015, 12:45:03 12:45 by Bamsalt »
Bamsalt
-Given: 359
-Receive: 330
« Reply #131 on: May 07, 2015, 10:17:54 22:17 » |
SolidWorks 2015 SP3.0 Full Multilanguage Integrated - Torrent
-Given: 833
-Receive: 4320
« Reply #132 on: May 10, 2015, 10:09:03 22:09 » |
SolidWorks 2015 SP3.0 uploaded.net ul.to link
Bamsalt
-Given: 359
-Receive: 330
« Reply #133 on: June 06, 2015, 08:39:46 08:39 » |
SolidCAM 2015 SP2 HF4
houly
-Given: 99
-Receive: 106
« Reply #134 on: June 30, 2015, 04:01:11 16:01 » |
Hello all, Does someone could upload lasted version of Solidworks ? last links seem to be dead...
thank you
hosmis
-Given: 334
-Receive: 243
« Reply #135 on: June 30, 2015, 04:15:52 16:15 » |
sw2015 sp3 torrent :
Bamsalt
-Given: 359
-Receive: 330
« Reply #136 on: July 01, 2015, 06:50:26 06:50 » |
You can get your Solidworks 2015 SP4 here ....
houly
-Given: 99
-Receive: 106
« Reply #137 on: July 01, 2015, 10:28:58 10:28 » |
Hello Bamsalt, I can't unrar your file, does it contain a password ?
Bamsalt
-Given: 359
-Receive: 330
« Reply #138 on: July 01, 2015, 10:38:10 10:38 » |
Yes, just use the standard password ....
hosmis
-Given: 334
-Receive: 243
« Reply #139 on: July 01, 2015, 03:31:02 15:31 » |
sw2015sp4 torrent
Bamsalt
-Given: 359
-Receive: 330
« Reply #140 on: July 25, 2015, 07:24:05 07:24 » |
SolidCam 2015 SP3 x86 x64 is right below ...
jesse
-Receive: 101
« Reply #141 on: September 04, 2015, 07:01:40 07:01 » |
Hi Fellas
Last Build of HsmWorks from August 28 2015, somebody asked for the activator so...............
Saludos
kreutz
-Given: 994
-Receive: 125
« Reply #142 on: September 07, 2015, 04:26:53 16:26 » |
SOLID WORKS software problems due to conflict with Microsoft update # KB3072630There is a conflict with Microsoft KB3072630 (published July 14 2015) which can cause SOLIDWORKS to become unstable when installed or updated after KB3072630 is applied. The MS update makes changes to Windows Installer which prevents SolidWorks installations (new, modify/repair, update or uninstall) from being executed correctly. Solidworks' staff is trying to produce a software fix as soon as possible in 2015 and 2016 versions, however, in the interim, please review the information on the link below to prevent and correct instability caused by this conflict. Affected softwareSOLIDWORKS 2011 - 2015, and SOLIDWORKS 2016 beta. SymptomsInstability may appear in many different functional areas of the software, so the list below may not be complete. Known symptoms are: Missing add-ins from the SOLIDWORKS add-ins list in the Tools menu. Error when launching SOLIDWORKS or opening a file: "Could not load SOLIDWORKS DLL: GdtAnalysisSupport.dll". Crashes when recording, playing or editing a SOLIDWORKS Macro. Instability when using Equations. Error when launching SOLIDWORKS or SOLIDWORKS Explorer: "DWG document manager library is invalid or missing". More information and temporary solutions on: https://www.solidsolutions.co.uk/Blog/2015/07/Alert-Windows-Update-Causing-Issues-with-SOLIDWORKS-InstallsUpgrades/#.Vc8cGUa4EcM
« Last Edit: September 07, 2015, 04:29:07 16:29 by kreutz »
hosmis
-Given: 334
-Receive: 243
« Reply #143 on: October 06, 2015, 02:27:05 14:27 » |
sw2016 multi lang torrent
bigtoy
-Given: 337
-Receive: 297
« Reply #145 on: January 28, 2016, 05:38:50 05:38 » |
Do Solidworks KeyGens actually work?We have SW at my work so I can copy the install files, no problem. Of course at work we use a license server - I can't copy that! So for home use, what "medicines" do I need to apply to crack SW so it'll work? On the internet I've seen SW keygens mentioned; is that's what's used here? I'm loath to download a multi-gigabyte torrent file just to answer the question, I hope you understand Hence the questions.
-Given: 833
-Receive: 4320
« Reply #146 on: January 28, 2016, 09:02:19 09:02 » |
you maybe lucky and get a licence file and patched files, only problem trying to save a large download is, If the patch & licence files don't match your version it may not get fix...
It happens so many times someone has fix files and says download from developers site, then developer changes the install file, and the fix no longer works.
optikon
-Given: 1105
-Receive: 2007
« Reply #147 on: January 28, 2016, 10:57:01 10:57 » |
Do Solidworks KeyGens actually work?We have SW at my work so I can copy the install files, no problem. Of course at work we use a license server - I can't copy that! So for home use, what "medicines" do I need to apply to crack SW so it'll work? On the internet I've seen SW keygens mentioned; is that's what's used here? I'm loath to download a multi-gigabyte torrent file just to answer the question, I hope you understand Hence the questions. You want the fixes by SSQ, they are clean and flawless. I would stay away from anything else. which version do you have? perhaps we could post just the SSQ fix for what you need.
« Last Edit: January 28, 2016, 11:01:03 11:01 by optikon »
bigtoy
-Given: 337
-Receive: 297
« Reply #148 on: January 29, 2016, 04:20:30 04:20 » |
We use SW 2016, I believe with the service pack (SP1). However we also use 2015. Either is fine by me, if fixes are available for either of them.
-Given: 833
-Receive: 4320
« Reply #149 on: January 29, 2016, 02:21:08 14:21 » |
download the torrent and select from the list of files just the fix.. or just mark the two *.iso as don't down load...
