hosmis
-Given: 334
-Receive: 243
« Reply #100 on: June 23, 2014, 10:30:35 22:30 » |
Solid works 20 14 s p 4 zorrent 32&64
hosmis
-Given: 334
-Receive: 243
« Reply #101 on: July 14, 2014, 03:50:36 15:50 » |
Solidcam 2014 sp2 only English, Czech and German languages Edit : All 17 languages are supported Chinese Simplified, Chinese Traditional, Czech, Danish, Dutch, English, French, German, Hebrew, Hungarian, Italian, Japanese, Korean, Polish, Portuguese, Russian, Spanish, Turkish second text
« Last Edit: July 15, 2014, 02:24:24 14:24 by hosmis »
hosmis
-Given: 334
-Receive: 243
« Reply #102 on: July 26, 2014, 11:20:21 23:20 » |
https://www.google.com.tr/search?q=windows+driver+signature+disable&rls=com.microsoft:tr-TR:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7GGHP_trTR588&gfe_rd=cr&ei=hS3UU_3ZDKSG8QfClIC4Bg&gws_rd=sslhttp://solidsquad.blogspot.com.tr/2013/10/solidcam-2014-sp0-multilanguage-for.htmlinclude , readme_64bit txt 1. SolidCAM 2014 SP2 64bit Setup
1.1. Download SolidCAM2014_SP2_English_64bit.iso and one or more archives with language localization needed from folder ..\Win64\Localizations\
1.2. Install SolidCAM 2014 SP2 English 64bit
1.3. Unpack all folder from your localization archive to <SolidCAM 2013 progdir> (by default C:\Program Files\SolidCAM2014\) and overwrite original ones
2. USB-HASP-Emulator Setup
ATTENTION!
For SolidCAM 2014 SP1 you need to register new dump (solidcam2011_sp8_hf1_2012.reg) and restart USB-HASP-Emulator
To install emulator you need Administrator rights! To install emulator for Win Vista or Win7 you need to boot computer in mofe F8 > Enable Enforcement Unsigned drivers! Moreover you need to use boot mode F8 > Enable Enforcement Unsigned drivers at every reboot of computer!
2.1. Copy folder ..Win64\_SolidSQUAD_\USB-Emul_Win64 to C:
2.2. Register dump (run "solidcam2011_sp8_hf1_2012.reg" and confirm to add info in Windows Registry)
2.3. Run ..\USB_Emul_Win64\install.bat and wait until system will find and install new devices
If setup is succesfull you have to see new devices:
Device Manager -> Universal Serial Bus controllers -> SafNet inc. HASP key Device Manager -> Universal Serial Bus controllers -> SafNet inc. USB key
That's all
Cracked by Team-SolidSQUAD (SSQ)
« Last Edit: July 26, 2014, 11:29:54 23:29 by hosmis »
hosmis
-Given: 334
-Receive: 243
« Reply #103 on: July 27, 2014, 01:29:58 01:29 » |
Denimdragon
« Reply #104 on: July 28, 2014, 02:25:53 02:25 » |
I keep getting error -3,7 What am I doing wrong? Should I install the emu first? I've been fighting these for a couple of days now
« Last Edit: July 28, 2014, 02:32:14 02:32 by Denimdragon »
-Given: 833
-Receive: 4320
« Reply #105 on: July 28, 2014, 11:22:42 11:22 » |
I keep getting error -3,7 What am I doing wrong? Should I install the emu first? I've been fighting these for a couple of days now way too much information, to give an answer...(jk) I and other just ignore such requests. to help you help us. Are you keeping it a secret as to what version or who's post you downloaded from?. (no clue from thank you buttons pressed) If by chance you downloaded via links from hosmis, he went the extra... to post an how to at #108...
Denimdragon
« Reply #106 on: July 28, 2014, 01:55:14 13:55 » |
Yeah sorry about that. It's SolidCAM_2014_S1_SSQ (disk image file). I'm on windows 8.1 with allow unsigned drivers enforced. Maybe I'm not understanding the process in the readme text (which is the same as what hosmis has posted above in #108) on how to move the files around. When it says "Unpack all folder from your localization archive to <SolidCAM 2013 progdir> (by default C:\Program Files\SolidCAM2014\) and overwrite original ones" It's possible that I'm doing that wrong because I don't see original language files to overwrite. Also I never see the hasp keys installed on my device manager. I feel like such a noob. I use to be a wiz at this but not anymore I guess
« Last Edit: July 28, 2014, 02:32:11 14:32 by Denimdragon »
-Given: 833
-Receive: 4320
« Reply #107 on: July 28, 2014, 02:47:29 14:47 » |
Yeah sorry about that. It's SolidCAM_2014_S1_SSQ (disk image file). I'm on windows 8.1 with allow unsigned drivers enforced. Maybe I'm not understanding the process in the readme text (which is the same as what hosmis has posted above in #108) on how to move the files around. When it says "Unpack all folder from your localization archive to <SolidCAM 2013 progdir> (by default C:\Program Files\SolidCAM2014\) and overwrite original ones" It's possible that I'm doing that wrong because I don't see original language files to overwrite. Also I never see the hasp keys installed on my device manager. I feel like such a noob. I use to be a wiz at this but not anymore I guess by default C:\Program Files\SolidCAM2014\ if you install to any other than default path, as with most programs, patches and cracks don't work, or are a pain to fix, so always install to default folders. just like the pass word to a laptop was by word of mouth GreatGrandDaughter only problem was the person who put in the password could not spell.
Denimdragon
« Reply #108 on: July 30, 2014, 12:06:23 00:06 » |
Working great now thanks for the help!
houly
-Given: 99
-Receive: 106
« Reply #109 on: September 17, 2014, 09:42:55 09:42 » |
Hello all, I'm trying to install SolidWorks 2014 SP4 but I always hav an error with Electrical schematic package, here is the screenshot : could you please help me ? regards PS : I'm using Win7 / 64bits.
optikon
-Given: 1105
-Receive: 2007
« Reply #110 on: September 17, 2014, 10:37:11 10:37 » |
houly
-Given: 99
-Receive: 106
« Reply #111 on: September 17, 2014, 10:52:10 10:52 » |
Thanks Optikon but I can't find the file .ldf, .mdf and I don't know how to create a base... any other solution ?
-Given: 833
-Receive: 4320
« Reply #112 on: September 17, 2014, 11:35:46 11:35 » |
What is your install path? try default path
houly
-Given: 99
-Receive: 106
« Reply #113 on: September 17, 2014, 04:18:46 16:18 » |
Hello pickit2, Thanks for your reply, I already use the default install path.
I finally found .ldf and .mdf files and deleted all files of SQL... and it seems to work properly ! Thanks again
hosmis
-Given: 334
-Receive: 243
« Reply #114 on: October 14, 2014, 03:14:12 03:14 » |
SolidWorks 2015 SP0 Full Multilang (by SSQ)
Only 64-bit Win 7/8/8.1 are supported!
torrent file..
« Last Edit: October 14, 2014, 03:24:12 03:24 by hosmis »
hosmis
-Given: 334
-Receive: 243
« Reply #115 on: October 29, 2014, 02:12:51 02:12 » |
Solidcam2014sp3 Multilang 32-64 torrent
jesse
-Receive: 101
« Reply #116 on: October 30, 2014, 06:40:05 06:40 » |
Hi Fellas long time no see ya
HsmWorks 2015 Release 38078 from October 29 2014 (Fresh out of the oven)
Saludos
green2red
-Given: 127
-Receive: 108
« Reply #117 on: November 28, 2014, 07:00:28 19:00 » |
InfiniteSkills - SolidWorks Electrical - Schematic Fundamentals Training Video A Practical SolidWorks Training Course That Teaches Real World Skills
George
-Given: 20
-Receive: 35
« Reply #118 on: December 01, 2014, 01:58:10 01:58 » |
Jesse, any news on an updated crack that works properly for newer versions of HsmWorks?
Bamsalt
-Given: 359
-Receive: 330
« Reply #119 on: February 09, 2015, 08:52:25 20:52 » |
SolidCAM 2015 SP1 - 64bits
Bamsalt
-Given: 359
-Receive: 330
« Reply #120 on: February 21, 2015, 02:49:01 02:49 » |
SolidWorks 2015 SP2 x64
jesse
-Receive: 101
« Reply #121 on: March 01, 2015, 07:19:10 19:19 » |
Lattest release as of March 01 2015 Jesse, any news on an updated crack that works properly for newer versions of HsmWorks?
Activation is the same is working ok until now, install as usual, offline, then activate, and block acces to the net. Saludos
George
-Given: 20
-Receive: 35
« Reply #122 on: March 01, 2015, 09:30:33 21:30 » |
Re activation - the main program works, but Posting terminates with activation related errors.
Cheers, thanks for the new build!
Bamsalt
-Given: 359
-Receive: 330
« Reply #123 on: March 20, 2015, 08:13:00 08:13 » |
1. SolidWorks 2015 SP2.1 Full - SSQ
2. CAMWorks 2015 SP1.0 x64 - SSQ
Issue corrected, the new file is SW15SP2_1.rar
« Last Edit: April 03, 2015, 03:25:52 15:25 by Bamsalt »
UncleBog
-Given: 165
-Receive: 176
« Reply #124 on: March 20, 2015, 11:25:37 11:25 » |
Hello Bamsalt,
Both of your attachments contain the same torrent (CAMWorks). Could you correct the SolidWorks file please ?
