jesse
-Receive: 101
« on: October 20, 2009, 06:24:42 06:24 » |
Finally!!!!!!! Solidworks 2010 SP0 Win32, Win64, Full, Multilanguage, and Medicine. Torrent file for now: http://www.filefactory.com/file/a052d3h/n/SW_2k10_rar Beware of the size: 10.15 GB Saludos EDIT: Corrected torrent file
« Last Edit: December 28, 2013, 11:07:39 23:07 by pickit2 »
preatorian
-Given: 16
« Reply #1 on: October 23, 2009, 03:11:19 15:11 » |
Hi all, Is this an official release?
joker12
-Receive: 80
« Reply #2 on: October 24, 2009, 02:26:48 02:26 » |
Saw this posted at http://my.softarchive.net/search/?q=solidworks+2010&x=12&y=7Downloads are from Hotfile / Storage / Filefactory No Rapidshare links. x32 and x64 iso's included. PS: Very large Download! Update: I downloaded and installed 64 bit version. It seems to work. I have not tried all the functions. Total download is 10 Gigs. X32 = 5 Gigs and x64 = 5 Gigs Cracks are patched DLL's Also Keep firewall up or disconnect Network as it calls home at begin install to verify serial number.
gk101
« Reply #3 on: December 12, 2009, 04:05:18 16:05 » |
I downloaded the x86 parts (52 files + sfv ) and the download went fine. When I tried to open a file with WINRAR it ask for a password. I did open with WINRAR the sfv file and I thought the numbers (FC51D247 for part01) was the password, I guess not. Where do I find or get the password so WINRAR will open these files?
oldvan
-Receive: 107
If the van is a Rockin'...
« Reply #4 on: December 13, 2009, 01:13:33 01:13 » |
Tracker responds "torrent file not registered", but thanks to DHT/Peer Exchange torrent is downloading now, shows 6 seeders and 88 peers. ----------------------------------- About 24 hours later... PS: Success downloading 32-bit version using the torrent.
« Last Edit: December 13, 2009, 03:43:08 15:43 by oldvan »
hosmis
Online
-Given: 347
-Receive: 243
« Reply #5 on: December 13, 2009, 09:37:51 09:37 » |
Working
ed2k://|file|[3D.CAD.%E8%A8%AD%E8%A8%88%E5%B7%A5%E7%A8%8B%E8%BB%9F%E4%BB%B6].SolidWorks.2010.SP0.0.Multilingual.Win32.Full.DVDiSO.iso|5360013312|A1E9B5F27F1D79F46F3B64629B0BFDD5|h=WGE42FHKR7XZMO2TWKTW7QKS4SUORD5G|/
-Given: 841
-Receive: 4365
« Reply #6 on: December 13, 2009, 02:12:46 14:12 » |
password is in the post Note: this is not a link but it is the password >> ut@updatesofts.com
« Last Edit: December 13, 2009, 02:14:47 14:14 by pickit2 »
gk101
« Reply #7 on: December 13, 2009, 08:40:59 20:40 » |
Thanks for the help!!! I was able to open and install. Everthing opens fine except the SW 2010 drawing program itself. As it is opening a box pops up saying "An error has occurred and Solidworks needs to restart" Now I still have Solidworks 2007 installed. Could that be the problem. Should I uninstall '07?
-Given: 561
« Reply #8 on: December 13, 2009, 09:05:05 21:05 » |
it sounds like you have not installed the pathces correct, I've still got solidworks 2009 SP0 installed and both still work.
I had the same problem but reinstalled tha patches and everything worked ok
gk101
« Reply #9 on: December 13, 2009, 10:39:00 22:39 » |
I thought that also but I checked the version and it is the correct one. I put the sldappu.dll in the C:\program files\solidworks corp\solidworks it is version 18.0.0.5035. I'm at a loss. I've done 2006 and 2007 no problem.but this one is giving me a headache! Thanks for your help...any other ideas will be welcome.
-Given: 561
« Reply #10 on: December 14, 2009, 08:08:01 20:08 » |
Have you only patched 1 file, the patches I applied as follows E-drawings folder 3 dll files photoview360 folder 1 dll file simulation folder licnce.dat file solidworks folder (win32) SLDAPPu.dll swexplorer a patcher exe file
If not try this way and it shoudl work
gk101
« Reply #11 on: December 15, 2009, 05:16:03 05:16 » |
You just maybe correct. I don't think I put the error correct in SWexplorer. So I did that and first it said error fixed then it still would not work. So I'm doing it all over again. Thanks, You have been a lot of help. I feel confident I can get this running with your help. The other solidworks (2006 & 2007) I got working just had one crack file and it was done. This one is a little more complicated.
gk101
« Reply #12 on: December 16, 2009, 04:11:01 04:11 » |
Okay, I cleared everything out and tried again. E-drawings, Photoview360, swexplorer seems to work. Now when I installed SW2010 it ask me if I wanted to install simulation. Was I supposed to check yes? If so what serial #? I think that maybe one problem. Also when I copy swexplorer2pdmworks_crk to swexplorer file when I click on it in the file it says error fixed.But after I try to load SW I get the error message and it then says "error Patching file" Also it does not say it is an .exe file it says it is an Application. My patch says:"swexplorer2pdmworks_crk" NOT "swexplorer2pdmworks_crk.exe" And just curious what is this number for?...Serial Number: 04M7DP-PEJTNX-FR64BH-BVJB36-5K9QQW-AWD5VA
I'm hoping you can see something I'm doing incorrectly!
-Given: 841
-Receive: 4365
« Reply #13 on: December 17, 2009, 12:32:08 00:32 » |
This from the sw2010_SolidSQUAD.nfo with some notes.[you need to read between the lines, for nfo files]  ---------------------------------------- Install Notes ---------------------------------------- 1. Burn the DVD images on DOUBLE-LAYER DVD+R or mount via Alcohol 120% or Daemon Tools. 2. Point to X:/sldim/sldim.exe, where X is your DVD letter 3. Install and use the enclosed serial [in sw2010_SolidSQUAD.nfo] 4. Apply cracks from archive [ by this copy the contents of the folders in the crack folder to your install folder]see wizpics last post two above this one. if you don't copy the cracks over SW2010 makes out it's working but will fall over sometime later. 5. Enjoy! My patch says:"swexplorer2pdmworks_crk" NOT "swexplorer2pdmworks_crk.exe"
means you have file .extension or system files hidden, so windows don't show the .exe
« Last Edit: December 17, 2009, 12:39:55 00:39 by pickit2 »
gk101
« Reply #14 on: December 17, 2009, 01:13:18 13:13 » |
Thanks for your help!! I have done everything to the letter (except I used MagicISO, is that a problem?) and I still get an "error message". I'll just go back to my 2007 for now.
-Given: 841
-Receive: 4365
« Reply #15 on: December 17, 2009, 08:11:37 20:11 » |
I would have used nero or an other burning program to write the iso, or you could use winrar to unpack the *.iso to c:\sw2010 and run install from there.
gk101
« Reply #16 on: December 18, 2009, 02:53:18 14:53 » |
I unpacked with WINRAR installed the paches but get the same error message. I know I'm not doing some little thing or doing something incorrect. One thing I do know Simulation is not installing completely. SW install ask for a password for simulation. Don't know what to use. Many thanks for your help.
-Given: 841
-Receive: 4365
« Reply #17 on: December 19, 2009, 01:09:47 13:09 » |
What version are you using? I have installed 64bit onto main pc and laptop. Q. did you use the install serial to be found in the file sw2010_SolidSQUAD.nfo there are two one starting >>> 0000 0000 0000 plus another 3 sets of numbers. (total 24 digits) From starting install from setup.exe, The install don't ask for any other serials after that number is put in and install carrys on to finish.
« Last Edit: December 19, 2009, 01:12:02 13:12 by pickit2 »
gk101
« Reply #18 on: December 19, 2009, 03:22:03 15:22 » |
I downloaded the x86, 52 rar files + sfv from Rapidshare. I opened the files with WINRAR, The first time I did a virtual mount with MAGICiso. Then under SW2010_SPO I clicked on the RED SW cube and a window saying "SolidWorks 2010 SPO Installation Manager" comes up with a graphic of the bottom half of a motorcycle at the top. It ask me If I'm individual or Administrative, I chose the former, Click Next, It ask for Serial Number, It already has the first 4 sets filled in correctly I filled in the last two set of four with proper letters and numbers as found in: Solidworks\SW 2010uz\solidSquad. Then on the same page it ask for other serial numbers, For PDM,Simulation,Motion and Flow Simulation. If I click on Simulation it has a set of boxes for the numbers, I tried the same set as for the program itself and it says incorrect so I just leave those four choices unchecked. Then click next it checks my system and it starts install. Every thing seams okay. I then go to C:\ where it loaded and apply the patches as instructions in solidSQUAD crack file. The thing is everything, Solidworks, edrawings,photoview360 and explorer I find where to overwrite the patches to except for Simulation.Also I find no icon to setup Simulation. So I click on the Desktop SW 2010 icon and SW 2010 graphic comes up and the a few seconds later the screen flickers and the a box pops up and says "an error has occurred and solidworks needs to restart". Now when I unpack to C:\ with WINRAR A different small install window comes up, It has no motorcycle graphic, Just says install SW 2010 on my computer, It only ask for the serial number a few questions like sharing info I choose no and then install. Everything seems okay. After it completes install I find where to put all the cracks per instructions except for Simulation!! I can't find where to put the "license DAT file. Simulation Is in a sub folder and I don't see where to over write the DAT to. There is no " SW Simulation progdir>\License". I have opened every folder and file to find the license and a setup but find none. So I do nothing for Simulation. So when I click the desktop icon for SW 2010 It starts to open I get the same flicker and the same error window pops up. Thats all I know to tell you.
« Reply #19 on: April 30, 2010, 05:37:32 05:37 » |
« Last Edit: May 02, 2010, 06:12:28 06:12 by solutions »
hosmis
Online
-Given: 347
-Receive: 243
« Reply #20 on: April 30, 2010, 03:58:34 15:58 » |
sgoum
-Given: 94
-Receive: 68
« Reply #21 on: May 03, 2010, 04:08:11 16:08 » |
PilotPTK
-Receive: 23
« Reply #22 on: May 17, 2010, 05:04:03 05:04 » |
Solidworks 2010 SP3.0 by SolidSquad
hosmis
Online
-Given: 347
-Receive: 243
« Reply #23 on: June 24, 2010, 04:05:43 04:05 » |
hosmis
Online
-Given: 347
-Receive: 243
« Reply #24 on: June 30, 2010, 07:50:55 19:50 » |
