April 30, 2025, 09:06:47 09:06
Author Topic: best router ?  (Read 4450 times)
mr_byte31
-Given: 75
-Receive: 144
« on: October 14, 2009, 08:04:58 08:04 »
hi all
I am going to buy a new router but I don't know which one is the best
I am thinking about one of those : SpeedTouch, 3Com, TPlink, Thomson, D-link
my friend told me that Thomson is a new better choice so I am asking about ur idea too???
maduran
-Given: 522
« Reply #1 on: October 14, 2009, 10:10:05 10:10 »
I am using DIR-655 from D-LINK since 2007.
It is stable and the wireless part works perfect.
mr_byte31
-Given: 75
-Receive: 144
« Reply #2 on: October 14, 2009, 12:57:55 12:57 »
the problem that this machine will work 24/24 without being restarted
so if the router hangs a lot
it will be a problem
I will take D-Link into considration
anyway thanks
willrocker
« Reply #3 on: January 24, 2010, 04:26:45 16:26 »
I had a speedtouch, had to reset every 30 minutes. It was a horrible nightmare, then got a linksys switch which was ok but eventually died, im now using a netgear which hangs maybe once a month at the most. Its a pretty good router. Something like a 'ultimate wireless router' its called, can't quite remember!
wild
-Given: 647
-Receive: 452
« Reply #4 on: January 26, 2010, 03:16:28 15:16 »
If you like tweaking with your router,
I warmly suggest you the ASUS WL-500gp (if possible the release 1 (not sold anymore), instead of the V2 version): you will find LOTS of documentation/firmware/...
I "upgraded" its internal RAM to 128MB (original 32MB), so I can run flawlessly eMule or Bittorrent clients without requiring my PC turned on 24/24.
By the way, attached to it there is also an HDD to save the received data...
Just some links:
http://www.dd-wrt.com/wiki/index.php/WL500G_Premium_v2
http://wiki.openwrt.org/oldwiki/openwrtdocs/hardware/asus/wl500gp
P.S. Please remember that you will need an external ADSL modem (this one is a ROUTER, not an ADSL/Router).
