June 23, 2024, 07:50:02 19:50
Author Topic: i need Help with multimedia card...  (Read 4560 times)
Ahmad_k
SCG Moderator
-Given: 169
-Receive: 1289
« on: January 05, 2007, 09:08:26 09:08 »
Can someone know how to read/write to multimedia card using proton+. I need an access to FAT16 system file loaded on that MMC.
fernandodiaz
« Reply #1 on: January 06, 2007, 01:59:58 01:59 »
hi my friend
save money and time with:
http://www.crownhill.co.uk/product.php?prod=1557
uALFAT-SD is our OEM board of uALFATâ„¢ chip. The low cost and the ease of use makes ALFAT-SD the ultimate solution for OEMs and hobbyists.
Fully built and tested.
Standard .1" holes for header for user interface.
Secure Digital (SD)/ Multi Media (MMC) Card connector.
5V tolerant I/Os.
Requires regulated 3.3V.
32 KHz crystal is not populated.
£35.95 ex. VAT
Ahmad_k
SCG Moderator
-Given: 169
-Receive: 1289
« Reply #2 on: January 06, 2007, 09:11:55 09:11 »
i dont want to use any chip, only the PICmicro and the MMC or SD connected directly to it.
fernandodiaz
« Reply #3 on: January 06, 2007, 09:11:11 21:11 »
HI my friend Grin
Then you can use mikrobasic library with  MMC samles and PIC18FXX
is very easy use....
only need  MMC, PIC18 , and compiler
Multi Media Card Library
The Multi Media Card (MMC) is a flash memory card standard. MMC cards are currently available in sizes up to and including 1 GB, and are used in cell phones, mp3 players, digital cameras, and PDA’s.
mikroBasic provides a library for accessing data on Multi Media Card via SPI communication.This library also supports SD(Secure Digital) memory cards
 Roll Eyes
hamid9543
-Given: 80
« Reply #4 on: January 08, 2007, 05:40:47 05:40 »
hi
is there library in picbasic pro  for conect mmc to pic16f877
Belgitaes
-Given: 19
« Reply #5 on: January 15, 2007, 08:01:23 08:01 »
I have find 2 example Design with MMc Card in proteus
hope this one help you
http://rapidshare.com/files/11779799/Sector_Access.zip.html
frasenci
Translator
-Given: 142
-Receive: 84
« Reply #6 on: January 16, 2007, 11:49:01 23:49 »
Hmm , very interesting Topic.
On one application I ended myself buying a Alfat chip based device. US$ 39.-
Did ALL tests with MikroBasic and MikroC , no luck !! It seems that the libraries are very sensitive upon the brand of the card you use.  Sorry about that. I even broke an brand new A-DATA 512 Mb MMC card ( no longer could format ) .  Sector access works good but no FAT handling...
I am not an expert , maybe my circuits have errors ??   Roll Eyes ,... but if sector access works ,..... hmmm. Don t know for sure.
On the other hand , look on Proton`s Forums , they already have developed a set of MACROS that will handle FAT access on MMC cards BUT -------> you will need last version of the Software to handle the macro extension..... sorry again.
 Huh
I second very strongly : get yourself an ALFAT or similar chip artifact....
Just to document the topic a little bit.
So long
Greetings
Francisco
