December 14, 2025, 10:26:10 22:26
Author Topic: 50v smps  (Read 5799 times)
gevv
-Given: 159
-Receive: 534
« on: January 04, 2007, 10:06:50 10:06 »
16 tour  add
Test to continue......
first test  4amp load...
Umarım gelmez ilham perilerimin sonu... ! Modifiye uzmanı web üzerinde 320volt.com ile yaktı mumu....
rf151
« Reply #1 on: December 16, 2007, 04:11:49 16:11 »
the circuit diagram  quility is very low.  could u upload a best quility picture?
wollybyte
« Reply #2 on: March 23, 2008, 07:45:47 07:45 »
what transformer is used in this design
can you give winding details
heroinb
« Reply #3 on: March 28, 2008, 10:44:02 10:44 »
i didnt understand.
ekinci
« Reply #4 on: April 03, 2008, 07:31:37 07:31 »
have you ever tried two switch forward converter?
ausdev
-Given: 8
« Reply #5 on: April 15, 2008, 06:29:21 06:29 »
May I ask a stupid question!!
What is a SMPS when referring to power supplys ?
 Embarrassed
picnaut
« Reply #6 on: April 22, 2008, 12:53:58 00:53 »
I don't think that an honest question is stupid. We all learn new terms from time to time.
Well, SMPS stands for "Switched Mode Power Supply". On the other hand, the normal classic power supply is a "Linear Power Supply".
SMPS and Linear supplies have their own pros and cons. SMPS is small, light weight and very efficient but very noisy interms of EMI/RFI (Electrical noise). The Liner supply on the other hand is much larger, heavier (on account of large transformer), dissipates more heat and has poor efficiency. But, at the same time a Linear supply has immaculate regulation, extremely low noise and is ripple free.
 Smiley
joprinz
« Reply #7 on: April 23, 2008, 11:18:03 23:18 »
Hope you have completed the power supply. If its possible a quick Note on the circuit and some details about the transformer will be very useful to understand your circuit better.
But thanks anyways :-)
