You think I am funny guy huh?
November 25, 2024, 04:48:58 16:48
Author Topic: pcb file  (Read 5340 times)
Jeckson
-Given: 54
« on: September 01, 2009, 03:53:36 15:53 »
Hai all
I'm looking PCB files for MAX1110/MAX1112 and MAX7224.
Unfortunedly only found at google from maxim app notes which cann't made by hand and double side.
Someome have info about the pcbs from other experimenters ?
Like bigger tracks or perhaps 1 side pcb
Thank you very much
Jeckson
PS:
This similiar my thread at 8052.com without response
leptro
-Given: 618
-Receive: 26
« Reply #1 on: September 01, 2009, 04:28:08 16:28 »
i dont understand your problem, all those ics are available in dip package.
ithink it's easy to solder them.
perhaps using a breadboard  is the solution or a lot off pcb software are available in this forum to diy.
hopes i help you.
TomJackson69
-Receive: 63
« Reply #2 on: September 02, 2009, 05:13:04 05:13 »
Hi Jeckson,
Please explain about your problem. Do you need a software program to make PCB? or you need to someone to show you how to make a PCB?
I am not so sure what is your problem.
Tom
Con Rong Chau Tien
sphinx
-Given: 614
-Receive: 270
« Reply #3 on: September 02, 2009, 05:33:25 05:33 »
i think he means that what he found was double sided pcb's wich he cant make, so my guess is that he is looking for some single side pcb layout for those circuits maybe with some  thicker/wider copper tracks.
which might be simpler to make.
hmm cant u download eagle cad and make those cant be many components and there you can make as wide tracks as you want them to be. in free mode on eagle u can make 100mm x 80mm single or double sided with one sheet. i think that would be enough for that project
regards mike
Jeckson
-Given: 54
« Reply #4 on: September 03, 2009, 11:38:46 11:38 »
Thank you very much
Did you have link another experimenters which have pictures or pcb files MAX1112/1110 and MAX7224?
or done with something with bigger tracks?
Thank's
Jeckson
sphinx
-Given: 614
-Receive: 270
« Reply #5 on: September 04, 2009, 07:04:36 19:04 »
what i used my old laser printer and some see thruu plastic sheets to print on somtimes i had touch up with a black ink pen, i had my UV-lamp and transfered to pcb and then developed with fluid, then i just etched it.
the plastic i was usin was that stuff some might remember from school when they used it to show on the big white screen, i think we called it "overhead" or something like that.
i didnt make any tiny stuff but for surface mounted (not to tiny) and normal dip components it worked fine for me.
at that time i was using EDWin software but you might find free version of Eagle from CADSoft work as good, its simple and even with free version you can make good sized home projects. lately i use PCAD but for small tiny projects its too big and complex, so if youre not making very advanced things at home stay with Eagle, its also easier to learn too.
try it and make something with it and you might like to use it, if you are familiar with some other software use it instead.
best regards
Jeckson
-Given: 54
« Reply #6 on: September 07, 2009, 12:28:21 12:28 »
Thank's
But I still looking for another who's already made it...
Jeckson
-Given: 834
-Receive: 4322
« Reply #7 on: September 07, 2009, 12:56:17 12:56 »
why not get evaluation kit from maxim. if you only want one why not use any cad/pcb program and if you can't print layout you could use A Permanent Marker Pen or even paint your layout with enamel paint as used for model plastic kits. http://www.maxim-ic.com/getds.cfm?qv_pk=1679
Jeckson
-Given: 54
« Reply #8 on: September 08, 2009, 01:12:06 13:12 »
Thank's....
I had download and tried with http://datasheets.maxim-ic.com/en/ds/MAX1110EVKIT-MAX1112EVKIT.pdf
unfortnedly it's double side pcb,much pin headers and jumpers which didn't available here..
If there's 1 side PCB with wider track.... will be glad to copied.
Thank you very much
Jeckson
-Given: 834
-Receive: 4322
« Reply #9 on: September 09, 2009, 02:06:30 02:06 »
here is a quick single side layout.
note: GND & AGND need a link, also c11 needs GND.
« Last Edit: September 09, 2009, 11:59:06 11:59 by pickit2 » Logged
Jeckson
-Given: 54
« Reply #10 on: September 09, 2009, 12:47:17 12:47 »
Thank you very much...
How's to replace your kindness....?
Thank you very much
Jeckson
Makassar
PS:
Did you need 1 piece MAX1110/MAX1112 EVB from your file?
Jeckson
-Given: 54
« Reply #11 on: September 09, 2009, 03:05:33 15:05 »
hai
Did you mean C10? and make link between GND & AGND
Thank's
Jeckson
-Given: 834
-Receive: 4322
« Reply #12 on: September 09, 2009, 09:11:55 21:11 »
There was an error C10 needs gnd and AGND needs connecting to GND.
see red links in pcb-layout, Also you need to add jumpers on JU1 & JU2
Jeckson
-Given: 54
« Reply #13 on: September 10, 2009, 03:52:24 15:52 »
Thank you very much
Do we needed the inductor for EMI avoid.
Thank you very much
Jeckson
Did someone also have pcb picture of MX7224 DAC? ...:-)
-Given: 554
« Reply #14 on: September 10, 2009, 06:45:55 18:45 »
Thank you very much
Thank you very much
Jeckson
Jeckson how many time do you need to keep asking, Pickit2 has given you what you require Now I will only say this once and once only
STOP ASKING FOR THE SAME DRAWING I think you should do some home work and get some PCB software and lay it out yourself don't expect others to do it for you
