December 21, 2024, 02:30:39 14:30
Author Topic: Req DAVID LASER SCANNER pls  (Read 13164 times)
15mgtar
« on: August 28, 2009, 09:30:12 09:30 »
sgoum
-Given: 94
-Receive: 68
« Reply #1 on: August 31, 2009, 07:27:31 19:27 »
http://rapidshare.com/files/272580370/David_Laserscanner_2_4_3.rar
This is from another sharing site. All credits go to the original uploader
cncdude
-Given: 28
« Reply #2 on: May 16, 2012, 06:31:06 18:31 »
can any of the users tell me if this is restricted in any way shape fusion??etc
cncdude
-Given: 28
« Reply #3 on: May 19, 2012, 01:28:38 13:28 »
Will anyone please take this on, the 3.3 version of the david_laser_scanning software,id gladly make a small donation for your troubles Wink
 https://rapidshare.com/files/3015530426/DAVID_Setup_3.3.0.2830.exe  4.57mb
and some example of what this great software does  http://www.david-laserscanner.com/?section=Gallery
2012-03-02: What's New in DAVID-Laserscanner Version 3.3.0
New Features:
 Camera Calibration: Auto-detect “outer/negative corner” vs. “inner/normal corner” setup on Calibration (Advanced Settings→Camera→Calibration→AutoDetectCalibCornerSetup)
 Camera Calibration: Auto-detect and compensate “misplaced” calibration patterns (Advanced Settings→Camera→Calibration→CompensatePatternOffsets)
 Camera Calibration: Option to auto-detect and compensate rotated calibration patterns (Advanced Settings→Camera→Calibration→CompensatePatternRotInPlane) - use with care!
 Laserscanning: Show detected laser line in depth map
 Laserscanning: Slider for changing display refresh rate during scanning
 Shapefusion: Option to use texture in alignment
 Shapefusion: New selection tool “Connected Components Selection”
 List of Scans: Allow changing order of scans by up/down buttons
 List of Scans: Ctrl+S for “Show all Scans” and Ctrl+h for “Hide all Scans”
 Global Fine Registration: Option to change number of iterations
Misc:
 Camera: Improved Exposure slider (min/max depending on camera, more and reasonable steps for DAVID cams)
 Camera: Switch off auto-exposure, RightLight(TM), auto-focus etc. by default
 Camera: Improved handling and storing of Properties
 Camera Calibration: Improved precision by reducing image noise
 Camera Calibration: Support extended pattern (two more columns of markers on each side)
 Show warning message when DAVID has no write access to store settings
 Added default camera properties for Logitech C615
 Added default camera properties for SL scanning
 COM: Start command and Save message also work for SL scanning
 Improved camera/video performance
 Shapefusion: Improved alignment speed
 Shapefusion: Improved sharpness of Fusion result
 New Canon SDK version, should support more EOS models
Bugfixes:
 Selection Tool: Fixed selection getting imprecise after some time
 Fixed showing textured scan result (crashed in some cases)
 Shapefusion: Fixed possible freeze in “Around Y-Axis” (or X or Z) mode
 Show Depth Map immediately on Start
 AutoFrequencies: Fixed rare bug leading to wrong Frequencies value
 AutoFrequencies: Fixed freezing when user changes Frequencies value
 SL: Immediately show red intensity curves when switching to SL mode
 Scan lists: Fixed problem when list was longer than screen
 Calib.scale: Check value and restore previous value only when necessary
 Shapefusion: Fixed importing OBJs from ZBrush
« Last Edit: May 21, 2012, 11:58:46 11:58 by daz » Logged
« Reply #4 on: May 21, 2012, 02:40:17 02:40 »
You need to post/host the exe before you'll even have a chance of someone looking at it.  A brief description of the s/w and what's great about this version versus what's out there already might also be a good idea (in other words, sell the idea it's worth the trouble) since there are people who have peed in the pool by asking for rev 3.051 when 3.05 was available.
« Last Edit: May 21, 2012, 02:42:35 02:42 by solutions » Logged
cncdude
-Given: 28
« Reply #5 on: May 21, 2012, 12:10:45 12:10 »
Advice taken,and more info added
Edited to say ive thown in the towel and purchased the license Cry
but im sure lots of others will still want this. Wink
« Last Edit: May 22, 2012, 05:54:38 17:54 by daz » Logged
CocaCola
-Given: 170
« Reply #6 on: June 18, 2012, 11:14:51 23:14 »
So the question begs to be asked, are you willing to share the full current version install package, so that one of the fine medicine makers here can have a go at it?  Or does the key just enable the demo?
** Edit never mind I see the key just enables the features locked in the demo, I suspected it was a completley different install package...
« Last Edit: June 19, 2012, 12:04:58 00:04 by CocaCola » Logged
cncbasher
-Given: 107
-Receive: 51
« Reply #7 on: June 19, 2012, 07:07:01 07:07 »
here's version 2.6.1 as a portable if it helps anyone
http://depositfiles.com/files/c1veifysa
0815achim
-Given: 224
-Receive: 25
« Reply #8 on: November 23, 2012, 05:52:21 05:52 »
I find Version 3.4 with keygen at following link http://www.dl4all.com/ase/tag/laserscanner.html
But take care! In the download link my virus scanner reports a maleware for the key generator.
In one of the download pages (sorry didn't know which one) is a second key generator included without virus warning that works.
