April 22, 2025, 05:37:38 17:37
Pages: [1] 2  All
Author Topic: Swordfish Compiler Full Cracked  (Read 41296 times)
sahin2580
-Receive: 34
« on: July 28, 2009, 02:21:22 14:21 »
http://rapidshare.com/files/261102646/Swordfish.rar
run Setup.exe and after go to C:\Program Files\Mecanique\Swordfish
change and owerwrite that files in the crack folders
« Last Edit: July 28, 2009, 08:08:38 20:08 by sahin2580 » Logged
gem1144aaa
-Given: 134
-Receive: 27
« Reply #1 on: July 28, 2009, 08:21:52 20:21 »
Hope we can share expertise and souce code snippets too
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1298
« Reply #2 on: July 28, 2009, 08:33:22 20:33 »
Confirmed. Working 100%
margo
-Given: 38
-Receive: 33
« Reply #3 on: July 28, 2009, 08:37:14 20:37 »
anybody tried the online update?..will it break it?...if i were brave id try.....
-Given: 841
-Receive: 4367
« Reply #4 on: July 28, 2009, 09:53:30 21:53 »
it updates your cracked files. so you then need to reinstall
ajak
-Given: 199
-Receive: 77
« Reply #5 on: July 29, 2009, 02:08:50 02:08 »
wow this is what i am finding.. thanks to sahin2580 Cheesy
this is the only one i know that is dedicated to swordfish compiler.. it has lot of examples..
http://digital-diy.com/swordfish.html
MAXPAYNE
-Given: 502
-Receive: 368
It's a little funny......
« Reply #6 on: July 31, 2009, 08:58:24 08:58 »
what is the difference between the previously uploaded file(almost 90MB) and newly uploaded file(almost 10MB) ? Is there something missing in 10MB file ?
savnik20
-Given: 37
-Receive: 401
« Reply #7 on: July 31, 2009, 11:38:03 11:38 »
Yes,the MPLAB v8.10
sahin2580
-Receive: 34
« Reply #8 on: July 31, 2009, 04:43:43 16:43 »
yes i have a mistake to the during file archive process.
meho
-Given: 1001
« Reply #9 on: August 01, 2009, 10:03:36 10:03 »
does not work for me - no hex file - i get only .cof, .idf and .sfp  Huh
SE edition works OK!
(Mikroelektronika Bigpic4 Board,18f8520, Picflash Programmer)
any ideas ?
miha
-Given: 841
-Receive: 4367
« Reply #10 on: August 01, 2009, 10:38:56 10:38 »
miha
Have you tried the samples. you only get the hex if there is no problem with your code.
meho
-Given: 1001
« Reply #11 on: August 01, 2009, 11:52:40 11:52 »
hi,pickit2,
yes,have tried some  elementary examples from  "samples" folder - even  simple  original "blink" does not work
1.syntax OK
2.compiles ok
3. --> no results window
4.no call to picflash programmer (right path established)
SE edition works fine -
(my default compiler is ME MikroBasic 7)
miha
5.no hex
gem1144aaa
-Given: 134
-Receive: 27
« Reply #12 on: August 01, 2009, 01:16:12 13:16 »
Dear PicKit2 and Meho
I ran the program on three different computers to check what you said and found it working 100% and generating all the requited files ".cof"  , ".hex" , ".idf" , ".sfp" ,".asm" non of them ware zero size nor spaces filled.
so please check that mikrochip MPlab ide V8.10 is well installed and under a folde name  RootDriveName\microchip as
c:\microchip  or e:\microchip and that your computers have no virus more over when loading he hex file on the programmer software it loaded well.
hear is the sd_mmc  program sample included with the compilation results note time and date of the result file compared to the source.
Good job sahin Bek  Wink
« Last Edit: August 01, 2009, 06:43:57 18:43 by gem1144aaa » Logged
ajak
-Given: 199
-Receive: 77
« Reply #13 on: August 01, 2009, 01:32:58 13:32 »
@ Meho
Are you sure you copy the 3 files on the crack folder on the swordfish rar file and paste it to the swordfish program folder?
1. Copy and paste Swordfish.exe and SwordfishIDE.exe from the crack folder to your Swordfish program folder. ex. "C:\Program Files\Mecanique\Swordfish\"
2. Copy and paste SwordfishICC.exe to "C:\Program Files\Mecanique\Swordfish\Bin"
overwrite the old files to new ones..
meho
-Given: 1001
« Reply #14 on: August 01, 2009, 03:53:37 15:53 »
here i am again:
i must be half - or snow - blind  Angry - or "..." -   (although wearing glasses).....
simply overlooked  " Copy and paste SwordfishICC.exe to "C:\.......\Swordfish\Bin "
it works now - BIG THANKS go to all of you at Sonsivri - specially Ajak,Pickit2,Gem1144aaa,and Sahin
have a nice weekend !
miha
margo
-Given: 38
-Receive: 33
« Reply #15 on: August 01, 2009, 04:16:03 16:16 »
anybody got the ISIS plugin to work?..I cant
-Given: 841
-Receive: 4367
« Reply #16 on: August 01, 2009, 07:54:01 19:54 »
did you see how to here
http://www.sfcompiler.co.uk/wiki/pmwiki.php?n=SwordfishUser.ISISPlugin
margo
-Given: 38
-Receive: 33
« Reply #17 on: August 01, 2009, 11:21:32 23:21 »
ok, sorted, note to others the SordfishICC needs to overwrite the file in the BIN directory too, im a muppet!,
« Last Edit: August 01, 2009, 11:46:33 23:46 by margo » Logged
ipek
-Given: 60
-Receive: 79
« Reply #18 on: August 02, 2009, 12:59:15 00:59 »
Confirmed. Working percent 100%
many thanks effort.
debutpic
« Reply #19 on: August 02, 2009, 07:49:57 07:49 »
Hello
On my computer I have
-Proteus 7.2 SP6
-Swordfish Compiler
-ISIS plugin
Where can I get Virtual Hardware Board (VHB)
for working
-Given: 841
-Receive: 4367
« Reply #20 on: August 02, 2009, 12:34:12 12:34 »
for working
When you have downloaded and installed the above, you need to ensure that Virtual Hardware Board (VHB) explorer is pointing to the installed version of ISIS. To do this, select "PLUGIN...LABCENTER ELECTRONICS PROTEUS VSM" from the IDE main menu to invoke the VHB Explorer. Press the "ISIS Location" button on the VHB Explorer main toolbar and point to your "isis.exe" file. For example,
 filename=C:\Program Files\Labcenter Electronics\Proteus 7 Demonstration\BIN\isis.exe
cjeffries1
-Given: 252
-Receive: 176
« Reply #21 on: August 02, 2009, 02:06:17 14:06 »
Has anyone got a link for the DS 18B20.DSN file that goes in the Swordfish VHB Explorer folder? I think this comes with the later version of Swordfish when you run the ISIS plugin. There should be 4 design files available, I only have 3 with the current version here.
TIA
gem1144aaa
-Given: 134
-Receive: 27
« Reply #22 on: August 02, 2009, 09:25:00 21:25 »
TIA
hi cjeffries1
here a link for what you want but for the atmel.
youcan youse it or change microcontroller with the pic or what ever you want
http://en.pudn.com/downloads138/sourcecode/embed/detail593863_en.html
aamir
-Given: 37
-Receive: 229
« Reply #23 on: January 04, 2011, 06:20:05 06:20 »
Please reupload
gem1144aaa
-Given: 134
-Receive: 27
« Reply #24 on: January 09, 2011, 10:19:56 22:19 »
All credits go to Sahin2580 cause what i share now is really his
http://hotfile.com/dl/95577823/b9e0342/Swordfish.rar.html  (bad not working any more)
new link   http://hotfile.com/dl/133445946/0192691/Swordfish.rar.html
« Last Edit: October 27, 2011, 12:36:11 12:36 by gem1144aaa » Logged
Pages: [1] 2  All
