November 25, 2024, 01:46:17 01:46
Author Topic: Pic based waveform capturing and restoring  (Read 4481 times)
shibuv
« on: July 22, 2009, 01:16:04 13:16 »
hello
anybody can help me to find a project for storing and reproducing waveforms from a function generator using PIC16f877A.
shibuv
myblog
http://shibuvarkala.blogspot.com
Digibob
-Given: 71
if i go to hell,i want to go with my bench
« Reply #1 on: July 22, 2009, 03:25:30 15:25 »
i don't know if this can help you ,i made project with AD9833 from Analog Devices,This  component Can Generate Sine,Square,Triangle up to 10 MHZ (20 i think).
I made it with Pic877 and programmed in basic(Test Board).i can upload pcd,.bas etc if you need. i don't have any schematic,i've build this on the fly.
« Last Edit: July 22, 2009, 03:30:09 15:30 by Digibob » Logged
-Given: 405
-Receive: 545
« Reply #2 on: July 22, 2009, 03:32:36 15:32 »
I would check out some old issues of EPE where they did some pc scopes and Function generators cause they used an 877 and they had store the wave before showing it on the pc if I remember right.
Don't remember the exact issue's but try this link
http://www.epemag3.com/index.php?option=com_content&task=view&id=60&Itemid=53
Alexandra
« Reply #3 on: August 19, 2009, 06:57:27 18:57 »
Hi Digibob,
Please can you unload your code?
Digibob
-Given: 71
« Reply #4 on: August 19, 2009, 09:30:23 21:30 »
No Problem,Proton Basic code And Major Part Of Code was Copied From Other Site.it's for use with AD9833
