March 14, 2025, 08:01:45 20:01
Author Topic: AllPic programmer  (Read 7519 times)
Groovy
-Receive: 25
« on: December 22, 2006, 12:20:14 00:20 »
This is a serbian Microchip programmer. It work nice with 8,18,28 i 40 pin package and with eeprom series 24cXX. It could program new series of pic-s with build-in internal oscillator like 12f6XX ,16F62X,...
**Led1** indicate power supply voltage and it should be about 14-16V
**Led2** indicate Vdd +5v voltage on chip
**JP1** If JP1 is connected vdd +5v voltage is constantly 5V and Led2 indicate that.This mod is for all mcrochips who does not have internal oscillator like 16F84, 16F87x and also for eeproms.
 For new mcu JP1 should be unconnected and in that mod vdd +5v voltage appears after turning 13V programming voltage on programming start.
(16F627,16F628,12F629,12F675...)
**JP2** Is for turning on write protect mod and for eeproms 24cXX
**con1** external connector for in-circuit programming
Programmer could not program 16c5x sseries and some others specific microchips mcu.
http://digilander.libero.it/ddanijel/allpic/allpic.zip
« Last Edit: December 22, 2006, 12:22:27 00:22 by Groovy » Logged
Many free eBooks about electronics
http://electronic-ebooks.blogspot.com/
shaiqbashir
-Given: 16
Instrumentation..My Extreme Passion
« Reply #1 on: December 22, 2006, 05:14:33 05:14 »
can u tell me which software we should use in order to operate this programmer?
Rego
-Receive: 320
The power is back
« Reply #2 on: December 22, 2006, 08:04:40 08:04 »
u can use icprog
Smiley ....THE POWER IS BACK.... Smiley
....REGO....
shaiqbashir
-Given: 16
« Reply #3 on: December 22, 2006, 10:38:02 10:38 »
thanks rego for ur help!
but ICPROG supports many programmer types. WHich type this ALLPIC Programmer belong to?
I mean i need to setup the hardware settings in the IC Prog. So which setting should i use for this programmer?
Thanks in advance!
Groovy
-Receive: 25
« Reply #4 on: December 22, 2006, 10:48:29 10:48 »
Use The JDM Programmer settings
viji
« Reply #5 on: December 30, 2006, 01:23:23 01:23 »
SIMPLE AND EFFECTIVE PROGRAMMER
THANKS
Groovy
-Receive: 25
« Reply #6 on: December 30, 2006, 09:40:16 21:40 »
exactly
GroinkGroink
« Reply #7 on: January 11, 2007, 05:21:19 17:21 »
Works also fine with Winpic800.
I had been able to program PIC 18F2550. ICprog does not have it available in the programming list.
GroinkGroink
