January 10, 2025, 03:37:17 03:37
Author Topic: help to learning C and guidances for PIC  (Read 7724 times)
iphone
-Given: 115
« on: June 20, 2009, 01:42:03 13:42 »
hi guys,
Need your helps and guidance on how to start programming in C for PIC.
As I study through out of the forum, I decide to study Hitech C , C18 and C30.
So my plan is to study Hitech C for PIC16 as microchip dont have any C16 for PIC16. For PIC18, I will study on C18 (maybe Hitech for PIC18 also but an option) and for PIC24 & dsPIC33, I will use C30.
So for C18 & C30, there are 'how to get started' guide from microchip and as for now, I'm good and smooth in that path.
But the problem is on hitech C for PIC 16, I'm confuse which installation will do for PIC16 and how to integrate with MPLAB IDE. Ok can somebody point me step by step on how solve below question:
1. Which package of hitech C should I install that support PIC16 (if also install for PIC18,PIC24,dsPIC33, it will a bonus. Any explanation appreciated  very much) ?
2. How to integrate the hitech C with MPLAB IDE (I already install MPLAB 8.33) ?
3. How about hitech C IDE ? Is it good to install also ? what's pro and contra ?
BTW, I know in ANSI C in PC using borland (long time ago) but none in uC such as PIC.
Thanks in advance.
ajak
-Given: 199
-Receive: 77
« Reply #1 on: June 20, 2009, 04:54:43 16:54 »
i think this is the answer to your questions... this is the software you will need..
http://www.sonsivri.com/forum/index.php?topic=935.0
iphone
-Given: 115
« Reply #2 on: June 21, 2009, 06:06:52 18:06 »
I know this thread but my question which one I should intall and how to integrate with MPLAB etc.
 Maybe my english is hard to understand. Sory english is not mother's thunk.
ajak
-Given: 199
-Receive: 77
« Reply #3 on: June 21, 2009, 07:04:28 19:04 »
base from question number 1, use HI-TECH Enterprise Edition
read this to enlighten you..
http://htsoft.com/products/compilers/htee-microchip.php
here also.. download and watch this..
http://techtrain.microchip.com/webseminars/ArchivedDetail.aspx?Active=193
number 2 question: >> http://htsoft.com/support/faqs.php#faq60
help yourself do something to achieve something.. Smiley
iphone
-Given: 115
« Reply #4 on: June 21, 2009, 07:11:39 19:11 »
Yes that what I want to do but sometime different people with different scale and need some help in order to start somewhere. thanks
pirvcb
-Given: 147
-Receive: 245
« Reply #5 on: June 22, 2009, 11:44:50 23:44 »
Hi iphone,
take a look at section 4 in this book.... http://rapidshare.com/files/246108232/123_PIC_Microcontroller__the_Evil_Genius.rar
and this also seems not so bad...
http://rapidshare.com/files/64852511/2527618E-9D98-4396-BD50-394D3A14326D.rar
at moment i have no time to go in deep about C.
Let me know...
Later.
sohel
-Given: 167
-Receive: 149
« Reply #6 on: June 23, 2009, 09:09:47 09:09 »
password protected?
robban
-Given: 34
-Receive: 38
Warrior
« Reply #7 on: June 25, 2009, 02:10:47 14:10 »
Hi!
As You say, You're not familiar with C regarding PIC. My suggestion is that You don't use HI-TECH C as a starting point.
They have a tendency to use C as a extension to asm with all it's difficulties regarding readabilility and other quirks. Use CCS instead(found elsewhere in this forum with a lot of readymade libs).
Personally I use asm for PIC; more readability and instructive(check out Microchip for their application notes), but when it comes to structures it's obviously easier to use C.
BTW, which version of Borland C do You use? I love the old ones with DOS inteface. Regarding intergrating HI-TECH compilers and MPLAB IDE, don't forget from MPLAB IDE(project> set language tool location) to point to your installation of HI-TECH, libraries, includes and other pertinent sources.
Good luck...  Smiley
« Last Edit: June 25, 2009, 02:28:51 14:28 by robban » Logged
Code Warrior
joker12
-Receive: 80
« Reply #8 on: June 28, 2009, 01:10:18 01:10 »
I would; imho , use CCS or Mikcroelectronik C to start with. They can be found by doing a search on this board.
Second, read ,read, & read. There are many beginner C books available here on this site. Again do a search.
Third, Use the examples and experiment.
If you have not done any C programming, maybe start with PIC Basic, it's less structured.
Good luck
« Last Edit: June 28, 2009, 01:12:41 01:12 by joker12 » Logged
robban
-Given: 34
-Receive: 38
Warrior
« Reply #9 on: July 01, 2009, 08:31:02 20:31 »
Good luck
I agree - C is more complicated - but surely more structured...
Code Warrior
pirvcb
-Given: 147
-Receive: 245
« Reply #10 on: July 01, 2009, 11:51:50 23:51 »
password protected?
Sorry, i've later seen it here at sonsivri microcontroller ebooks board:
http://rapidshare.com/files/123387919/PIC_C.rar.html
pass: mbandala
Later
« Last Edit: July 02, 2009, 12:29:25 00:29 by pirvcb » Logged
pirvcb
-Given: 147
-Receive: 245
« Reply #11 on: July 04, 2009, 04:08:00 04:08 »
Have a look to this resource.
http://ifile.it/oy2z7ut
Pass in the attachment.
Later.
A small thank for my little work would be nice.
« Last Edit: July 09, 2009, 05:52:32 17:52 by pirvcb » Logged
qolpa
-Given: 19
« Reply #12 on: July 09, 2009, 07:21:21 07:21 »
http://rapidshare.com/files/251688256/pdf.zip.html
Later.
 Huh
Quote from: rapidshare
Error
This file is neither allocated to a Premium Account, or a Collector's Account, and can therefore only be downloaded 10 times.
This limit is reached.
To download this file, the uploader either needs to transfer this file into his/her Collector's Account, or upload the file again. The file can later be moved to a Collector's Account. The uploader just needs to click the delete link of the file to get further information.
when everthing else fails, read the instructions
pirvcb
-Given: 147
-Receive: 245
« Reply #13 on: July 09, 2009, 10:07:22 10:07 »
 Huh
Can i guess this is the only way for you to ask to reupload?
anaKu
-Given: 22
-Receive: 21
« Reply #14 on: July 11, 2009, 02:00:23 14:00 »
Both links:
and
are dead.
Could you please reload?
Thanks.
pirvcb
-Given: 147
-Receive: 245
« Reply #15 on: July 11, 2009, 10:07:31 22:07 »
New rapidshare link:
http://rapidshare.com/files/254708789/pdf.zip
The ifile link is down due a crash of ifile system.
Advice says that will be back working in little time.
