SFx
-Given: 65
-Receive: 235
« Reply #250 on: April 29, 2010, 04:44:57 16:44 » |
localcrack
-Receive: 21
« Reply #251 on: May 01, 2010, 07:30:59 07:30 » |
I requires following links http://en.pudn.com/dl.asp?id=469661Describe: Week Ligong ARM9 2410 test platform uCOS-II based on the experimental code, including uCOS-II transplantation experiments, buzzer experiments, serial communication experiment, graphic LCD control experiments and Modbus RTU master and slave communication experiment, FTP, GPRS, GPS, IrDA such as testing, processor s3c2410. easy-to-read code, comments in detail, recommended download. http://en.pudn.com/dl.asp?id=253896Describe: with MCU GPRS modem communications program and realized the ppp dial-up, tcp/udp communications Agreement contains the serial control protocol http://en.pudn.com/dl.asp?id=229689Describe: infrared remote control MCU most complete information, including many current television remote control decoder ASIC, C and Assembly Language prepared by the example of decoding procedures will be watching you!
aamir
-Given: 37
-Receive: 229
« Reply #252 on: May 06, 2010, 08:48:18 08:48 » |
need following book contains 8051 and arm simulation in proteus it is in chines but contains much information PROTEUS in the MCS-51 & ARM7 system of 100 cases" , this book is a pdf format. (2010-01-01, Asm, 37389KB, Downloads 4) http://en.pudn.com/downloads218/sourcecode/embed/detail1025587_en.html
deveshsamaiya
-Given: 15
« Reply #253 on: May 10, 2010, 08:12:21 08:12 » |
hi i need these code please download it... http://en.pudn.com/dl.asp?id=430761 // this is the code for mp3 decoder using avr
embedded@iit
DreamCat
-Given: 223
-Receive: 116
« Reply #255 on: May 13, 2010, 02:38:28 14:38 » |
download link for these two file on EASYSHARE http://www.easy-share.com/1910213422/uClinux-CAN-BUS-Driver.rarMD5: 8FBE36F4A62100A794BA3ADE9C86CC69 http://www.easy-share.com/1910213423/uClinux_CAN_Driver.rarMD5: 4435C411332F9BD33A475A69A5C36849 Posted on: May 13, 2010, 02:49:59 14:49 - Automerged
I requires following links http://en.pudn.com/dl.asp?id=469661Describe: Week Ligong ARM9 2410 test platform uCOS-II based on the experimental code, including uCOS-II transplantation experiments, buzzer experiments, serial communication experiment, graphic LCD control experiments and Modbus RTU master and slave communication experiment, FTP, GPRS, GPS, IrDA such as testing, processor s3c2410. easy-to-read code, comments in detail, recommended download. http://en.pudn.com/dl.asp?id=253896Describe: with MCU GPRS modem communications program and realized the ppp dial-up, tcp/udp communications Agreement contains the serial control protocol http://en.pudn.com/dl.asp?id=229689Describe: infrared remote control MCU most complete information, including many current television remote control decoder ASIC, C and Assembly Language prepared by the example of decoding procedures will be watching you! http://www.easy-share.com/1910213468/hongwaigooog.rarMD5: 33D2BFCC97B574EF77D0EFB6B9266589 http://www.easy-share.com/1910213469/8051_pppsrc.zipMD5: 78DF1A4A8BEE7D128C42FAF399C520F1 http://www.easy-share.com/1910213514/uCOS-II--daima.rarMD5: B60B94EF21577597C7DDA82D02FA5A5A Posted on: May 13, 2010, 03:02:36 15:02 - Automerged http://www.easy-share.com/1910213536/sd+vs1003+avr.rarMD5: E91AE2805F45A62885EB698FD885C99D Posted on: May 13, 2010, 03:04:50 15:04 - Automerged http://www.easy-share.com/1910213849/PROTEUS.rarMD5: C55588B47700F0C7867122DED38600A0
cicos
-Given: 133
-Receive: 237
« Reply #256 on: May 14, 2010, 03:53:09 03:53 » |
SFx
-Given: 65
-Receive: 235
« Reply #257 on: May 14, 2010, 06:09:30 06:09 » |
-Given: 841
-Receive: 4366
« Reply #258 on: May 14, 2010, 10:19:06 10:19 » |
Rule is Simple You limit request to 3, Acting like Oliver, asking for more, Gets you a 3 day Mute, Read the rules
« Last Edit: May 14, 2010, 10:21:16 10:21 by pickit2 »
riteshjain_82
-Given: 31
-Receive: 33
« Reply #259 on: May 21, 2010, 05:51:09 17:51 » |
localcrack
-Receive: 21
« Reply #260 on: May 29, 2010, 03:38:10 15:38 » |
Please req. following links http://en.pudn.com/dl.asp?id=580917Describe: Infrared Remote Control Proteus simulation, modeled on the infrared principle, the use of Proteus simulation, it should be noted that there is no infrared Proteus simulation components http://en.pudn.com/dl.asp?id=592274Describe: Automotive Integrated Monitor- Guangdong Province Undergraduate Electronic Design Contest works (won the first prize) The use of technology: ARM9 (S3C2440), UC/OS, UC/GUI, infrared gun, ultrasonic ranging, touch screen, voice playback main functions : through the sensor to collect external information, (road detection, speed, smooth, the chassis height, the degree of spin) and then collected the necessary external information analysis and processing, and finally by the implementation of the implementation of the output command unit (voice, TFT LCD screen), so that a smooth running car, increasing riding comfort. http://en.pudn.com/dl.asp?id=603619Describe: The work on the placement machine are very useful, you can look at to assess the look, this article
SFx
-Given: 65
-Receive: 235
« Reply #261 on: May 29, 2010, 04:54:17 16:54 » |
http://ifile.it/h5bj8ic/1520819%25BA%25EC%25CD%25E2%C3%8C%C2%BD%25B2%25E2%C3%8A%C2%B5%25D1%25E9.rarhttp://ifile.it/naojf1m/283390073IR_DECODE.rarhttp://ifile.it/8lb3rcd/385375549pin.rarPlease req. following links http://en.pudn.com/dl.asp?id=580917Describe: Infrared Remote Control Proteus simulation, modeled on the infrared principle, the use of Proteus simulation, it should be noted that there is no infrared Proteus simulation components http://en.pudn.com/dl.asp?id=592274Describe: Automotive Integrated Monitor- Guangdong Province Undergraduate Electronic Design Contest works (won the first prize) The use of technology: ARM9 (S3C2440), UC/OS, UC/GUI, infrared gun, ultrasonic ranging, touch screen, voice playback main functions : through the sensor to collect external information, (road detection, speed, smooth, the chassis height, the degree of spin) and then collected the necessary external information analysis and processing, and finally by the implementation of the implementation of the output command unit (voice, TFT LCD screen), so that a smooth running car, increasing riding comfort. http://en.pudn.com/dl.asp?id=603619Describe: The work on the placement machine are very useful, you can look at to assess the look, this article http://ifile.it/i9b2dcq/41191286691.rarhttp://ifile.it/xr2cd3b/549636965Embedded_arm_smart_car.rarhttp://ifile.it/7ov9j1i/697288442smt.rar
localcrack
-Receive: 21
« Reply #262 on: June 02, 2010, 04:52:14 16:52 » |
I needs followings http://en.pudn.com/dl.asp?id=507852Describe: Automatic placement machine PC control procedures, including the next-bit machine communications, visual processing, such as part of http://en.pudn.com/dl.asp?id=815351Describe: TQ2440 linux QT Application Development Manual (exclusive inlay production days)--- LINUX-new graphical interface development, QT complete the application, open source code for all applications, supporting the development of detailed guidelines for the production of quality learning sky/tq2440 user development Course details are: http://www.embedsky.net/infoDis.php?id=3 based on TQ2440 linux QT Application Development Manual (exclusive inlay production days) Release Date :2009-06-16-based applications TQ2440 linux QT Development Manual (exclusive inlay production days), includes all source code, image, development of detailed process manuals, step-by-step guide you into the magical images of embedded Linux GUI interface.
SFx
-Given: 65
-Receive: 235
« Reply #263 on: June 02, 2010, 06:48:25 18:48 » |
I needs followings http://en.pudn.com/dl.asp?id=507852Describe: Automatic placement machine PC control procedures, including the next-bit machine communications, visual processing, such as part of http://en.pudn.com/dl.asp?id=815351Describe: TQ2440 linux QT Application Development Manual (exclusive inlay production days)--- LINUX-new graphical interface development, QT complete the application, open source code for all applications, supporting the development of detailed guidelines for the production of quality learning sky/tq2440 user development Course details are: http://www.embedsky.net/infoDis.php?id=3 based on TQ2440 linux QT Application Development Manual (exclusive inlay production days) Release Date :2009-06-16-based applications TQ2440 linux QT Development Manual (exclusive inlay production days), includes all source code, image, development of detailed process manuals, step-by-step guide you into the magical images of embedded Linux GUI interface. http://ifile.it/h1t4qvf/185375567AutoMount%28NoNozzleChange%29.rarhttp://ifile.it/9enh3rs/279419131QTdeveloponlyfortq2440embedsky.rar
localcrack
-Receive: 21
« Reply #264 on: June 03, 2010, 07:48:49 07:48 » |
I requires following one http://en.pudn.com/dl.asp?id=324487Describe: A uC/OS+ GUI-driven 98x67 LCD routine use of the Keil MDK compiler works, uCOS-II for V2.52 version, GUI for ZLG the V1.0 version, LCD using NOKIA 3510I of the LCD module, the module on controller models for Epson S1D15G14. http://en.pudn.com/dl.asp?id=388645Describe: Hybrid stepping motor driver microstep SPWM technology, hybrid stepping motor driver microstep SPWM technology. http://en.pudn.com/dl.asp?id=381402Describe: Inverter 16F73 MCU C source code, with recharge, municipal electric inverter switching, over-temperature protection with overload!
SFx
-Given: 65
-Receive: 235
« Reply #265 on: June 04, 2010, 11:14:23 11:14 » |
I requires following one http://en.pudn.com/dl.asp?id=324487Describe: A uC/OS+ GUI-driven 98x67 LCD routine use of the Keil MDK compiler works, uCOS-II for V2.52 version, GUI for ZLG the V1.0 version, LCD using NOKIA 3510I of the LCD module, the module on controller models for Epson S1D15G14. http://en.pudn.com/dl.asp?id=388645Describe: Hybrid stepping motor driver microstep SPWM technology, hybrid stepping motor driver microstep SPWM technology. http://en.pudn.com/dl.asp?id=381402Describe: Inverter 16F73 MCU C source code, with recharge, municipal electric inverter switching, over-temperature protection with overload! http://ifile.it/ylfsj73/189346505uCGUI_LPC214x_For_Keil.rarhttp://ifile.it/4xl2a5o/2972883944.rarhttp://ifile.it/md9npzw/321840269pic16f73.rar
sa_mo33958
-Given: 45
-Receive: 42
« Reply #267 on: June 05, 2010, 07:10:44 07:10 » |
firegun
-Receive: 14
« Reply #270 on: June 11, 2010, 07:22:33 07:22 » |
riteshjain_82
-Given: 31
-Receive: 33
« Reply #271 on: June 14, 2010, 07:02:19 07:02 » |
mtech84
-Given: 19
« Reply #272 on: June 18, 2010, 02:29:20 02:29 » |
hello i need this http://en.pudn.com/dl.asp?id=10246 can u please upload to itfile site... thx alot...
localcrack
-Receive: 21
« Reply #273 on: June 21, 2010, 05:39:35 17:39 » |
I needs following files http://en.pudn.com/dl.asp?id=359655Describe: CC1000 Rf modem C codes for philips sLpc213X ARM MCU. http://en.pudn.com/dl.asp?id=359796Describe: CC2500 acceptance, sending packets of the library function modules can be directly in the project file to add halregssrf.h header files, by calling the relevant documents can be. Test. http://en.pudn.com/dl.asp?id=77612Describe: AVR MEGA8 CC1000 write C code is very useful information
