November 24, 2024, 09:52:08 21:52
Author Topic: need LCD (2 by 16) sample program in keil in C  (Read 5786 times)
glenndr_15
-Given: 20
-Receive: 72
« on: June 14, 2009, 12:08:47 00:08 »
Greetings!
I tried to program the LCD sample n the book of mazidi, but it's not working. can someone share a program for LCD 2 by 16 written in C using keil for 8051?
best regards,
glenndr_15
« Last Edit: June 14, 2009, 12:41:23 00:41 by glenndr_15 » Logged
nambinh
-Given: 24
« Reply #1 on: June 14, 2009, 12:51:45 00:51 »
#ifndef __LCD_H__
#define __LCD_H__
void lcd_init(void);
void delay();
void control_word(unsigned char ch);
void data_word(unsigned char ch);
void wrt_value(unsigned char x);
void cursorxy(unsigned char x, unsigned char y);
void disp_str(unsigned char msg[]);
void wrt_string(unsigned char *string);
void wrt_long(unsigned long a);
void wrt_char(unsigned char a);
void wrt_int(unsigned int a);
void wrt_dec_char(unsigned char x);
void wrt_dec_long(unsigned long a);
void wrt_dec_int(unsigned int a);
void wrt_2dec_place(unsigned char a);
void wrt_float(float a);
#endif
#include <reg51.h>
#define LCD P2 // lcd connected to this port
void delay()
unsigned char i;
for (i=0; i<255 ;i++);
unsigned char copy;
copy  = ch; //save a copy of it
ch = ch >> 4; //get the higher nibble
ch = ch & 0x0f; // -- do --
ch = ch | 0x20; // add E(bit 6) &  RS (bit 5)
LCD = ch; //out to lcd data port HIGHER nibble with E=1, RS=0
ch = ch & 0x0f; // make E=0, RS=0 with higher nibble
LCD = ch; //out to lcd data port higher nibble with E=0, RS=0
ch = copy; //get original byte
ch = ch & 0x0f; //to get lower nibble
ch = ch | 0x20; // E=1, RS=0
LCD = ch; //out to lcd data port LOWER nibble with E=1, RS=0
LCD = ch; //out to lcd data port lower nibble with E=0, RS=0
delay(); // give some delay here
unsigned char copy;
ch = ch | 0x30; // add E(bit 6) &  RS (bit 5)
LCD = ch; //out to lcd data port HIGHER nibble with E=1, RS=1
ch = ch & 0x1f; // make E=0, RS=1 with higher nibble
LCD = ch; //out to lcd data port higher nibble with E=0, RS=1
ch = ch | 0x30; // E=1, RS=1
LCD = ch; //out to lcd data port LOWER nibble with E=1, RS=1
LCD = ch; //out to lcd data port lower nibble with E=0, RS=1
void lcd_init(void)
control_word(0x28);// 4bit, 2lines, 5x7
control_word(0x28);// again
control_word(0x0E);// disp On, cursor On, no blink
control_word(0x01);// clear LCD
control_word(0x06);// CUR_RIGHT
control_word(0x80);// line 1 cur. position 0
unsigned char i;
while(msg[i] != '\0')
data_word(msg[i++]);
Bringing Cursor to (X,Y) location of LCD
X -> 1,2
Y -> 1,16
if((x<1||x>2)&&(y<1||y>16))
x=1;
y=1;
if(x == 1)
control_word(0x7F+y);
else
control_word(0xBF+y);
unsigned char temp;
temp = x/0x10;
if(temp>9)
return;
else
data_word(temp+0x30);
temp = x%0x10;
if(temp>9)
return;
else
Writing string to LCD
delay();
while(*string)
data_word(*string++);
unsigned char i;
unsigned char b,c[8]={48,48,48,48,48,48,48,48};
for(i = 7;a > 0;i--)
b = a % 16;
if(b <= 9)
b = b + 48;
else
b = b + 55;
a =  a / 16;
c[i] = b;
for(i =0; i<=7;i++)
data_word(c[i]);
unsigned char i;
unsigned char b,c[4]={48,48,48,48};
for(i = 3;a > 0;i--)
b = a % 16;
if(b <= 9)
b = b + 48;
else
b = b + 55;
a =  a / 16;
c[i] = b;
for(i =0; i<=3;i++)
data_word(c[i]);
void wrt_char(unsigned char x)
unsigned char temp;
temp = x/0x10;
if(temp>9)
data_word(temp+55);
else
data_word(temp+48);
temp = x%0x10;
if(temp>9)
data_word(temp+55);
else
data_word(temp+48);
void wrt_dec_char(unsigned char a)
unsigned char i;
unsigned char b,c[3]={48,48,48};
for(i = 2;a > 0;i--)
b = a % 10;
b = b + 48;
a =  a / 10;
c[i] = b;
for(i =0; i<=2;i++)
data_word(c[i]);
unsigned char i;
unsigned char b,c[10]={48,48,48,48,48,48,48,48,48,48};
for(i = 9;a > 0;i--)
b = a % 10;
b = b + 48;
a =  a / 10;
c[i] = b;
for(i =0; i<=9;i++)
data_word(c[i]);
unsigned char i;
unsigned char b,c[5]={48,48,48,48,48};
for(i = 4;a > 0;i--)
b = a % 10;
b = b + 48;
a =  a / 10;
c[i] = b;
for(i =0; i<=4;i++)
data_word(c[i]);
/* function to write the fractional part after decimal upto
two decimal places
INPUT : the decimal part as unsigned char */
unsigned char i;
unsigned char b,c[2]={48,48};
for(i = 1;a > 0;i--)
b = a % 10;
b = b + 48;
a =  a / 10;
c[i] = b;
for(i =0; i<=1;i++)
data_word(c[i]);
/* function to write the floating point number upto
two decimal places
INPUT : floating point number
OUTPUT : xxxxx.yy   on lcd at current cursor position */
unsigned int i;
unsigned char j;
i = (unsigned int)a;
wrt_dec_int(i);
wrt_string(".");
j = (unsigned char)((a - i) * 100);
wrt_2dec_place(j);
USE THE INSERT CODE BUTTON WHEN UPLOADING CODE
« Last Edit: June 18, 2009, 03:40:28 03:40 by bbarney » Logged
tsk_cable
« Reply #2 on: June 17, 2009, 08:51:30 20:51 »
Hi i'm kinda new here but this is my code for 16x2 Lcd
It was made with Keil uVision, Enjoy
#include <REGX52.H>
#define LCD_data P2
#define LCD_rs P1_0
#define LCD_rw P1_1
#define LCD_en P1_2
void LCD_busy(void);
void LCD_poweron(void);
void LCD_command(unsigned char var);
void LCD_senddata(unsigned char var);
void LCD_sendstring(unsigned char *var);
void LCD_init(void);
void main(void)
        unsigned char msg[] ="Learning";
        LCD_poweron();    // 15ms delay
                LCD_init();
                LCD_command (0x80);     // Set CGRAM adress,data is Avaible from uC
        LCD_sendstring(msg);
                while(1);
void LCD_busy()
    unsigned char i,j;
        for(i=0;i<50;i++)
                for(j=0;j<255;j++);
void LCD_poweron()
unsigned int i;
for (i=0;i<22500; i++);
     LCD_data  = var;      //Function set: 2 Line, 8-bit, 5x8 dots
     LCD_rs   = 0;        //Selected command register
     LCD_rw   = 0;        //We are writing in instruction register
     LCD_en   = 1;        //Enable H->L
     LCD_en   = 0;
     LCD_busy();          //Wait for LCD to process the command
     while(*var)              //till string ends
       LCD_senddata(*var++);  //send characters one by one
     P2  = var;      //Function set: 2 Line, 8-bit, 5x7 dots
     LCD_rs   = 1;        //Selected data register
     LCD_en   = 0;
void LCD_init(void)
     LCD_data = 0x38;     //Function set: 2 Line, 8-bit, 5x8 dots
     LCD_rw   = 0;        //We are writing in data register
     LCD_en   = 0;
     LCD_data  = 0x0F;     //Display on, Curson blinking command
     LCD_en   = 0;
     LCD_data  = 0x01;     //Clear LCD
     LCD_en   = 0;
     LCD_data  = 0x06;     //Entry mode, auto increment with no shift
         LCD_en   = 0;        //Enable H->L
     LCD_busy();
deveshsamaiya
-Given: 15
« Reply #3 on: August 18, 2009, 03:09:32 15:09 »
// LCD header file with standard functions to drive 16*2 alphanumeric LCD
#define LCDPORT P2
#define RS P2_0
#define RW P2_1
#define E  P2_2
bit  status=0
#define lcd_delay 60
void delay(unsigned int j)
unsigned int i,k;
for(i=0;i<j;i++)
for(k=0;k<100;k++);
void _lcd_init_write(unsigned char a)
RS = 0;
RW = 0;
LCDPORT=a;
E=1;
delay(lcd_delay);
E=0;
void lcd_com(unsigned char a){
unsigned char temp;
if(status){
status=0;
 goto a;
RS=0;
a:
RW=0;
temp=a;
temp&=0xF0;
LCDPORT&=0x0F;
LCDPORT|=temp;
E=1;
delay(lcd_delay);
E=0;
temp=a<<4;
temp&=0xF0;
LCDPORT&=0x0F;
LCDPORT|=temp;
E=1;
delay(lcd_delay);
E=0;
void lcd_data(unsigned char a){
status=1;
RS=1;
lcd_com(a);
void lcd_init(void){
delay(lcd_delay);
_lcd_init_write(0x30);
delay(lcd_delay);
delay(lcd_delay);
delay(lcd_delay);
_lcd_init_write(0x20);
delay(lcd_delay);
lcd_com(0x28);
delay(lcd_delay);
lcd_com(4);
delay(lcd_delay);
lcd_com(0x85);
delay(lcd_delay);
lcd_com(6);
delay(lcd_delay);
lcd_com(1);
delay(lcd_delay);
void lcd_puts(char *aaa)
unsigned int i=0;
for(;aaa[i]!=0;i++)lcd_data(aaa[i]);
embedded@iit
