April 30, 2025, 09:01:28 09:01
Author Topic: my winpic800  (Read 10982 times)
-Given: 562
« on: November 09, 2005, 11:54:44 23:54 »
here you are boys this is my version of the gtp usb plus single sided pcb
PCB 1. ZIF/ISCP socket
PCB 2 . main board
i used a case an cut hole for zif socket and it connects to main pcb via connector plugs
Fully tested and working
Now i dont have the hex file for PIC. sorry boys
wizpic
batbatdieu
« Reply #1 on: November 11, 2005, 09:27:46 09:27 »
Hex file , please !!!
LazBoy
-Given: 78
-Receive: 25
« Reply #2 on: November 11, 2005, 02:29:54 14:29 »
The software has the hex files in archive, isn't it ?
-Given: 562
« Reply #3 on: November 11, 2005, 09:46:15 21:46 »
No the HEX file is no longer in the winpic folder I don't have HEX FILE so please stop asking for it I know this is the best palce to share and rip. but for 6 erous it's worth the money. it's the best programmer i have tried. I've tried Propic2 gold,PICall,picpro16,Epic,warp13 and found this usb programmer is better even the older version.
Dembo
« Reply #4 on: November 13, 2005, 10:10:48 10:10 »
Do You mean this files???
-Given: 405
-Receive: 545
« Reply #5 on: November 13, 2005, 05:24:44 17:24 »
great work Dembo
now how about sharing the fuse setting for the pic because that not loaded in the hex file?
« Reply #6 on: November 13, 2005, 05:33:00 17:33 »
Are these hex files for GTP-USB+ or the ones found in older versions of winpic800..
-Given: 562
« Reply #7 on: November 13, 2005, 05:55:38 17:55 »
I think those file are for old version has the is not a usb 232 version any more
wizpic
tasosstr
-Given: 95
-Receive: 14
« Reply #8 on: November 14, 2005, 04:03:33 16:03 »
Hello try this i don't remember when  i downloaded but  maybe help.
Best Regards,
Tasos
ang1960
-Given: 1348
-Receive: 333
« Reply #9 on: November 14, 2005, 04:08:47 16:08 »
It is older version.
-Given: 405
-Receive: 545
« Reply #10 on: November 14, 2005, 06:16:47 18:16 »
no fuse setting in that one either
TCU
« Reply #11 on: November 15, 2005, 07:18:07 07:18 »
Hex file for GTP USB Plus = 6Euro. use for GTP USB Plus only.
but GTP USB Summer 2005 free --> Hardware & Hex
OK?
-Given: 405
-Receive: 545
« Reply #12 on: November 15, 2005, 07:21:25 19:21 »
free or not you still need the fuse settings to load the hex file and i can't seem to find them :confused:
-Given: 562
« Reply #13 on: November 15, 2005, 09:16:29 21:16 »
I had no problem when i built the old one i tried the EPIC and the warp13a with no problems i did not alter teh fuse settings.
-Given: 405
-Receive: 545
« Reply #14 on: November 18, 2005, 06:19:19 18:19 »
using winpicprog and a 16pro40 the fuses don't load.so I started winpic800 and loaded the hex file and the fuses seem to be set.so I need to know what setting to setup in winpic800 to use my 16pro40 programmer with it to program the chip.
anyone using a 16pro40 with winpic800 ? so i can program this chip and use Wizpic's board.
Nice board Wizpic,hoping to be using it soon
