November 27, 2024, 01:06:35 13:06
Author Topic: Need AT command Help  (Read 4339 times)
falcon _bd
-Given: 66
-Receive: 117
falconbd.com
« on: June 12, 2009, 05:30:52 17:30 »
I need AT command help for Sim toolkit. I am using sim300c gsm module.
For Browse the or select the sim menu I need the Details command set or reference link.
Thanks in Advance.
poweralgorithm
« Reply #1 on: June 13, 2009, 12:38:44 00:38 »
http://rapidshare.com/files/243901372/sim300c_atc.pdf.html
falcon _bd
-Given: 66
-Receive: 117
falconbd.com
« Reply #2 on: June 13, 2009, 09:08:32 09:08 »
Sim tool kit.  Page (126 - 151).
I have read this doc.
But I need some clear explanation with example.
-Given: 834
-Receive: 4322
« Reply #3 on: June 13, 2009, 11:38:06 11:38 »
Do have you a serial link to module.
if so at Terminal you send command ATI and module replies with
SIMCOM_Ltd
SIMCOM_SIM300C
Revision: 1008B09SIM300CM32_SPANSION
if you have a old serial modem (you don't need to connect to phone line) you connect it to your pc serial port and try using HyperTermial. and see responces you get back.
falcon _bd
-Given: 66
-Receive: 117
falconbd.com
« Reply #4 on: June 14, 2009, 04:55:01 16:55 »
I get these replay for ATI command
SIMCOM_Ltd
SIMCOM_SIM300C
Revision:1008B12SIM300C32_SPANSION
I can send, receive and delet the SMS through the AT command.
Really I need the AT command to browse and select the sim menu.
step by step.....
kelly
-Receive: 26
Embedded linux on ARM
« Reply #5 on: June 15, 2009, 07:43:17 07:43 »
The STK command is Proactive command,U refer to 3GPP TS 11.14 specification Smiley
« Last Edit: June 15, 2009, 07:56:27 07:56 by kelly » Logged
falcon _bd
-Given: 66
-Receive: 117
falconbd.com
« Reply #6 on: June 15, 2009, 10:48:03 10:48 »
Can you give me any doc or example for
CMGF=1  (text mode) Operatin
kelly
-Receive: 26
« Reply #7 on: June 16, 2009, 03:13:51 03:13 »
A example about text mode for u:
AT
OK
AT+CMGF=1
OK
AT+CMGW="+85291234567"
> A simple demo of SMS text messaging.
+CMGW: 1
OK
AT+CMSS=1
+CMSS: 20
OK
Here is a description of what is done in the above example:
    + Line 1: "AT" is sent to the GSM / GPRS modem to test the connection. The GSM / GPRS modem sends back the result code "OK" (line 2), which means the connection between the HyperTerminal program and the GSM / GPRS modem works fine.
    + Line 3: The AT command +CMGF is used to instruct the GSM / GPRS modem to operate in SMS text mode. The result code "OK" is returned (line 4), which indicates the command line "AT+CMGF=1" has been executed successfully. If the result code "ERROR" is returned, it is likely that the GSM / GPRS modem does not support the SMS text mode. To confirm, type "AT+CMGF=?" in the HyperTerminal program. If the response is "+CMGF: (0,1)" (0=PDU mode and 1=text mode), then SMS text mode is supported. If the response is "+CMGF: (0)", then SMS text mode is not supported.
    + Line 5 and 6: The AT command +CMGW is used to write an SMS text message to the message storage of the GSM / GPRS modem. "+85..." is the recipient mobile phone number. After typing the recipient mobile phone number, you should press the Enter button of the keyboard. The GSM / GPRS modem will then return a prompt "> " and you can start typing the SMS text message "A simple demo of SMS text messaging.". When finished, press Ctrl+z of the keyboard.
    + Line 7: "+CMGW: 1" tells us that the index assigned to the SMS text message is 1. It indicates the location of the SMS text message in the message storage.
    + Line 9: The result code "OK" indicates the execution of the AT command +CMGW is successful.
    + Line 10: The AT command +CMSS is used to send the SMS text message from the message storage of the GSM / GPRS modem. "1" is the index of the SMS text message obtained from line 7.
    + Line 11: "+CMSS: 20" tells us that the reference number assigned to the SMS text message is 20.
    + Line 13: The result code "OK" indicates the execution of the AT command +CMSS is successful.
falcon _bd
-Given: 66
-Receive: 117
falconbd.com
« Reply #8 on: June 16, 2009, 12:05:20 12:05 »
CMGF=1 (text mode)
CMGF=0 (hexmode)
This command also works for sim toolkit (STK).
I dont need help about simply sending, receiving, or deleting the SMS.
Anyway,thanks for your trying.
