December 24, 2024, 12:51:16 00:51
Author Topic: FAT/MMC library in CCS 4+ ?  (Read 8243 times)
krakatoa
-Given: 8
-Receive: 88
« on: December 12, 2006, 05:08:20 17:08 »
The CCS website (http://www.ccsinfo.com/content.php?page=v4compiler) mentions that the compiler also contains a FAT library .
Many new example programs and libraries
These are some of the new libraries and examples added to Version 4:
    * FAT - Access/read/write files on a SD/MMC card that has a FAT file system. Run a long term log on your PIC® MCU, saving each entry by appending to a file. Then read the results on your PC by opening the file.
Anyone got this library ? Please do share.
Tech girls rock!
neer4evr
« Reply #1 on: February 13, 2008, 02:26:24 14:26 »
MikroC also has FAT/MMC library and many other like
CAN Library
CANSPI Library
Compact Flash Library
EEPROM Library
Ethernet Library
SPI Ethernet Library
Flash Memory Library
Graphic LCD Library
T6963C Graphic LCD Library
I²C Library
Keypad Library
LCD Library
LCD Custom Library
LCD8 Library
Manchester Code Library
Multi Media Card Library
OneWire Library
PS/2 Library
PWM Library
RS-485 Library
Software I²C Library
Software SPI Library
Software UART Library
Sound Library
SPI Library
USART Library
USB HID Library
Util Library
SPI Graphic LCD Library
Port Expander Library
SPI LCD Library
SPI LCD8 Library
SPI T6963C Graphic LCD Library
wnmaximino
-Given: 47
-Receive: 202
Homer
« Reply #2 on: February 13, 2008, 04:48:53 16:48 »
The SD/MMC library from MikroC working very well...
mayler
Roger that!
« Reply #3 on: February 13, 2008, 05:27:37 17:27 »
I picked from CCS 4.065 these files, but i have since 4.049.   Smiley
Computer Engineer.
El_Guitre
« Reply #4 on: February 16, 2008, 11:25:39 23:25 »
la libreria para trabajar con SD/MMC de MicroC funciona a la perfeccion y se puede trabajar en fat16
