Hi all,
sorry for my english
I have 2 LCD screen 3.5" rescue from 2 videotelephony with the relative board interface (the controller is
PVI-1004C, this is the datasheet:
http://www.pwkj.cn/UploadFile/2005/4/15/200541516173290562.pdf ).
I want to know if it's possible to connect/interface this screen with a PIC or with the PC.
Thanks a lot
Just checked your datasheet . It is actually you have to build a driver to control your TFT . The datasheet provides pin nos and its details logic . Have a look at here
http://XXX.circuitcellar.com/AVR2004/grand.html (replace xxx with www) this might provide a starting point , I do not press on but mostly the TFTS use standard or almost the same controllers , with Hardware driven an others software typr ASIC glue . You would better be off with an RS232 interfaced one available in the market.
Ts
