December 28, 2024, 06:35:15 06:35
Author Topic: Hi-tech 18 SPI routine  (Read 4469 times)
piedos
« on: December 08, 2006, 05:19:08 17:19 »
I couldn't find SPI routine for picc18.
is it a buit in funtion, if not where can find it,
not: not present in microchipc.com
thanks in advance
robban
-Given: 34
-Receive: 38
Warrior
« Reply #1 on: December 09, 2006, 05:55:52 05:55 »
That's funny, I can't find it either. You have two options: Build your own or switch to Microchip MCC18
Then proceed as follows:
Start by building the run-time libraries with Makeall.bat in the src folder
Then look here:
root:\MCC18\src\extended\pmc\SPI  or:
root:\MCC18\src\traditional\pmc\SPI
If You're not content with that, try CCS compiler which can be found elsewhere on this forum
If You're porting to HI-TECH, let me know.
Happy programming....
« Last Edit: December 09, 2006, 06:59:46 06:59 by robban » Logged
Code Warrior
piedos
« Reply #2 on: December 14, 2006, 10:10:59 22:10 »
After I've written my SW SPI code I read your post Smiley
They are exactly same Smiley
