November 26, 2024, 10:32:21 10:32
Author Topic: Question about this file please?  (Read 3940 times)
eleckits
-Given: 36
« on: April 07, 2009, 11:18:21 11:18 »
I have this code but don't know how to compile it, because I don't know the name of the compiler that was written with, would you please give me the name of this compiler?
;Filename:  IRCLD501.SRC
DEVICE  PIC16F84,HS_OSC,WDT_OFF,PWRT_ON,PROTECT_OFF
ID      'IR51'
LEDDUTY         =       8       ;SETS NUMBER OF FAST LOOPS OUT OF 256 THAT LED
; GLOWS AS NIGHTLIGHT.
PULSEWIDTH      =       1       ;SETS NUMBER OF LOOPS WHICH TRIAC PULSE COVERS
BLINKWIDTHL     =       12      ;SETS NUMBER OF CYCLES WHICH LED BLINKS COVER
BLINKWIDTHS     =       1       ;SETS NUMBER OF CYCLES WHICH LED BLINKS COVER
ONOFFADR        =       0       ;SETS ADDRESS OF ONOFF COMMAND LOCATION IN MEM
BRITEADR        =       8       ;SETS ADDRESS OF BRITE COMMAND LOCATION IN MEM
DIMADR          =       16      ;SETS ADDRESS OF DIM   COMMAND LOCATION IN MEM
PHASEADR        =       63      ;SETS ADDRESS OF PHASE VALUE STORED IN MEM
LASTONADR       =       62      ;SETS ADDRESS OF LAST ON/OFF STATUS IN MEM
DEBOUNCE        =       20      ;SETS KEY DEBOUNCE TIME LENGTH
AUTOSAVE        =       100     ;SETS TIME TO WAIT AFTER COMPLETING DIM OR BRITE
; ACTIVITY TO AUTOSAVE PHASEANGLE
STOREMAXH       =       3       ;SETS MAX TIME TO WAIT FOR INCOMING CODE TO STORE
STOREMAXL       =       88      ;SETS MAX TIME TO WAIT FOR INCOMING CODE TO STORE
; TIME=(((STOREMAXH-1)*256)+STOREMAXL))/120
;RAMPRATEF       =       3       ;ALLOWS 1 TICK OF PHASEANGLE ADJUST PER
;                                ; COUNT OF RAMPRATEF HALFCYCLES.
;RAMPRATES       =       5       ;ALLOWS 1 TICK OF PHASEANGLE ADJUST PER
;                                ; COUNT OF RAMPRATES HALFCYCLES.
;RAMPTHRESHOLD   =       80      ;SETS PHASEANGLE LEVEL AT WHICH RAMPRATE CHANGES
OFF             =       184     ;CONSTANT FOR "LAMP OFF" PHASEANGLE
MINTURNON       =       150     ;SETS MIN BRIGHTNESS FOR TURN ON
MINHOLDTIME     =       21      ;SETS MIN PERIOD BETWEEN IR INPUTS TO OCCUR
; BEFORE DECODE REQUIRED AGAIN
BITWIDTH        =       24      ;24 LOOPS AT 24kHz = 1000us (1760>1000>680)
SPACEWIDTH      =       100     ;100 LOOPS AT 24kHz = 4166us (4166>3360)
; where 3360= actual space-bitwidth+normal space
;           = 3680-1000+680 =
ZDIN            =       RA.2
SERIN           =       RB.7
TRIAC           =       RB.2
SW1             =       RB.1
SW2             =       RB.4
SW3             =       RB.3
SW4             =       RB.5
LED             =       RB.6
BRITE           =               SW1
ONOFF           =               SW2
STORE           =               SW3
DIM             =               SW4
CLOCKOUT        =       RA.1    ;PUTS OUT CLOCK = 1/2 LOOP FREQ
TIMERVALUE      =       207     ;SETS TASK1 LOOP FREQ TO 12kHz;152=12000
;TIMERVALUE = 255 - ((XTAL/4) / (LOOPFREQ X PRESCALER))       ;208=24000
;           = 255 - (2500000 / (24000 X 2))
;           = 255 - 52.08333333
;           = 202.9166667  ;USING 203: ERROR=0.0410509%
;EEPROM INITIALIZATION
EEORG   PHASEADR
EEDATA  64H         ;initial turn-on value
EEORG   LASTONADR
EEDATA  0H
       ;CODES FOR RCA CABLE BOX
       ;(G.E.Universal remote set cable mode to RCA box "047")
EEORG   ONOFFADR
EEDATA  028H,073H,000H,000H,000H,000H,000H,000H
EEORG   BRITEADR
EEDATA  038H,073H,000H,000H,000H,000H,000H,000H
EEORG   DIMADR
EEDATA  018H,073H,000H,000H,000H,000H,000H,000H
;VARIABLE STORAGE
ORG     0CH     ;SET TO START OF GENERAL PURPOSE RAM
BITTIMER        DS      1       ;COUNTS LOOPS UNTIL TIME TO SAMPLE BIT
SPACETIMER      DS      1    ;USED TO SET LIMIT TO SPACES BETWEEN SERIAL BITS
BITCOUNTER      DS      1       ;USED TO COLLECT CORRECT NUMBER OF BITS
PHASEANGLE      DS      1       ;VALUE SETS THE PHASE ANGLE
PHASECOUNTER    DS      1       ;COUNTS LOOPS UNTIL = PHASE TO PULSE TRIAC
PULSECOUNTER    DS      1       ;USED TO END TRIAC PULSE BY COUNTING LOOPS
ZEROCOUNTER     DS      1       ;COUNTS ZERO DETECTIONS
BOUNCECOUNTER   DS      1       ;COUNTS ZERO DETECTIONS TO DEBOUNCE KEYS
RAMPCOUNTER     DS      1       ;COUNTS MULTIPLES OF ZERO DETECTIONS
; TO SET PHASE ANGLE RAMP RATE.
KEY1COUNTER     DS      1       ;DETECTS ACTION ON DIM & BRIGHT TO TRIGGER
; AUTOMATIC STORAGE OF LAST PHASEANGLE SET
BLINKCOUNTER    DS      1       ;COUNTS ZERO DETECTIONS TO CONTROL LED ONTIME
STORECOUNTERH   DS      1       ;USED TO LIMIT HOW LONG SYSTEM WAITS FOR
; A NEW IR CODE TO COME FOR STORAGE
STORECOUNTERL   DS      1       ;USED TO LIMIT HOW LONG SYSTEM WAITS FOR
ZDLOG           DS      1       ;USED TO RECORD PREVIOUS & PRESENT STATES OF ZDIN
SERINLOG        DS      1       ;USED TO RECORD PREVIOUS & PRESENT STATES OF SERIN
SERDATA0        DS      1       ;BYTE 0 OF 64-BIT SERIAL DATA WORD RECEIVED
SERDATA1        DS      1       ;BYTE 1 OF 64-BIT SERIAL DATA WORD RECEIVED
SERDATA2        DS      1       ;BYTE 2 OF 64-BIT SERIAL DATA WORD RECEIVED
SERDATA3        DS      1       ;BYTE 3 OF 64-BIT SERIAL DATA WORD RECEIVED
SERDATA4        DS      1       ;BYTE 4 OF 64-BIT SERIAL DATA WORD RECEIVED
SERDATA5        DS      1       ;BYTE 5 OF 64-BIT SERIAL DATA WORD RECEIVED
SERDATA6        DS      1       ;BYTE 6 OF 64-BIT SERIAL DATA WORD RECEIVED
SERDATA7        DS      1       ;BYTE 7 OF 64-BIT SERIAL DATA WORD RECEIVED
MEMDATA0        DS      1       ;BYTE 0 OF STORED 64-BIT DATA WORD
MEMDATA1        DS      1       ;BYTE 1 OF STORED 64-BIT DATA WORD
MEMDATA2        DS      1       ;BYTE 2 OF STORED 64-BIT DATA WORD
MEMDATA3        DS      1       ;BYTE 3 OF STORED 64-BIT DATA WORD
MEMDATA4        DS      1       ;BYTE 4 OF STORED 64-BIT DATA WORD
MEMDATA5        DS      1       ;BYTE 5 OF STORED 64-BIT DATA WORD
MEMDATA6        DS      1       ;BYTE 6 OF STORED 64-BIT DATA WORD
MEMDATA7        DS      1       ;BYTE 7 OF STORED 64-BIT DATA WORD
STATS           DS      1       ;USED TO STORE TEMPORARY PROGRAM STATISTICS
STOREHIT        =       STATS.0 ;IF=1 THEN STORE KEY WAS HIT
ONOFFHIT        =       STATS.1 ;IF=1 THEN ONOFF KEY WAS HIT
BRITEHIT        =       STATS.2 ;IF=1 THEN BRITE KEY WAS HIT
DIMHIT          =       STATS.3 ;IF=1 THEN DIM   KEY WAS HIT
BUFFERFULL      =       STATS.4 ;IF=1 THEN 64-BIT WORD IS WAITING TO BE DECODED
WORDSTART       =       STATS.5 ;IF=1 THEN START BIT EDGE DETECTED
KEYBOUNCE       =       STATS.6 ;IF=1 THEN KEY IS IN DEBOUNCE DELAY
ZEROHIT         =       STATS.7 ;IF=1 THEN ZEROPOINT WAS PASSED
STATS2          DS      1       ;USED TO STORE TEMPORARY PROGRAM STATISTICS
PULSESTART      =       STATS2.0;SAYS THE TRIAC TRIGGER PULSE IS RUNNING
PULSEDONE       =       STATS2.1;SAYS TRIGGER FOR CYCLE IS COMPLETE
LAMPON          =       STATS2.2;SAYS IF LAMP IS SWITCHED ON
BLINK           =       STATS2.3;SAYS BLINKER ROUTINE IS TO START A LED FLASH
ALLOWKEY1       =       STATS2.4;SET BY ZD TO CONTROL PHASEANGLE RAMP RATE
ALLOWKEY2       =       STATS2.5;SET BY ZD TO CONTROL ONOFF & STORE DEBOUNCE
BITDONE         =       STATS2.6;SAYS BIT HAS BEEN CAPTURED
STOREMODE       =       STATS2.7;SAYS STORE MODE IS ENABLED
STATS3          DS      1       ;USED TO STORE TEMPORARY PROGRAM STATISTICS
ONOFFCODEVALID  =       STATS3.0;SAYS A VALID ONOFF CODE WAS RECIEVED
BRITECODEVALID  =       STATS3.1;SAYS A VALID BRITE CODE WAS RECEIVED
DIMCODEVALID    =       STATS3.2;SAYS A VALID DIM CODE WAS RECEIVED
IRTOGGLEDONE    =       STATS3.3;SAYS ON/OFF TOGGLE CALLED BY IR CODE IS COMPLETE
GLOW            =       STATS3.4;SAYS LED NIGHTLIGHT GLOWING IS ENABLED
DATAADR         DS      1       ;VALUES POINT TO BYTE OF EEPROM DATA
DATABOX         DS      1       ;HOLDS DATA BYTE READ FROM MEM OR
; HOLDS DATA TO WRITE TO MEM.
HOLDCOUNTER     DS      1
DELAYCOUNTERA   DS      1       ;USED ONLY IN DELAYCOUNTER
DELAYCOUNTERB   DS      1       ;USED ONLY IN DELAYCOUNTER
LEDGLOW         DS      1       ;USED TO COUNT FAST LOOPS TO CONTROL THE
;BRIGHTNESS OF THE LED'S NIGHTLIGHT GLOW.
ORG     0       ;SET TO START OF GENERAL PURPOSE RAM
;INITIALIZE VARIABLES
INITIALIZE      CLR     RA              ;CLEAR ALL OUTPUTS
CLR     RB
       ;MOV     ADCON0,#11001000B ;TURN OFF A2D CONVERTER & SET CLKRATE
;& SET TO CHANNEL 1 <0:3>
SETB    RP0             ;SET RP0 TO UPPER REGISTER BANK
       ;MOV     ADCON1,#00000011B;SET PORT1 INPUTS AS DIGITAL
MOV     RA,#00000100B   ;SET PORT RA DATA DIRECTIONS
MOV     RB,#10111011B   ;SET PORT RB DATA DIRECTIONS
CLR     OPTION          ;SET OPTION REG. RB-PULL-UPS ON
; AND SET PRESCALER TO TIMER
; AND PRESCALER 1:2
CLRB    RP0             ;SET RP0 TO LOWER REGISTER
       ;SETB    RTIE            ;SET TIMER INTERUPT ENABLE
       ;CLRB    INTF            ;CLEAR RB0/INT FLAG
       ;SETB    INTE            ;SET RB0/INT ENABLE
       ;SETB    GIE             ;SET GLOBAL INTERUPT ENABLE
CLR     STATS
CLR     STATS2
CLR     STATS3
CLR     SERINLOG
MOV     PHASEANGLE,#OFF
MOV     DATAADR,#LASTONADR      ;READ LAST "ON/OFF" STATUS
CALL    READDATA
TEST    DATABOX
       ;LEAVE LAMP OFF IF LAST STATE WAS "OFF"...
JZ      :CONTINUE
       ;TURN LAMP ON TO LAST LEVEL IF LAST STATE WAS "ON"...
MOV     DATAADR,#PHASEADR             ;READ LAST "ON" LEVEL
CALL    READDATA
MOV     PHASEANGLE,DATABOX            ;LOAD "ON" LEVEL
:CONTINUE      ;MOV     RAMPCOUNTER,#RAMPRATES
MOV     RAMPCOUNTER,#8
CLR     KEY1COUNTER
MOV     BOUNCECOUNTER,#DEBOUNCE
MOV     TMR0,#TIMERVALUE;RESET TIMER
CLRB    T0IF            ;CLEAR TIMER OVERFLOW FLAG
CALL    LEDPLAY
;MAIN: MAIN PROGRAM LOOP
MAIN
;GENERATE 1/2 LOOP FREQ O/P WAVE
RUNCLOCK        JB      CLOCKOUT,CLEARCLOCK
SETCLOCK        SETB    CLOCKOUT
JMP     MAINA
CLEARCLOCK      CLRB    CLOCKOUT
;DETECT AND READ IR SERIAL I/P
MAINA           RL      SERINLOG
AND     SERINLOG,#00000010B
SNB     SERIN
SETB    SERINLOG.0
JB      BUFFERFULL,RECEIVEDONE ;SHOULD NOT NEED THIS LINE
CJE     SERINLOG,#00000001B,BITBEGIN
JB      WORDSTART,MAINB
JMP     RECEIVEDONE
BITBEGIN        MOV     BITTIMER,#BITWIDTH
CLRB    BITDONE
JB      WORDSTART,MAINB
WORDBEGIN       SETB    WORDSTART
MOV     BITCOUNTER,#17  ;SET NUMBER OF BITS TO RECEIVE
JMP     RECEIVEDONE
MAINB           JB      BITDONE,SPACEDOG
DJNZ    BITTIMER,RECEIVEDONE
SETB    BITDONE
MOV     SPACETIMER,#SPACEWIDTH
KEEPBIT         RL      SERDATA0                ;SHIFT ALL BITS UP
RL      SERDATA1
       ;RL      SERDATA2
       ;RL      SERDATA3
       ;RL      SERDATA4
       ;RL      SERDATA5
       ;RL      SERDATA6
       ;RL      SERDATA7
CLRB    SERDATA0.0
SNB     SERINLOG.0              ;CHECK STATE OF SERIAL INPUT
SETB    SERDATA0.0              ;SAVE  STATE OF SERIAL INPUT
DJNZ    BITCOUNTER,RECEIVEDONE
SETB    BUFFERFULL
JMP     WORDDONE
;THIS IS A WATCHDOG TIMER FOR SPACES BETWEEN IR SIGNALS. IF SPACE IS TOO BIG,
; THE SCANNING OF IR DATA WILL BE RESET.
SPACEDOG        DJNZ    SPACETIMER,RECEIVEDONE
CLR     SERDATA0                ;CLEAR BUFFER
CLR     SERDATA1
CLR     SERDATA2
CLR     SERDATA3
CLR     SERDATA4
CLR     SERDATA5
CLR     SERDATA6
CLR     SERDATA7
WORDDONE        CLRB    WORDSTART
CLRB    BITDONE
RECEIVEDONE
;SCAN FOR PUSHBUTTON KEYPAD I/P AND EXECUTE FUNCTION FOR EACH KEYHIT
; AND ALSO EXECUTE FUNCTIONS FOR WHICH A VALID IR CODE WAS RECEIVED.
SCANKEYS        JB      ONOFFCODEVALID,RUNONOFF
JB      BRITECODEVALID,RUNBRITE
JB      DIMCODEVALID,RUNDIM
JNB     STORE,RUNSTORE
JNB     BRITE,RUNBRITE
JNB     DIM,RUNDIM
JB      ONOFF,KEYSDONE
RUNONOFF        JB      IRTOGGLEDONE,KEYSDONE
JNB     ALLOWKEY2,KEYSDONE
CLRB    ALLOWKEY2
SNB     ONOFFCODEVALID
SETB    IRTOGGLEDONE
SETB    BLINK
CLR     KEY1COUNTER  ;PREVENT AUTOSAVE IF THIS TIMER IS RUNNING
JNB     STOREMODE,:B
SETB    ONOFFHIT
MOV     STORECOUNTERH,#STOREMAXH
MOV     STORECOUNTERL,#STOREMAXL
JMP     KEYSDONE
:B              JB      LAMPON,TURNOFF
TURNON          ;READ STORED VALUE OF LAST LEVEL
CALL    READDATA
CJBE    PHASEANGLE,#MINTURNON,:B
MOV     PHASEANGLE,#MINTURNON
:B              MOV     DATAADR,#LASTONADR            ;SAVE "ON" STATUS FOR NEXT POWERUP
MOV     DATABOX,#1
CALL    SAVEDATA
JMP     KEYSDONE        ;FINISHED
TURNOFF        ;STORE VALUE OF PHASEANGLE FOR RECALL WHEN TURNING BACK ON
       ;CJBE    PHASEANGLE,#MINTURNON,TURNOFFA ;CHECK IF TOO DIM FOR NEXT TURNON
       ;MOV     PHASEANGLE,#MINTURNON          ;SET MIN BRIGHTNESS FOR NEXT TURNON
TURNOFFA        CLRB    LAMPON
MOV     DATAADR,#PHASEADR  ;SAVE LEVEL FOR NEXT TURNON
MOV     DATABOX,PHASEANGLE
CALL    SAVEDATA
MOV     PHASEANGLE,#OFF
MOV     DATAADR,#LASTONADR ;SAVE "OFF" STATUS FOR NEXT POWERUP
MOV     DATABOX,#0
CALL    SAVEDATA
RUNSTORE        JNB     ALLOWKEY2,KEYSDONE
CLRB    ALLOWKEY2
JNB     STOREMODE,SETSTORE
CLRSTORE        SETB    BLINK
CLR     STORECOUNTERH
CLR     STORECOUNTERL
CLRB    STOREMODE
CLRB    ONOFFHIT
CLRB    BRITEHIT
CLRB    DIMHIT
JMP     KEYSDONE
SETSTORE        SETB    BLINK
SETB    STOREMODE       ;INDICATE STORE MODE ENABLED
RUNBRITE        JNB     ALLOWKEY1,KEYSDONE;CHECK IF TIME TO ADJUST PHASEANGLE
CLRB    ALLOWKEY1
SETB    BLINK
JNB     STOREMODE,:B
SETB    BRITEHIT
JMP     KEYSDONE
:B              MOV     KEY1COUNTER,#AUTOSAVE
TEST    PHASEANGLE      ;CHECK IF PHASEANGLE AT LIMIT
JZ      KEYSDONE
DEC     PHASEANGLE      ;ADJUST PHASEANGLE TO MAKE LAMP BRIGHTER
RUNDIM          JNB     ALLOWKEY1,KEYSDONE;CHECK IF TIME TO ADJUST PHASEANGLE
CLRB    ALLOWKEY1
SETB    BLINK
JNB     STOREMODE,:B
SETB    DIMHIT
JMP     KEYSDONE
CJAE    PHASEANGLE,#OFF,KEYSDONE;CHECK IF PHASEANGLE AT LIMIT
INC     PHASEANGLE      ;ADJUST PHASEANGLE TO MAKE LAMP BRIGHTER
       ;JMP     KEYSDONE        ;FINISHED
KEYSDONE
;SCAN FOR EDGES ON ZD I/P WHICH INDICATE OCCURANCE OF AC POWER ZERO-CROSSINGS
; AND OPERATE SYSTEM COUNTERS THAT ARE SYNCHRONIZED TO ZERO-CROSSINGS.
DETECTZERO      RL      ZDLOG           ;SAVE PREVIOUS STATE OF ZDIN IN BIT 1
AND     ZDLOG,#00000010B ;GET PRESENT STATE OF ZDIN & MASK
SNB     ZDIN
SETB    ZDLOG.0
CJE     ZDLOG,#3,DETECTZERODONE ;NO EDGE ON ZDIN FOR THIS VALUE
CJE     ZDLOG,#0,DETECTZERODONE ;NO EDGE ON ZDIN FOR THIS VALUE
       ;SETB    ZEROHIT
INC     ZEROCOUNTER
MOV     PHASECOUNTER,PHASEANGLE ;RESET PHASE COUNTER
CLRB    TRIAC                   ;TURN OFF TRIAC TRIGGER OUTPUT
CLRB    PULSEDONE
;THIS COUNTER SETS DURATION OF LED BLINKS TO MULTIPLES OF ZERO-CROSSINGS.
TEST    BLINKCOUNTER
SZ
DEC     BLINKCOUNTER
;THIS COUNTER CONTROLS THE RATE AT WHICH BRITE & DIM RAMP UP OR DOWN.
; THIS COUNTER IS ALSO A DEBOUNCE TIMER FOR THE DIM & BRITE KEYS.
;THE RAMP RATE IS ALSO DECREASED AS THE PHASEANGLE INCREASES TO PROVIDE
; BETTER CONTROL OF DIMMER SETTINGS.
DJNZ    RAMPCOUNTER,:B
SETB    ALLOWKEY1
       ;NOTE: UNCOMMENT ONLY RAMPRATE ROUTINE #1, #2, OR #3
       ;RAMPRATE ADJUST ROUTINE #1
       ;MOV     RAMPCOUNTER,#RAMPRATEF       ;SET TO SLOW RAMPRATE
       ;CJB     PHASEANGLE,#RAMPTHRESHOLD,:B ;TEST FOR WHICH RAMPRATE
       ;MOV     RAMPCOUNTER,#RAMPRATES       ;SET TO FAST RAMP RATE
       ;RAMPRATE ADJUST ROUTINE #2
       ;MOV     RAMPCOUNTER,PHASEANGLE       ;CALC RAMPRATE AS
       ;RR      RAMPCOUNTER                  ; FUNCTION OF PHASEANGLE
       ;RR      RAMPCOUNTER                  ;DIVIDE VALUE BY 16
       ;RR      RAMPCOUNTER
       ;RR      RAMPCOUNTER
       ;AND     RAMPCOUNTER,#00001111B
       ;TEST    RAMPCOUNTER                  ;CHECK FOR 0
       ;JNZ     :B
       ;MOV     RAMPCOUNTER,#2               ;LIMIT MIN RAMPRATE
       ;RAMPRATE ADJUST ROUTINE #3
MOV      RAMPCOUNTER,#7              ;SET MAX RAMPRATE
CJAE     PHASEANGLE,#112,:B          ;CHECK PHASEANGLE RANGE
DEC      RAMPCOUNTER                 ; AND ADJUST RAMPRATE
CJAE     PHASEANGLE,#80,:B
DEC      RAMPCOUNTER
CJAE     PHASEANGLE,#48,:B
DEC      RAMPCOUNTER
;THIS COUNTER IS THE DEBOUNCE TIMER FOR THE STORE & ONOFF KEYS.
; THIS COUNTER LIMITS ACTION OF THESE KEYS TO 1 TOGGLE PER KEY-PRESS.
:B             ;JNB     STORE,DETECTZERODONE
       ;JNB     ONOFF,DETECTZERODONE
JNB     ONOFF,:C        ;CHECK IF ONOFF KEY IS PRESSED
JNB     STORE,:C        ;CHECK IF STORE KEY IS PRESSED
JMP     :H
:C              MOV     BOUNCECOUNTER,#DEBOUNCE ;RESTART COUNTER IF KEY IS PRESSED
:H              TEST    BOUNCECOUNTER
JZ      :D
DJNZ    BOUNCECOUNTER,:D
SETB    ALLOWKEY2       ;ENABLE ONOFF KEY
;THIS COUNTER SAVES PHASEANGLE TO EEPROM FOR NEXT POWERUP AFTER BRITE OR
; DIM FUNCTIONS WERE USED. THIS TIMER PREVENTS PHASEANGLE DATA FROM BEING
; WRITTEN TO THE EEPROM REPEATEDLY DURING THE ACTUAL USE OF BRITE OR DIM.
:D              TEST    KEY1COUNTER     ;CHECK IF TIME TO SAVE PHASEANGLE
JZ      :F
DJNZ    KEY1COUNTER,:F
CALL    READDATA
CJB     PHASEANGLE,#OFF,:G ;IS LAMP ON OR OFF?
TEST    DATABOX
JZ      :E        ;DON'T SAVE LASTON STATUS IN NVRAM IF ALREADY CLR
       ;MOV     DATAADR,#LASTONADR
MOV     DATABOX,#0
CALL    SAVEDATA  ;SAVE "OFF" STATUS FOR NEXT POWERUP
JMP     :E
:G              TEST    DATABOX
JNZ     :E        ;DON'T SAVE LASTON STATUS IN NVRAM IF ALREADY SET
MOV     DATABOX,#1
CALL    SAVEDATA  ;SAVE "ON" STATUS FOR NEXT POWERUP
:E              MOV     DATAADR,#PHASEADR
CALL    SAVEDATA  ;SAVE PHASEANGLE FOR NEXT TURNON
;THIS COUNTER LIMITS HOW LONG SYSTEM WILL REMAIN IN STORE MODE
:F              JNB     STOREMODE,:I
DJNZ    STORECOUNTERL,:I
DJNZ    STORECOUNTERH,:I
CLRB    STOREMODE
SETB    BLINK
;THIS COUNTER RESETS CODEVALID FLAGS IF NO IR SIGNALS ARE RECEIVED WITHIN
; A CERTAIN AMOUNT OF TIME.
:I              TEST    HOLDCOUNTER
JZ      DETECTZERODONE
DJNZ    HOLDCOUNTER,DETECTZERODONE
CLRB    ONOFFCODEVALID
CLRB    BRITECODEVALID
CLRB    DIMCODEVALID
CLRB    IRTOGGLEDONE
DETECTZERODONE
;DECODE RECEIVED IR CODES AND ENABLE FUNCTION IF VALID CODE DETECTED.
; ALSO STORE NEW IR CODES IF SYSTEM IS IN "STORE" MODE.
DECODESERIN     JNB     BUFFERFULL,DECODEDONE
SETB    BLINK
CLRB    BUFFERFULL
JNB     STOREMODE,DECODE
JB      ONOFFHIT,STOREONOFF
JB      BRITEHIT,STOREBRITE
JB      DIMHIT,STOREDIM
JMP     DECODEDONE
STOREONOFF      CLRB    ONOFFHIT
CLRB    STOREMODE
CLR     STORECOUNTERH
CLR     STORECOUNTERL
MOV     DATAADR,#ONOFFADR
CALL    SAVECODE
JMP     DECODEDONE
STOREBRITE      CLRB    BRITEHIT
CLRB    STOREMODE
CLR     STORECOUNTERH
CLR     STORECOUNTERL
MOV     DATAADR,#BRITEADR
CALL    SAVECODE
JMP     DECODEDONE
STOREDIM        CLRB    DIMHIT
CLRB    STOREMODE
CLR     STORECOUNTERH
CLR     STORECOUNTERL
MOV     DATAADR,#DIMADR
CALL    SAVECODE
JMP     DECODEDONE
DECODE
CHECKONOFF      JB      ONOFFCODEVALID,GOONOFF
CALL    READCODE
CJNE    SERDATA0,MEMDATA0,CHECKBRITE
CJNE    SERDATA1,MEMDATA1,CHECKBRITE
       ;CJNE    SERDATA2,MEMDATA2,CHECKBRITE
       ;CJNE    SERDATA3,MEMDATA3,CHECKBRITE
       ;CJNE    SERDATA4,MEMDATA4,CHECKBRITE
       ;CJNE    SERDATA5,MEMDATA5,CHECKBRITE
       ;CJNE    SERDATA6,MEMDATA6,CHECKBRITE
       ;CJNE    SERDATA7,MEMDATA7,CHECKBRITE
SETB    ONOFFCODEVALID
GOONOFF         MOV     HOLDCOUNTER,#MINHOLDTIME
JMP     DECODEDONE
CHECKBRITE      JB      BRITECODEVALID,GOBRITE
CALL    READCODE
CJNE    SERDATA0,MEMDATA0,CHECKDIM
CJNE    SERDATA1,MEMDATA1,CHECKDIM
       ;CJNE    SERDATA2,MEMDATA2,CHECKDIM
       ;CJNE    SERDATA3,MEMDATA3,CHECKDIM
       ;CJNE    SERDATA4,MEMDATA4,CHECKDIM
       ;CJNE    SERDATA5,MEMDATA5,CHECKDIM
       ;CJNE    SERDATA6,MEMDATA6,CHECKDIM
       ;CJNE    SERDATA7,MEMDATA7,CHECKDIM
SETB    BRITECODEVALID
GOBRITE         MOV     HOLDCOUNTER,#MINHOLDTIME
JMP     DECODEDONE
CHECKDIM        JB      DIMCODEVALID,GODIM
MOV     DATAADR,#DIMADR
CALL    READCODE
CJNE    SERDATA0,MEMDATA0,DECODEDONE
CJNE    SERDATA1,MEMDATA1,DECODEDONE
       ;CJNE    SERDATA2,MEMDATA2,DECODEDONE
       ;CJNE    SERDATA3,MEMDATA3,DECODEDONE
       ;CJNE    SERDATA4,MEMDATA4,DECODEDONE
       ;CJNE    SERDATA5,MEMDATA5,DECODEDONE
       ;CJNE    SERDATA6,MEMDATA6,DECODEDONE
       ;CJNE    SERDATA7,MEMDATA7,DECODEDONE
SETB    DIMCODEVALID
GODIM           MOV     HOLDCOUNTER,#MINHOLDTIME
JMP     DECODEDONE
DECODEDONE
;UPDATE LED STATUS
RUNLED          JB      BLINK,STARTBLINK  ;CHECK IF BLINK SHOULD BEGIN
JNB     GLOW,RUNBLINK     ;CHECK IF NIGHTLIGHT IS ON
NIGHTLIGHT      DEC     LEDGLOW
CJA     LEDGLOW,#LEDDUTY,:B
:A              SETB    LED
JMP     RUNLEDDONE
:B              CLRB    LED
JMP     RUNLEDDONE
STARTBLINK      CLRB    BLINK           ;INIT BLINK TIMER AND TURN LED ON
CLRB    GLOW
SETB    LED
MOV     BLINKCOUNTER,#BLINKWIDTHL ;INIT FOR LONG BLINK
JB      ONOFFCODEVALID,RUNLEDDONE ;TEST IF CODE VALID
JB      BRITECODEVALID,RUNLEDDONE
JB      DIMCODEVALID,RUNLEDDONE
JNB     DIM,RUNLEDDONE
JNB     BRITE,RUNLEDDONE
JNB     ONOFF,RUNLEDDONE
JNB     STORE,RUNLEDDONE
MOV     BLINKCOUNTER,#BLINKWIDTHS ;INIT FOR SHORT BLINK
JMP     RUNLEDDONE
RUNBLINK        TEST    BLINKCOUNTER    ;CHECK IF TIME TO TURN LED OFF
JNZ     RUNLEDDONE
CLRB    LED
SETB    GLOW
RUNLEDDONE
;PRODUCE TRIGGER PULSES FOR TRIAC DRIVING AC LOAD
RUNTRIAC        JB      PULSEDONE,RUNTRIACDONE
CJE     PHASEANGLE,#OFF,RUNTRIACDONE ;VALUE MEANS LAMP OFF
JNB     PULSESTART,RUNCOUNTER
RUNPULSE        DJNZ    PULSECOUNTER,RUNTRIACDONE
CLRB    TRIAC
CLRB    PULSESTART
SETB    PULSEDONE
JMP     RUNTRIACDONE
RUNCOUNTER      TEST    PHASECOUNTER
JZ      RUNTRIGGER
DEC     PHASECOUNTER
JMP     RUNTRIACDONE
RUNTRIGGER      SETB    TRIAC
SETB    LAMPON
SETB    PULSESTART
MOV     PULSECOUNTER,#PULSEWIDTH
RUNTRIACDONE
;REGULATE PROGRAM MAIN LOOP FREQUENCY
WAITER          JB      T0IF,:DONE      ;WAIT UNTIL TIMER OVERFLOWS
JB      T0IF,:DONE      ;THIS METHOD INCREASES THE ACCURACY
JB      T0IF,:DONE      ;WITH WHICH THE TIMER OVERFLOW
JB      T0IF,:DONE      ;IS DETECTED.
JB      T0IF,:DONE
JB      T0IF,:DONE
JB      T0IF,:DONE
JB      T0IF,:DONE
JB      T0IF,:DONE
JB      T0IF,:DONE
JB      T0IF,:DONE
JB      T0IF,:DONE
JB      T0IF,:DONE
JB      T0IF,:DONE
JB      T0IF,:DONE
JB      T0IF,:DONE
JB      T0IF,:DONE
JB      T0IF,:DONE
JB      T0IF,:DONE
JB      T0IF,:DONE
JMP     WAITER
       ;JNB     T0IF,$          ;USUAL TIMER CHECK METHOD USES
; ONLY THIS LINE BUT IS SLIGHTLY
; LESS ACCURATE.
:DONE           MOV     TMR0,#TIMERVALUE
CLRB    T0IF
JMP     MAIN
;SUBROUTINES FOLLOW
;READDATA:READS DATA BYTE FROM EEPROM
READDATA        MOV     EEADR,DATAADR   ;LOAD ADDRESS OF DATA TO READ
SETB    RP0
SETB    RD              ;START READ CYCLE
CLRB    RP0
MOV     DATABOX,EEDATA  ;READ DATA
RET
;SAVEDATA:SAVES DATA BYTE TO EEPROM (TAKES ABOUT 10ms TO COMPLETE AFTER
;          THIS ROUTINE RUNS. CAN CHECK WR BIT TO SEE IF DONE)
SAVEDATA        SETB    RP0
JB      WR,$            ;WAIT IF EEPROM IS BUSY
CLRB    RP0
MOV     EEADR,DATAADR   ;LOAD ADDRESS OF LOCATION TO SAVE TO
MOV     EEDATA,DATABOX  ;LOAD DATA TO SAVE
SETB    RP0
SETB    WREN            ;SET WRITE ENABLE BIT
MOV     EECON2,#055H    ;WRITE SPECIAL BYTE #1
MOV     EECON2,#0AAH    ;WRITE SPECIAL BYTE #2
SETB    WR              ;START WRITE CYCLE
CLRB    WREN            ;CLR WRITE ENABLE BIT
CLRB    RP0
RET
;LEDPLAY:BLINK LED FOR BILL'S FUN AND AMUSEMENT! (INDICATES MICRO IS RUNNING)
LEDPLAY         MOV     BLINKCOUNTER,#10
:LOOP           SETB    LED
CALL    DELAY50MS
CLRB    LED
CALL    DELAY50MS
DJNZ    BLINKCOUNTER,:LOOP
SETB    GLOW
RET
;DELAY50MS: TIME DELAY OF 50ms WITH 10MHz CLOCK
DELAY50MS       MOV     DELAYCOUNTERB,#163
MOV     DELAYCOUNTERA,#84
:LOOP           DJNZ    DELAYCOUNTERA,$
DJNZ    DELAYCOUNTERB,:LOOP
RET
;SAVECODE:SAVES UP TO 8 BYTES OF COMMAND CODE FROM RAM TO EEPROM
SAVECODE        MOV     DATABOX,SERDATA0
CALL    SAVEDATA
INC     DATAADR
MOV     DATABOX,SERDATA1
CALL    SAVEDATA
       ;INC     DATAADR
       ;MOV     DATABOX,SERDATA2
       ;CALL    SAVEDATA
       ;INC     DATAADR
       ;MOV     DATABOX,SERDATA3
       ;CALL    SAVEDATA
       ;INC     DATAADR
       ;MOV     DATABOX,SERDATA4
       ;CALL    SAVEDATA
       ;INC     DATAADR
       ;MOV     DATABOX,SERDATA5
       ;CALL    SAVEDATA
       ;INC     DATAADR
       ;MOV     DATABOX,SERDATA6
       ;CALL    SAVEDATA
       ;INC     DATAADR
       ;MOV     DATABOX,SERDATA7
       ;CALL    SAVEDATA
RET
;READCODE:READS UP TO 8 BYTES OF COMMAND CODE FROM EEPROM TO RAM
READCODE        CALL    READDATA
MOV     MEMDATA0,DATABOX
INC     DATAADR
CALL    READDATA
MOV     MEMDATA1,DATABOX
       ;INC     DATAADR
       ;CALL    READDATA
       ;MOV     MEMDATA2,DATABOX
       ;INC     DATAADR
       ;CALL    READDATA
       ;MOV     MEMDATA3,DATABOX
       ;INC     DATAADR
       ;CALL    READDATA
       ;MOV     MEMDATA4,DATABOX
       ;INC     DATAADR
       ;CALL    READDATA
       ;MOV     MEMDATA5,DATABOX
       ;INC     DATAADR
       ;CALL    READDATA
       ;MOV     MEMDATA6,DATABOX
       ;INC     DATAADR
       ;CALL    READDATA
       ;MOV     MEMDATA7,DATABOX
RET
Edit: if you need to post code the use the code function Smiley
« Last Edit: April 07, 2009, 02:20:48 14:20 by pickit2 » Logged
-Given: 405
-Receive: 545
« Reply #1 on: April 07, 2009, 02:04:05 14:04 »
maybe try here he has his own assembler if I remember right it was Src ,I maybe wrong but try there it could also be mpasm obj code,I don't use it so not sure
http://mondo-technology.com/
« Last Edit: April 07, 2009, 02:16:04 14:16 by bbarney » Logged
th_sak
-Given: 150
-Receive: 149
« Reply #2 on: April 07, 2009, 02:23:48 14:23 »
The code you have posted looks like 8051 assembly code. So try to assemble it using asem-51 assembler.
http://plit.de/asem-51/
-Given: 834
-Receive: 4322
« Reply #3 on: April 07, 2009, 02:25:02 14:25 »
good call on that bbarney, looking at it I thought MPasm then I read your link.
There are two formats for writing PIC assembler code. One comes directly from Microchip (MPASM), the other comes originally from Parallax who sold it to Tech-Tools (CVASM).
-Given: 405
-Receive: 545
« Reply #4 on: April 07, 2009, 02:44:01 14:44 »
There was one other Japaneese guy who used cvasm to he wrote some kinda dis-assembler
http://online.dip.jp/mikado/page2/index_e.html
