January 11, 2025, 06:11:27 06:11
Author Topic: PIC 16F917 AND AT25256 Interface using SPI  (Read 4354 times)
hock
-Receive: 126
« on: April 03, 2009, 06:44:16 18:44 »
i am trying to use AT25256 SPI eeprom with PIC 16F917.the first byte generates an error, all other bytes are correct. i am suspecting a bug is in read function. the SPI clock and DATA is visible on CRO. i am not sure if it is correct. do not have a deep memory scope.
can some one please help.
this is the code in main()
# include <htc.h>
# include "pic_function.h"
# include "delay.h"
# include "AT25256.h"
unsigned char i;
main()
init_pic(); // init the pic paripheral
init_AT25256();
while(1)
write_AT25256(0xBC,0x0100);
i = read_AT25256(0x0100);
if (i == 0xBC)
RB3 = 1;
RB4=0;
else
RB4 = 1;
RB3=0;
this is the code for init_pic
# include <htc.h>
__CONFIG(0x20E2); // watch dog timer is off
void init_pic(void)
// Oscillator Configuration register
// OSCCON =
//init interrupt register
INTCON = 0xE0;
//init port directions
TRISA = 0xFF;
TRISB = 0xE7;
TRISC = 0xAF;
TRISD = 0xF0;
TRISE = 0xFF;
RB3 = 0;
RB4 = 0;
// init spi
SSPEN = 0;
SSPSTAT |= 0x80;
SSPCON |= 0x10;
SSPBUF = 0x00;
SSPEN = 1;
PEIE = 1; // Enable Peripheral Interrupt Flag
GIE = 1; // enable Global Interrupt Flag
this is the code for AT25256
# include <htc.h>
# include "delay.h"
void init_AT25256(void)
ram_cs = 1;
delay_in_us(10);
ram_cs = 0;
write_spi(WREN);
ram_cs = 1;
delay_in_us(10);
ram_cs = 0;
write_spi(WRSR);
write_spi(NOPROT);
ram_cs = 1;
void write_AT25256(unsigned char data,unsigned int address)
ram_cs = 1;
delay_in_us(10);
ram_cs = 0;
write_spi(WREN);
ram_cs = 1;
delay_in_us(10);
ram_cs = 0;
write_spi(WRITE);
write_spi((address >> Cool);
write_spi((address & 0xFF));
write_spi(data);
ram_cs = 1;
unsigned char read_AT25256(unsigned int address)
unsigned char data;
ram_cs = 1;
delay_in_us(10);
ram_cs = 0;
write_spi(READ);
data = read_spi();
ram_cs = 1;
return data;
void write_spi(unsigned char data)
SSPIF = 0;
SSPBUF = data;
while (!SSPIF)
delay_in_ms(5);
unsigned char read_spi(void)
unsigned char temp;
SSPIF = 0;
SSPBUF = 0xFF;
while (!SSPIF)
delay_in_ms(5);
temp=SSPBUF;
return temp;
