November 29, 2024, 05:35:20 17:35
Author Topic: What is problem with atmega32  (Read 4358 times)
aamir
-Given: 37
-Receive: 229
« on: April 01, 2009, 05:48:23 05:48 »
 I am using LPT Progrmers for avr micro controllers ISP programs perfect  atmega8515 but problem with atmega32
PonyProg gives a -24 error saying it cannot recognize the attached any tip
microkid
-Given: 45
-Receive: 23
« Reply #1 on: April 01, 2009, 07:17:18 07:17 »
some avr chips requires SS line
Did you tried it?
MicroKid
Never Never Never giveup
aamir
-Given: 37
-Receive: 229
« Reply #2 on: April 01, 2009, 07:19:19 07:19 »
How to use it
microkid
-Given: 45
-Receive: 23
« Reply #3 on: April 01, 2009, 12:54:03 12:54 »
Sorry for not being able to help
I read it somewhere long back, while i get this problem. I cant remember how i solved it
For a long time im using usb port programmer
MicroKid
rahuljin
-Receive: 21
« Reply #4 on: April 01, 2009, 02:34:43 14:34 »
have u checked the connection because the pins are at different positions in these two microcontrollers?
also do u change the microcontroller type in ponyprog to atmega32 ?
or may be the microcontroller is gone.
have u set the fuse bits of the atmega32 to work with external crystal ? try to put one.
aamir
-Given: 37
-Receive: 229
« Reply #5 on: April 02, 2009, 04:16:59 04:16 »
Yes I have checked connection for micro controller i use different connection for micros
ali_asadzadeh
-Receive: 12
« Reply #6 on: April 14, 2009, 07:46:48 07:46 »
haven't you changed the fuse bits!
sacoroxo
-Given: 34
-Receive: 26
« Reply #7 on: April 16, 2009, 06:21:04 18:21 »
Wrong fuses settings ?
Howto recover wrong fuses settings on a AVR ? --> http://www.larsen-b.com/Article/260.html
High Voltage Programmer. --> http://www.der-hammer.info/hvprog/index_en.htm
