You think I am funny guy huh?
November 28, 2024, 07:41:57 19:41
Author Topic: [ASM] "include" error in MPLAB  (Read 6404 times)
tAhm1D
-Given: 103
-Receive: 180
« on: March 28, 2009, 04:21:14 16:21 »
I have used MPLAB v6.40, v7.30 and now v7.52. While programming in assembly language, I faced a problem with all the versions of MPLAB. Even after I include the header file like include "p18f4520.inc" I still have to declare the special function registers as MPLAB cannot detect the SFRs mentioned in the included header file. What is the problem? Huh
oldvan
-Receive: 107
If the van is a Rockin'...
« Reply #1 on: March 28, 2009, 07:29:26 19:29 »
Have you tried MPLAB 8.2?  Versions 6 and 7 are pretty badly antiquated.  You could be struggling with an old and now fixed problem.
If you want, post a sample of what you are trying and I'll try it here, let you know result.
tAhm1D
-Given: 103
-Receive: 180
« Reply #2 on: April 01, 2009, 07:39:52 19:39 »
Hi oldvan,
I have downloaded MPLAB 8.3 and started using it. Even in this version, same problem persists. I think, there may be an inherent problem in MPLAB in this regard. However, if you can find any solution, please let me know.
oldvan
-Receive: 107
« Reply #3 on: April 01, 2009, 10:29:54 22:29 »
Please post a sample of what you are doing, I've just been working on an assembly language program for the 16F877 using MPLAB 8.2 with no problems.  I suspect you are making a small error that once corrected can make your life MUCH easier.
-Given: 496
« Reply #4 on: April 01, 2009, 11:04:35 23:04 »
Do you specify the path directory for the .inc file?
oldvan
-Receive: 107
« Reply #5 on: April 02, 2009, 12:45:27 00:45 »
Should be no need to call out the entire path, MPASM should know where they live.
The following worked fine in my program:
#INCLUDE <P16F877.INC>  ; THIS IS WHERE CHIP REGISTERS AND BITS ARE DEFINED
xzb
-Given: 16
« Reply #6 on: April 02, 2009, 02:25:42 02:25 »
I used  v8.2 Whatever one or ones( #INCLUDE <P18F4520.INC>  #INCLUDE "P18F4520.INC" )no problem.
tAhm1D
-Given: 103
-Receive: 180
« Reply #7 on: April 02, 2009, 01:29:18 13:29 »
Hi oldvan,
In my case it is not working. Let me put a small Test program. In the following Test program with Pic18f4520,where 2 leds in portb are lit, include path is not working and only when portb and trisb is defined in the program (remove the semicolon), only then the program is build successfully. Why? Please assemble the program and let me know kindly.
« Last Edit: April 02, 2009, 01:34:47 13:34 by tAhm1D » Logged
oldvan
-Receive: 107
« Reply #8 on: April 02, 2009, 03:45:27 15:45 »
Case seems to be causing the problem in this case.
For MPASM,
           clrf  portb
Is not the same as:
           CLRF  PORTB
Try it and report back.  :-)
tAhm1D
-Given: 103
-Receive: 180
« Reply #9 on: April 02, 2009, 04:44:31 16:44 »
Hi oldvan,
Now it works. Yes, the problem was because of the case. So simple but so problematic.
« Last Edit: April 02, 2009, 04:52:36 16:52 by tAhm1D » Logged
