January 11, 2025, 03:05:30 03:05
Author Topic: ccsc 4.084 and float number  (Read 5381 times)
Isabelino
« on: March 25, 2009, 05:10:51 17:10 »
Friends:
         I have CCSC 4.084 and I can't see float number on Proteus 7.4 SP3,. Why? My code is:
#include <16f628a.h>
#include <float.h>
void main()
   float a=3.25;
help me, please.
Kombinator
-Given: 39
-Receive: 32
« Reply #1 on: March 25, 2009, 07:31:18 19:31 »
float a;
void main()
   setup_adc_ports(NO_ANALOGS|VSS_VDD);
   setup_adc(ADC_OFF);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED,0,1);
   setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
   // TODO: USER CODE!!
a=3,234;
xzb
-Given: 16
« Reply #2 on: March 26, 2009, 02:07:40 02:07 »
this a problem I too nonplus,ccs and mcc can't see float number on Proteus 7.4 SP3.
so can see float number but is exponential the format:see aattachments
    « Last Edit: March 26, 2009, 08:11:15 08:11 by xzb » Logged
    xzb
    -Given: 16
    « Reply #3 on: March 27, 2009, 02:42:40 02:42 »
    I find IAR 'C' can true see float number on Proteus.
    « Last Edit: March 27, 2009, 02:54:02 02:54 by xzb » Logged
    Isabelino
    « Reply #4 on: March 27, 2009, 10:10:32 10:10 »
    Thanks XZB, your solution its ok.
     Wink Wink Wink Wink
    Isabelino
    « Reply #5 on: April 02, 2009, 03:44:56 15:44 »
    Friends:
    It's possible see BIGEndian floats variables on Proteus.
    mayler
    Roger that!
    « Reply #6 on: April 09, 2009, 04:46:37 04:46 »
    There is a problem in COFF generation in CCS. You can see the number in watch window, putting the address and specifying Big Endian Float Format...
    Computer Engineer.
    Isabelino
    « Reply #7 on: April 09, 2009, 02:02:36 14:02 »
    Thanks mayler:
                        Yes, I do it. But I want to see float variable in the other form ( Into variables window).
     Grin
    mayler
    Roger that!
    « Reply #8 on: April 10, 2009, 07:25:40 19:25 »
    Me too. But there's no way as far i know.
    Computer Engineer.
