April 28, 2025, 01:16:07 13:16
Author Topic: mikroC PRO for PIC 2009 version 1.6.5 has been released  (Read 23839 times)
zokij
-Given: 269
-Receive: 679
Nice time :)
« on: March 21, 2009, 01:41:46 01:41 »
Date: 20-03-2009
We have introduced bit variables, new graphical IDE, improved linker and optimizer. The process of compiling is much faster, machine code is smaller (up to 40%), environment is more user-friendly, examples and documentation are significantly improved. This version has been tested thoroughly, and is proved to be fully functional. We strongly recommend you to download it and give it a try. We hope it will satisfy your needs and expectations.
http://www.mikroe.com/en/compilers/mikroc/pro/pic/
wnmaximino
-Given: 47
-Receive: 202
Homer
« Reply #1 on: March 21, 2009, 08:33:09 20:33 »
Any people have a patch for this version?
THX!!
folkeu
-Given: 129
-Receive: 326
« Reply #2 on: March 26, 2009, 10:30:30 22:30 »
Someone works for this patch ?
xp338
-Given: 249
-Receive: 47
« Reply #3 on: April 07, 2009, 07:18:50 19:18 »
Try this.
Found it from China.
Credit to orginal creaker.
http://rapidshare.com/files/218591779/test.zip.html
MD5: 44D181C6435B237255FADB6E11EC4509
Limit 10 downloads only
wnmaximino
-Given: 47
-Receive: 202
Homer
« Reply #4 on: April 07, 2009, 07:57:35 19:57 »
Working fine!!
Thx
folkeu
-Given: 129
-Receive: 326
« Reply #5 on: April 07, 2009, 08:23:56 20:23 »
Can you make a new post, The download is closed because the 10 time is make
slashi
« Reply #6 on: April 07, 2009, 08:31:53 20:31 »
mirror:
http://www.mediafire.com/?gwqgjaiygjd
or
http://www.megaupload.com/?d=Q3BCIM7X
spasbyspas
-Given: 737
-Receive: 366
« Reply #7 on: April 07, 2009, 09:04:03 21:04 »
Amazing! 10k code compilled for 1sec! Shocked Wink
Please, test this compiller for confirmation this result(with this crack and included demo project)?!
xjackalx
-Given: 11
« Reply #8 on: April 07, 2009, 10:29:44 22:29 »
how is that.
changes in syntax?
my electronics folder on rapid
http://rapidshare.com/users/6S2ZL2
mikroset
« Reply #9 on: April 08, 2009, 02:37:45 14:37 »
   Adc_Read command does not work is by no means the first flaw that I find in this compiler,
   in previous versions I had no problems  Roll Eyes
mmladenovic
« Reply #10 on: April 08, 2009, 04:49:32 16:49 »
My code works in version 8.2 but not in this one Huh Sad
mpavlica
-Given: 32
« Reply #11 on: April 09, 2009, 08:29:55 20:29 »
crack not good
doesnt produce good code above 7500bytes
meax98
-Given: 1376
-Receive: 52
« Reply #12 on: April 18, 2009, 10:33:55 10:33 »
crack not good
Since in demo version, hex output is limited to 2k of program words, not 10k or 7.5k, what is true? Is this crack working or not?
mpavlica
-Given: 32
« Reply #13 on: April 18, 2009, 04:39:08 16:39 »
it does produce code, any size, but it isnt right compiled
spasbyspas
-Given: 737
-Receive: 366
« Reply #14 on: April 25, 2009, 10:57:49 10:57 »
Hi all!
RL-Team.Net Release!!!
mikroC PRO for PIC 2009 v1.65 + Crack
http://uploadbox.com/files/1DslNNeqcC
mikroBasic PRO for PIC 2009 v1.45 + Crack
http://uploadbox.com/files/DOsoZQEmFD
mikroPascal PRO for PIC 2009 v1.40 + Crack
http://uploadbox.com/files/hsw6TP9zLh
Pass:rl-team.net
Please,test and enjoy!
« Last Edit: April 25, 2009, 11:02:40 11:02 by spasbyspas » Logged
Cyril
« Reply #15 on: April 29, 2009, 06:07:31 18:07 »
   This version looks like a real RAM saver, have compared it with the 8.2 examples and it is terrific.
Can any one compare it with Hi-Tech compilers?
mabd
-Receive: 16
« Reply #16 on: May 10, 2009, 06:34:36 18:34 »
mikroC PRO for PIC 2009 BETA build 1.80 is available for download
Date: 07-05-2009
Give it a try, we still have some work to do on it, but the version is operational and functional. Do not hesitate to send us bug reports (the bug reporting system is built in the IDE).
List of improvements includes:
IDE:
New: Quick convertor added
Improved: External nodes added to code explorer
Improved: Enhancement of IDE styles set
Improved: Asm files added for all source files in Project Manager window
Improved: Print preview added, print options problem solved
Improved: Code Assistant display improvement for local declarations
Fixed Bug: Fast scrolling device name combo box in Project Settings window problem
Fixed Bug: Add/Remove files, right click does not mark selection in Project Manager window
Fixed Bug: Starting simulator if project is built for different family
Fixed Bug: Ascii table "&" sign problem
Fixed Bug: Breakpoints do not take effect unless Breakpoint Window is visible
Fixed Bug: Simulator and return from interrupt problem
Fixed Bug: Simulation of pop and mov to PCL register,
Compiler:
Additional chips supported: P18F13K50, P18F46J50, P18LF45J11, P18F14K50, P18F66J90, P18LF45J50, P18F23K20, P18F67J90, P18LF46J11, P18F24J11, P18F86J90, P18LF46J50, P18F24J50, P18F87J90, P18F25J11, P18LF13K50, P18F25J50, P18LF14K50, P18F26J11, P18LF24J11, P18F26J50, P18LF24J50, P18F43K20, P18LF25J11, P18F44J11, P18LF25J50, P18F44J50, P18LF26J11, P18F45J11, P18LF26J50, P18F45J50, P18LF44J11, P18F46J11 and P18LF44J50.
Improved: Def files for P18 family CCPR1 and ECCPR1 declared as 16bit registers
Improved: Interrupt vector table does not contain GOTO if it is not needed
Fixed bug: Long as indirect operand in (+,-) for p16 family
Fixed bug: Bad hex generated if code goes over 64kb in certain cases
Fixed bug: Interrupt and code size over 2k corrupts interrupt vector table (p16 family)
Fixed bug: I2C1_Init and I2C2_Init swapped calls
You can download it here.
http://www.mikroe.com/zip/mikroc_pic_pro/mikroc_pro_pic_beta_v180_setup.zip
