November 29, 2024, 09:57:29 21:57
Author Topic: New Microcontroller Selection after 8051  (Read 4298 times)
pramodjaipur
-Given: 17
« on: March 07, 2009, 09:49:36 09:49 »
We are working on 8051 project; The code size after compile is around 100K +
We are using External Uart, RTC, Latch & Logic's  EP-ROM, SRam. Watchdog IC. etc.
8051 supporting well, but due to code banking and more memory requirements, i want to shift with other controller, needed same functions.
I checked with ARM7, but need to modify in the Hardware too.
Please help me to selecting new chip.
thanks for your suggestions.
mick
-Given: 2056
-Receive: 122
« Reply #1 on: March 07, 2009, 11:09:54 11:09 »
http://www.st.com/stonline/press/news/year2002/p1226m.htm
The family's 40MHz 8032 core supports USB and many other on-chip peripherals making these devices a complete solution for a broad variety of embedded control applications. With up to 288-Kbyte of Flash memory and 8-Kbyte of SRAM, ST offers the largest memory densities for an 8051-class MCU available today. A $149 development kit coupled with third-party development tools is everything required to implement and validate a design.
Also take a look at www.maxim-ic.com
they have 8051 cores too
                        good luck with 8051
pramodjaipur
-Given: 17
« Reply #2 on: March 10, 2009, 06:31:02 06:31 »
                        good luck with 8051
Thanks for your reply,  If new design is required to use this device, better we can go with other "uC"
As we written the code in C and using compiler, better we can use some what latest.
Please suggest.
ali_asadzadeh
-Receive: 12
« Reply #3 on: March 10, 2009, 08:43:07 08:43 »
why not using an atmel avr?
you can use ATmega2560 containing 256KB code 8Kb ram 4 usart 5 timers 16 10bit adc and a lot of other stuff.
manman
-Receive: 23
« Reply #4 on: March 10, 2009, 03:48:20 15:48 »
Why not using a C8051F120 with 100 MIPS, 128 kB Flash, 8448 bytes data RAM, 8input AMUX 12-Bit ADC, Programmable amplifier gain: 16, 8, 4, 2, 1, 0.5, Two 12-Bit DACs, Five 16-bit timers, 100-Pin, 64 port I/O;, On-Chip JTAG Debug, and etc. Please see SILICON LABS site www.silabs.com for more info.
