November 26, 2024, 08:52:23 08:52
Author Topic: How to decode Manchester stream bit.  (Read 8833 times)
chithanh04dt2
-Given: 97
« on: February 18, 2009, 03:34:54 03:34 »
Hello, i'm a student and buiding final project for graduation. It's about RFID reader, I have a problem  with decoding Manchester . Could you tell me how to decoding Manchester use PIC, please.
Sorry for my English.
Regard !
-Given: 496
« Reply #1 on: February 18, 2009, 11:38:54 23:38 »
A manchester code sends data as changes in the data line.
The beauty of this coding is you can extract the bit rate by measuring the pulses time.
A change from high to low could be read as a 0
where as a low to high  could be read as a 1.
so if your original data is 0100 1100
the data to be sent are
10011010 01011010
Original data    ---> data to send
0 --> 10
1 --> 01
0 --> 10
0 --> 10
etc.
Decoding the data? just read every second bit of the data and you got the original stuff.
flyback
-Given: 73
-Receive: 39
« Reply #2 on: April 07, 2009, 09:17:42 21:17 »
you will find a very good example. with source code for PIC
http://www.winpicprog.co.uk/pic_tutorial12.htm
mris99
-Receive: 16
« Reply #3 on: April 08, 2009, 10:26:45 22:26 »
Sample Code in C (unknown source):
int16 man_encode(int unenc) {
   int odd_byte,even_byte,temp;
   odd_byte=unenc&0xAA;
   temp=(~unenc&0xAA)>>1;
   odd_byte=odd_byte|temp;
   even_byte=unenc&0x55;
   temp=(~unenc&0x55)<<1;
   even_byte=even_byte|temp;
   return((int16)odd_byte<<8)|even_byte;
int man_decode(int16 enc) {
   int odd_byte,even_byte;
   odd_byte=(int)(enc>>8);
   if((odd_byte&0xAA)^((~odd_byte&0x55)<<1)) {
      receive_error=1;
      return(0);
   } else odd_byte&=0xAA;
   even_byte=(int)enc;
   if((even_byte&0x55)^((~even_byte&0xAA)>>1)) {
      receive_error=1;
      return(0);
   } else even_byte&=0x55;
   receive_error=0;
   return(odd_byte|even_byte);
And the same in PIC16 assembly (by me):
;***** man_encode *********************************************************
;* manchester encode
;* Input : unenc              ; byte to encode
;* Output: manch16 ; coded word
;* Clock : ?
man_encode movf unenc,w ; odd_byte=unenc&0xAA;
andlw 0AAh
movwf odd_byte
comf unenc,w ; temp=(~unenc&0xAA)>>1;
andlw 0AAh
movwf TEMP
clrc
rrf TEMP,f
movf TEMP,w ; odd_byte=odd_byte|temp;
iorwf odd_byte,f
movf unenc,w ; even_byte=unenc&0x55;
andlw 055h
movwf even_byte
comf unenc,w ; temp=(~unenc&0x55)<<1;
andlw 055h
movwf TEMP
clrc
rlf TEMP,f
movf TEMP,w ; even_byte=even_byte|temp;
iorwf even_byte,f
return
;***** man_decode *********************************************************
;* manchester decode
;* Input : manch16 ; coded word
;* Output: unenc              ; decoded byte
;* Clock : ?
man_decode comf odd_byte,w ; TEMP = (~odd_byte&0x55)<<1)
andlw 055h
movwf TEMP
clrc
rlf TEMP,f
movf odd_byte,w ; W = (odd_byte&0xAA)
andlw 0AAh
xorwf TEMP,w ; W = (odd_byte&0xAA)^(~odd_byte&0x55)<<1)
jz md_input_ok1 ; if((odd_byte&0xAA)^((~odd_byte&0x55)<<1)) {
movlw 1 ;   receive_error=1;
movwf receive_error
clrf unenc ;   return(0);
return
md_input_ok1 movlw 0AAh ; else odd_byte&=0xAA;
andwf odd_byte,f
comf even_byte,w ; TEMP = (~even_byte&0xAA)>>1)
andlw 0AAh
movwf TEMP
clrc
rrf TEMP,f
movf even_byte,w ; W = (even_byte&0x55)
andlw 055h
xorwf TEMP,w ; W = (even_byte&0x55)^((~even_byte&0xAA)>>1)
jz md_input_ok2 ; if((even_byte&0x55)^((~even_byte&0xAA)>>1)) {
movwf receive_error
return
md_input_ok2 movlw 055h ; else even_byte&=0x55;
andwf even_byte,f
clrf receive_error ; receive_error=0;
movf odd_byte,w ; return(odd_byte|even_byte);
iorwf even_byte,w
movwf unenc
return
