April 30, 2025, 07:45:09 07:45
Author Topic: it is very good pic programmer  (Read 12780 times)
matelda
« on: November 02, 2006, 02:02:31 14:02 »
hi friends :
it is very good programmer , i tested it and it was perfect
http://www.winpic800.com/
best regards
MAtelda
-Given: 562
« Reply #1 on: November 02, 2006, 06:47:06 18:47 »
Yes you are right it's very good programmer i have been using right from the beging.
But what was the point of your post when this has already been coverd ?
wizpic
mizk_electro
« Reply #2 on: November 03, 2006, 12:54:30 00:54 »
but the latest version not support with USB programmer (using free hex ... version SUMMER ) .....
I succesfull build USB programmer using HEX summer version but only WORKING with winpic800 ver 3.55b & 3.55g  NOT the latest version ....
 Sad
Anyway it works ....  Wink
« Last Edit: November 03, 2006, 10:41:08 10:41 by mizk_electro » Logged
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1298
« Reply #3 on: November 04, 2006, 05:35:10 05:35 »
I think because the newer version use the USB2 compatibility to work and the SUMMER edition dont use this feature.
mizk_electro
« Reply #4 on: November 04, 2006, 07:51:18 07:51 »
Hmmm ....
Actually I use USB programmer ( with SUMMER hex ) with DELL Laptop Inspiron 6400 Duo Core ... bought in early 2006.... I thinks the USB port in my laptop is upto date.
Maybe somebody can crack winpic800 v3.60 to work with USB Summer edition ....   Huh ... who knows ?
mizk_electro
« Reply #5 on: November 04, 2006, 07:55:10 07:55 »
Or maybe we can create one forum ... just to develop software ( winpic800 alike ) for PIC & AVR programmer ... and it will be open source ( I mean on windows base) ... so that anybody can study the codes & change it upto their requirement.
Maybe somebody can write it using VB or C or what ever language.
Maybe somebody has better idea ?
matelda
« Reply #6 on: November 04, 2006, 11:18:22 11:18 »
hi
i use LPT wonpic800 programmer , and it works perfectly .....but i want to use USB programmer ... i could not find full requirements in the website """firmwire """ so if u we can share schematic + layout + firmwire , i will be thankful .
best regards
Matelda
mizk_electro
« Reply #7 on: November 04, 2006, 12:09:24 12:09 »
Here you are ...
INFO :
For the hex code ... there 2 hex codes (both proven working ... at least for me  Wink ) .... one is v3.54 & and other one v3.55 .
For the schematic & pcb ... using eagle 4.16r1. Inside schematic (or PCB) there 2 ICSP ... I put 2 ICSP for future plan as maybe I will cut it into 2 part ie programmer & socket .... maybe also for extension for other socket ie 18pin for 16F84A.
There is jumper for  supply power (VDD) for program PIC ... one is from USB power +5V or maybe connect to external +5V battery/power socket for extra ampere. Set jumper to  USB +5V is just working fine for me.
I just put in 28pin & 40pin socket for program PIC ... succesful program 18F2550, 18F4550, 16F877, 16F877A ... other not test as I dont have.
For Winpic800, this circuit ( & hex ) only working with Winpic800 v3.55b & v3.55g ( both tested ok with me ) .... I just attached v3.55g.
For driver ... searc in winpic800/GTP_USB/Driver GTP_USB/
Note: for Transistor = BC547 & Crystal 12Mhz .
This circuit PROVEN WORKING with laptop DELL Inspiron 6400 Duo Core .
So if you build it, could you please report back here on (as some hardware(PC) not compatible as stated by some forums):
1. Type of PIC you succesfull program with it ?
2. PC type (CPU , Motherboard & OS (xp sp2 etc))
3. Laptop / Deskstop.
4. Also any problem encounter
I ask your RESPONSE BACK  just for benefit all of us ....  Smiley ...  Cool
Also PLEASE refer  to :
1. http://ali3nworld.blogspot.com/
2. http://www.hobbypic.com/index.php?option=com_content&task=view&id=12&Itemid=35
« Last Edit: November 04, 2006, 12:44:39 12:44 by mizk_electro » Logged
mizk_electro
« Reply #8 on: November 04, 2006, 12:47:17 12:47 »
I'm giving back to this forum as I received much more from MY FRIENDS in this forum.
 Smiley  Smiley  Smiley ....  Cool
matelda
« Reply #9 on: November 04, 2006, 02:59:28 14:59 »
hi :
thankx mizk_electro for this great usb pic programer which inluded in this website
i want to say that it is very easy to build ..... but have u tested it ... w is ur opinion about it
best regadrs
Matelda
mizk_electro
« Reply #10 on: November 04, 2006, 03:56:10 15:56 »
matelda ...
Mine are same as in the blog .... except mine has extra ICSP, build with socket 28pin & 40 pin for PIC programming & external +5V for PIC programming socket .... actually the basic prinsip are same.
Mine are tested working ok (function 100%)  !!! ...  or maybe my explanation is not clear enough  Sad     .... sorry for my bad english   Cry
my hex code v3.54 is from this blog ( & also winpic800 v3.55b ) ..... hex code v3.55 are from some forums but I forgot the forum from  but both hex work ok (100% function).... hope my explanation clear enough to you....  Smiley
So it up to you to build or not ...  Wink
« Last Edit: November 04, 2006, 04:44:38 16:44 by mizk_electro » Logged
olotill
« Reply #11 on: November 05, 2006, 04:31:45 04:31 »
Hey mates...
If you want the winpic800 3.55g, just let me know and I send you, please use P.M. for asking about it..
Best Regards..
mizk_electro
« Reply #12 on: November 05, 2006, 09:07:11 09:07 »
Friends..
if any of you build this programmer ( using schematic from blog " http://ali3nworld.blogspot.com/ " or using mine ) , can you contribute back again here on type of PIC controller that been succesfull programmed using this programmmer.
I ask this just for OUR OWN GOODs (to see any limitation & problem if any)  .... thks.
astroman132003
« Reply #13 on: November 05, 2006, 11:25:05 11:25 »
  Hello
  I have done the programmer from hobbypic working with 3.55g and i have programmed the 16f876 and 16f84a at first time.
olotill
« Reply #14 on: November 05, 2006, 03:19:40 15:19 »
Hey mates..
I built the programmer based on the hobbypic por J1M model.... but I add a ZIF socket design based on GTP USB PLUS, so I tested the programmer with this models of pic..
PIC12F675
PIC12F629
PIC16F627
PIC16F628A
PIC16F819
PIC16F871
PIC16F876A
PIC16F877A
PIC18F2550
PIC18F452
PIC18F4620
PIC18F4550..
The programmer works very very good, almost like PLUS version, but I boght a PLUS version to use it for PIC`s and AVR, because I like AVR more than PIC  Wink
If you want the final design including the ZIF socket, just send me an PM and I will send you every monday...
Best Regards...
Olotill
matelda
« Reply #15 on: November 05, 2006, 03:37:52 15:37 »
my friends :
thankx very much for help .... i will build the programmer in this website http://ali3nworld.blogspot.com/
and i will inform u soon about the result ... i will take some photos for this programmer .
best regards
Matelda
njam
« Reply #16 on: December 04, 2006, 08:13:24 20:13 »
Hi Everybody!!
Be avare owners of laptop or PC with SIS 7001 usb controller on board .With this controller programmer GTP-USB lite end others  GTP
NO WORKS !!!!!!
Best regards
Njam
charudatt
-Given: 53
-Receive: 70
« Reply #17 on: December 06, 2006, 05:17:14 05:17 »
Any idea how you add new chip to Winpic800. I have been constantly telling or requesting them to add 16F72 chip , but absolutely no reply.
Please help.
mizk_electro
« Reply #18 on: December 06, 2006, 07:49:06 07:49 »
Hi Everybody!!
NO WORKS !!!!!!
Best regards
Njam
Njam,
What is the other GTP-USB did'nt work to you ? Is it GTP-USB Summer 2005 .... or GTP-USB Plus (latest by the author ) ?
One more thing, which version of winpic800 do you use and what is actually 'No works' (happen) ?
Mizk.
njam
« Reply #19 on: December 06, 2006, 08:51:02 08:51 »
Hi Everybody!!
NO WORKS !!!!!!
Best regards
Njam
Njam,
Mizk.
Other GTP is  GTP-USB Summer 2005 full wersion( I made it) GTP-USB Plus I don't now ,but I think that YES
I,m also owner of laptop with SIS 7001 controller .Best solution in this case buy PCMCIA with USB of good firm (eg.NEC) This problem was on spanish forum .
Njam
mizk_electro
« Reply #20 on: December 06, 2006, 11:20:26 11:20 »
Njam ...
Oooo ... thanks for info.
BTW, I been email by somebody asking help about GTP-USB Lite ( or maybe GTP-USB summer 2005 .... but the schematic is base as included in winpic800 v3.55g ). He made it base on the schematic but fail.
To make story short, I  give my working schematic, pcb & firmware for him to built it (mine are base on hobbypic with some modification to put 28pin & 40pin socket ) .... he built it and succesfull using it at his desktop but not work with his acer laptop (I dont know what type of the chipset in his laptop). The problem is the programmer  cannot finish program PIC  by connect it to the ACER laptop.
After a few days later, he email me and said he replace the transistors (in my schematic ... there are 2 transistor BC547) with ULN2003 ... and he sent the picture of final programmer .... that all  the story ... I think he success (although I send email to get confirmation on this programmer status  but no reply).
As for now I queit busy to finish my project ... maybe I'll try when I'm not so busy. If you have time & would you want to try it ?  and post back  the result here.
mizk_electro
« Reply #21 on: December 07, 2006, 04:54:17 04:54 »
Njam ...
Correction !!! .
That guy also cannot use this programmer with his laptop ( ACER brand but dont what is the chipset inside it). He also use it (with his ACER laptop) via PMCIA Usb adapter.
njam
« Reply #22 on: December 07, 2006, 08:38:13 08:38 »
Hi !
J have ACER laptop too.
This is a link to spanish forum of this problem
http://miarroba.com/foros/ver.php?foroid=59905&temaid=3372845
njam
