November 30, 2024, 06:46:19 06:46
Author Topic: CCS PICC v4 - Impressions  (Read 5415 times)
tavioman
« on: November 01, 2006, 07:22:42 07:22 »
I realy believe that CCS realy screwed up their compiler.
v4 looks really amateur. I don't like the user interface. It occupies very much of the screen.
What do you think about this version?
- Brain juice -
miba
« Reply #1 on: November 01, 2006, 08:13:20 08:13 »
Yes, you are right. The user interface reminds me of the early eighties of the last century - the time before Apple and then Microsoft published their user interface style guides.
8-)
But up to now I haven't testet the rest ...
simacc
The Death Is Immortality
« Reply #2 on: November 05, 2006, 01:56:31 01:56 »
I dont get in trouble with IDE.Why does it bothers you, i cant get? Huh And about compiling i didnt get a bug yet.I think v4 is better than older versions. Wink
« Last Edit: November 05, 2006, 02:18:58 02:18 by simacc » Logged
One Person Cracking Team
pecpys
« Reply #3 on: November 06, 2006, 10:21:47 10:21 »
I don't like user interface in this version because I want work space more than the big menu bar that hard to access. Huh
tavioman
« Reply #4 on: November 06, 2006, 10:25:43 10:25 »
If they relly want to make something fancy they should have done some "skin" function.
I really hate the actual User Interface.
- Brain juice -
krakatoa
-Given: 8
-Receive: 88
« Reply #5 on: December 10, 2006, 08:15:30 08:15 »
CCS is doing this to get in line with the new vista look. Though they have made some progress in that direction, I think the general change is one for the worse.
Tech girls rock!
hate
-Given: 156
-Receive: 355
« Reply #6 on: December 10, 2006, 12:20:35 12:20 »
The ide occupies so much space and isn't useful that much. Is there a way to turn it of?
Regards...
Regards...
robban
-Given: 34
-Receive: 38
Warrior
« Reply #7 on: December 10, 2006, 12:56:43 12:56 »
Regards...
You can always run CCC in the MPLAB IDE or just use a bit more advanced texteditor, like TextPad, which has the capability to launch DOS commands...
Code Warrior
ktanapat
« Reply #8 on: December 10, 2006, 02:22:53 14:22 »
you can use IDE version 3 with compiler CCS v4
hate
-Given: 156
-Receive: 355
« Reply #9 on: December 11, 2006, 06:45:07 06:45 »
I'll try MPLAB. Thnx for the tip!
Regards...
Regards...
wacksbaby
« Reply #10 on: December 22, 2006, 11:03:56 11:03 »
i agree MPLAB is still the best text editor.. i'm using it other than the compilers' own IDE. currently i was able to use it on PBP, Proton, CCS, Hi-Tech, IAR, etc. all that you need to do is to configure your system and MPLAB IDE. you can find everything on the net that says how to configure MPLAB to work with different compilers and you can actually use ICD2 or ICE or any programmer within MPLAB.. well of coarse for a third-party programmer you will need to create an interface for that.
More Power guys
« Last Edit: December 22, 2006, 11:12:29 11:12 by wacksbaby » Logged
densimitre
« Reply #11 on: December 28, 2006, 05:06:08 17:06 »
I had tested RTOS examples from CCS, and in 3.249 never work....but in 4.180 it works...
What do you think about this?
Bye
robban
-Given: 34
-Receive: 38
Warrior
« Reply #12 on: December 29, 2006, 02:29:24 02:29 »
Probably some config. problem...
Code Warrior
raham
« Reply #13 on: January 04, 2007, 05:53:04 05:53 »
the version 4.18 is somewhat stable than the previous versions Smiley
tavioman
« Reply #14 on: January 04, 2007, 07:04:36 07:04 »
 Cheesy Cheesy They already released 4.019 Cheesy Cheesy
- Brain juice -
