February 22, 2025, 09:36:27 09:36
Author Topic: disply 4/7 segment with 2pin(7 segment 2 serial)  (Read 9063 times)
samir_1982
 Warned
-Given: 30
-Receive: 76
« on: January 21, 2009, 06:17:47 06:17 »
This project is very good for 7-segment.only 2pin use for 4/7 segment disply
source code
http://kavirkit.com/kavir/2007/projects/avr/Serial%20LCD-7-SEGMENT%2074164.v2.0.zip
password:www.kavirelectronic.ir
other version
http://kavirelectronic.ir/fa/modules.php?name=Content&pa=showpage&pid=4
 Wink
« Last Edit: January 25, 2009, 08:05:08 08:05 by samir_1982 » Logged
Portable software Flow code orcad9 protel99 Proteus ccs And more
http://www.sonsivri.com/forum/index.php?topic=20330.msg72674#msg72674
LEAS
-Receive: 19
« Reply #1 on: January 24, 2009, 11:00:20 23:00 »
74164 shift register + 16x2 LCD 44780 based. 4-bit interface, but 1 pin of 8031 MCU needed. Proteus simulating picture and files. I program thise, but not build in reality.
LEAS
-Receive: 19
« Reply #2 on: January 25, 2009, 07:06:27 07:06 »
Mega8+Ds1820+WinAVR C compiler to thise theme. It's my experiments.
samir_1982
 Warned
-Given: 30
-Receive: 76
« Reply #3 on: January 25, 2009, 08:02:00 08:02 »
Atmega8+3wire +Easy function+win avr
void LCDclr(void);
void LCDhome(void);
void LCDshiftRight(uint8_t);
void LCDshiftLeft(uint8_t);
void LCDcursorOn(void);
void LCDcursorOnBlink(void);
void LCDcursorOFF(void);
void LCDblank(void);
void LCDvisible(void);
void LCDcursorLeft(uint8_t);
void LCDcursorRight(uint8_t);
void sendByteToRegister(uint8_t);
void LCDenableCommand(void);
void LCDdisableCommand(void);
void LCDenableData(void);
void LCDdisableData(void);
void LCDsendChar(uint8_t); //forms data ready to send to 74HC164
void LCDsendCommand(uint8_t); //forms data ready to send to 74HC164
void LCDinit(void);
// write a byte to the LCD character generator or display RAM
void LCDwritebyte(uint8_t, uint8_t);
void LCDdefinechar(const uint8_t* ,uint8_t);
void LCDclr(void);
void LCDhome(void);
void LCDstring(uint8_t*, uint8_t);
void LCDGotoXY(uint8_t, uint8_t);
void LCDprintData(u32,u32);
void LCDcursorRight(uint8_t);   //shif cursor right by n
void CopyStringtoLCD(const uint8_t*, uint8_t, uint8_t);//copies flash string to LCD at x,y
void LCDshiftRight(uint8_t);   //shift by n characters Right
void LCDshiftLeft(uint8_t);   //shift by n characters Left
void LCDcursorOn(void);      //Underline cursor ON
void LCDcursorOnBlink(void);   //Underline blinking cursor ON
void LCDcursorOFF(void);      //Cursor OFF
void LCDblank(void);         //LCD blank but not cleared
void LCDvisible(void);         //LCD visible
void LCDcursorLeft(uint8_t);   //Shift cursor left by n
http://kavirelectronic.ir/winavr/source/lcd3w/LCD3WIRE.zip
aamir
-Given: 37
-Receive: 229
« Reply #4 on: May 11, 2010, 03:40:08 15:40 »
Please upload it again
9thwonder
« Reply #5 on: June 24, 2010, 01:16:43 13:16 »
kindly upload 7 segment file again as there is some error in opening.
thanx
pushycat
-Given: 219
-Receive: 1448
« Reply #6 on: June 24, 2010, 03:53:40 15:53 »
Here it is: Re-uploaded
http://ifile.it/y49jkmt
http://ifile.it/y49jkmt/LCD3WIRE.zip
thanx
Yes...both the file links in the first post has some errors. Cannot view/download.
