November 27, 2024, 05:51:18 17:51
Author Topic: [ASM] Why this code doesn't work with PIC16F628(A) ??!!  (Read 7217 times)
aehandasa
-Given: 12
« on: December 26, 2008, 02:14:26 02:14 »
I'm a microcontroller newbie, i found this code but it's for PIC16F48. I tested it in the circuit with 16F84 and worked fine, but when i tested it with 16F628 or 16F628A, i wondered for this because what i know that the two PICs can be replaced with each other with no problems.
please, tell me what the reason of non workin for 16F628(A).
Thnx
here's the code:
   LIST    P = 16F84,  F = INHX8M, n = 66
        PIC84   equ     H'03FF'
;       Register Definitions
W                            EQU     H'0000'
F                            EQU     H'0001'
;----- Register Files------------------------------------------------------
INDF                         EQU     H'0000'
TMR0                         EQU     H'0001'
PCL                          EQU     H'0002'
STATUS                       EQU     H'0003'
FSR                          EQU     H'0004'
PORTA                        EQU     H'0005'
PORTB                        EQU     H'0006'
EEDATA                       EQU     H'0008'
EEADR                        EQU     H'0009'
PCLATH                       EQU     H'000A'
INTCON                       EQU     H'000B'
OPTION_REG                   EQU     H'0081'
TRISA                        EQU     H'0085'
TRISB                        EQU     H'0086'
EECON1                       EQU     H'0088'
EECON2                       EQU     H'0089'
;----- STATUS Bits --------------------------------------------------------
IRP                          EQU     H'0007'
RP1                          EQU     H'0006'
RP0                          EQU     H'0005'
NOT_TO                       EQU     H'0004'
NOT_PD                       EQU     H'0003'
Z                            EQU     H'0002'
DC                           EQU     H'0001'
C                            EQU     H'0000'
;----- INTCON Bits --------------------------------------------------------
GIE                          EQU     H'0007'
EEIE                         EQU     H'0006'
T0IE                         EQU     H'0005'
INTE                         EQU     H'0004'
RBIE                         EQU     H'0003'
T0IF                         EQU     H'0002'
INTF                         EQU     H'0001'
RBIF                         EQU     H'0000'
;----- OPTION Bits --------------------------------------------------------
NOT_RBPU                     EQU     H'0007'
INTEDG                       EQU     H'0006'
T0CS                         EQU     H'0005'
T0SE                         EQU     H'0004'
PSA                          EQU     H'0003'
PS2                          EQU     H'0002'
PS1                          EQU     H'0001'
PS0                          EQU     H'0000'
;----- EECON1 Bits --------------------------------------------------------
EEIF                         EQU     H'0004'
WRERR                        EQU     H'0003'
WREN                         EQU     H'0002'
WR                           EQU     H'0001'
RD                           EQU     H'0000'
;       RAM Definition
        __MAXRAM H'AF'
        __BADRAM H'07', H'30'-H'7F', H'87'
;       Configuration Bits
_CP_ON                       EQU     H'3FEF'
_CP_OFF                      EQU     H'3FFF'
_PWRTE_ON                    EQU     H'3FFF'
_PWRTE_OFF                   EQU     H'3FF7'
_WDT_ON                      EQU     H'3FFF'
_WDT_OFF                     EQU     H'3FFB'
_LP_OSC                      EQU     H'3FFC'
_XT_OSC                      EQU     H'3FFD'
_HS_OSC                      EQU     H'3FFE'
_RC_OSC                      EQU     H'3FFF'
;----------- USER REGISTERS ----------------------------------------------
POINTER                      EQU     H'000C'
HCOUNT                       equ     H'000D'
LCOUNT              equ     H'000E'
TEMP1                        EQU     H'002B'
TEMP2                        EQU     H'002C'
TEMP3                        EQU     H'002D'
ZAMAN                        equ     H'002E'
DISP                         EQU     H'002F'
msb             equ     0x29            ;general delay register
lsb             equ     0x2A            ;general delay register
FLCOUNT         equ     H'0027'         ;flas counter
WAITC           equ     H'0026'         ;wait and run
SPECIAL         equ     H'0025'          ;special function register
COUNT1          equ     H'0022'         ;system timer counter
COUNT2          equ     H'0021'         ;system flas timer counter
SYSFUNC         equ     H'0020'         ;system control register
LINE1           EQU     H'0010'
LINE2           EQU     H'0011'
LINE3           EQU     H'0012'
LINE4           EQU     H'0013'
LINE5           EQU     H'0014'
LINE6           EQU     H'0015'
LINE7           EQU     H'0016'
LINE8           EQU     H'0017'
LINE9           EQU     H'0018'
LINE10          EQU     H'0019'
LINE11          EQU     H'001A'
LINE12          EQU     H'001B'
LINE13          EQU     H'001C'
LINE14          EQU     H'001D'
LINE15          EQU     H'001E'
LINE16          EQU     H'001F'
SATIRLAR        EQU     H'0023'
; Display organization
ZERO    EQU     B'00111111'
ONE     EQU     B'00000110'
TWO     EQU     B'01011011'
THREE   EQU     B'01001111'
FOUR    EQU     B'01100110'
FIVE    EQU     B'01101101'
SIX     EQU     B'01111101'
SEVEN   EQU     B'00000111'
EIGHT   EQU     B'01111111'
NINE    EQU     B'01101111'
BLANK   EQU     B'00000000'
DISP1   equ   B'11111110'
DISP2   equ   B'11111101'   ; Mapping of Active Display Selection (PORT_A)
;DISP3   equ     B'11111011'
;DISP4   equ     B'11110111'
DISPOFF   equ   H'FF'
SWITCH   equ   B'00001110'   ; Activate RB1-3 for switch inputs
START
        call    SETCPUPORTSTATUS
        call    STEP_CLEAR
KAYANYAZI_1
         MOVLW  H'0000'
         MOVWF  SATIRLAR
KAYANYAZI_2
        INCFSZ  SATIRLAR
        GOTO    KAYANYAZI_3
        GOTO    KAYANYAZI_4
KAYANYAZI_3
        goto    KAYANYAZI_5
KAYANYAZI_4
        goto    KAYANYAZI_1
KAYANYAZI_5
        MOVLW   H'00'
        ADDWF   SATIRLAR,0
        CALL    FINDSHOW
        movwf   LINE1
        MOVLW   H'01'
        ADDWF   SATIRLAR,0
        CALL    FINDSHOW
        movwf   LINE2
        MOVLW   H'02'
        ADDWF   SATIRLAR,0
        CALL    FINDSHOW
        movwf   LINE3
        MOVLW   H'03'
        ADDWF   SATIRLAR,0
        CALL    FINDSHOW
        movwf   LINE4
        MOVLW   H'04'
        ADDWF   SATIRLAR,0
        CALL    FINDSHOW
        movwf   LINE5
        MOVLW   H'05'
        ADDWF   SATIRLAR,0
        CALL    FINDSHOW
        movwf   LINE6
        MOVLW   H'06'
        ADDWF   SATIRLAR,0
        CALL    FINDSHOW
        movwf   LINE7
        MOVLW   H'07'
        ADDWF   SATIRLAR,0
        CALL    FINDSHOW
        movwf   LINE8
        MOVLW   H'08'
        ADDWF   SATIRLAR,0
        CALL    FINDSHOW
        movwf   LINE9
        MOVLW   H'09'
        ADDWF   SATIRLAR,0
        CALL    FINDSHOW
        movwf   LINE10
        MOVLW   H'0A'
        ADDWF   SATIRLAR,0
        CALL    FINDSHOW
        movwf   LINE11
        MOVLW   H'0B'
        ADDWF   SATIRLAR,0
        CALL    FINDSHOW
        movwf   LINE12
        MOVLW   H'0C'
        ADDWF   SATIRLAR,0
        CALL    FINDSHOW
        movwf   LINE13
        MOVLW   H'0D'
        ADDWF   SATIRLAR,0
        CALL    FINDSHOW
        movwf   LINE14
        MOVLW   H'0E'
        ADDWF   SATIRLAR,0
        CALL    FINDSHOW
        movwf   LINE15
        MOVLW   H'0F'
        ADDWF   SATIRLAR,0
        CALL    FINDSHOW
        movwf   LINE16
        MOVLW   D'15'
        MOVWF   ZAMAN
        CALL    STEP_DELAY
        goto    KAYANYAZI_2
;        org     h'0100'
FINDSHOW
;KIRIKKALE ENDUSTRI MESLEK LISESI ELEKTRONIK BOLUMU
showdata
        addwf   PCL,1
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000001'     ;
        retlw   B'00000001'     ;
        retlw   B'01111111'     ;
        retlw   B'00000001'     ;
        retlw   B'00000001'     ;
        retlw   B'00000000'
        retlw   B'00111111'     ;
        retlw   B'01000000'     ;
        retlw   B'01000000'     ;
        retlw   B'01000000'     ;
        retlw   B'00111111'     ;
        retlw   B'00000000'
        retlw   B'01111111'     ;
        retlw   B'00001001'     ;
        retlw   B'00011001'     ;
        retlw   B'00101001'     ;
        retlw   B'01000110'     ;
        retlw   B'00000000'
        retlw   B'01111111'     ;
        retlw   B'01001001'     ;
        retlw   B'01001001'     ;
        retlw   B'01001101'     ;
        retlw   B'00110110'     ;
        retlw   B'00000000'
        retlw   B'00111110'     ;
        retlw   B'01000001'     ;
        retlw   B'01000001'     ;
        retlw   B'01000001'     ;
        retlw   B'00111110'     ;
        retlw   B'00000000'
        retlw   B'00000000'
        retlw   B'00000000'
        retlw   B'00000000'
        retlw   B'00000000'
        retlw   B'00000000'
        retlw   B'00000000'
        retlw   B'01111111'     ;
        retlw   B'01001001'     ;
        retlw   B'01001001'     ;
        retlw   B'01001001'     ;
        retlw   B'01000001'     ;
        retlw   B'00000000'
        retlw   B'01111111'     ;
        retlw   B'01000000'     ;
        retlw   B'01000000'     ;
        retlw   B'01000000'     ;
        retlw   B'01000000'     ;
        retlw   B'00000000'
        retlw   B'01111111'     ;
        retlw   B'01001001'     ;
        retlw   B'01001001'     ;
        retlw   B'01001001'     ;
        retlw   B'01000001'     ;
        retlw   B'00000000'
        retlw   B'00111110'     ;
        retlw   B'01000001'     ;
        retlw   B'01000001'     ;
        retlw   B'01000001'     ;
        retlw   B'00100010'     ;
        retlw   B'00000000'
        retlw   B'00000001'     ;
        retlw   B'00000001'     ;
        retlw   B'01111111'     ;
        retlw   B'00000001'     ;
        retlw   B'00000001'     ;
        retlw   B'00000000'
        retlw   B'01111111'     ;
        retlw   B'00001001'     ;
        retlw   B'00011001'     ;
        retlw   B'00101001'     ;
        retlw   B'01000110'     ;
        retlw   B'00000000'
        retlw   B'00111110'     ;
        retlw   B'01000001'     ;
        retlw   B'01000001'     ;
        retlw   B'01000001'     ;
        retlw   B'00111110'     ;
        retlw   B'00000000'
        retlw   B'01111111'     ;
        retlw   B'00000100'     ;
        retlw   B'00001000'     ;
        retlw   B'00010000'     ;
        retlw   B'01111111'     ;
        retlw   B'00000000'
        retlw   B'01000001'     ;
        retlw   B'01111111'     ;
        retlw   B'01000001'     ;
        retlw   B'00000000'
        retlw   B'00111110'     ;
        retlw   B'01000001'     ;
        retlw   B'01000001'     ;
        retlw   B'01000001'     ;
        retlw   B'00100010'     ;
        retlw   B'00000000'
        retlw   B'00100110'     ;
        retlw   B'01001001'     ;
        retlw   B'01001001'     ;
        retlw   B'01001001'     ;
        retlw   B'00110010'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
        retlw   B'00000000'     ;
return
STEP_CLEAR
        movlw   B'00000000'
        movwf   LINE1
        movwf   LINE2
        movwf   LINE3
        movwf   LINE4
        movwf   LINE5
        movwf   LINE6
        movwf   LINE7
        movwf   LINE8
        movwf   LINE9
        movwf   LINE10
        movwf   LINE11
        movwf   LINE12
        movwf   LINE13
        movwf   LINE14
        movwf   LINE15
        movwf   LINE16
        MOVLW   D'50'
        MOVWF   ZAMAN
        CALL    STEP_DELAY
RETURN
STEP_DELAY
        clrwdt
       ;call    DELAYSYS                        ;20 msec delay
        CALL    RUNTIME
        decfsz  ZAMAN
        goto    STEP_DELAY
return
RUNTIME
WRITEDISP
        ;test
        ;call    delay20
        ;test
        clrwdt
        movlw   D'0'
        movwf   PORTA
        movf    LINE1,0
        movwf   PORTB
        call    delay1
        clrwdt
        movlw   D'1'
        movwf   PORTA
        movf    LINE2,0
        movwf   PORTB
        call    delay1
        clrwdt
        movlw   D'2'
        movwf   PORTA
        movf    LINE3,0
        movwf   PORTB
        call    delay1
        clrwdt
        movlw   D'3'
        movwf   PORTA
        movf    LINE4,0
        movwf   PORTB
        call    delay1
        clrwdt
        movlw   D'4'
        movwf   PORTA
        movf    LINE5,0
        movwf   PORTB
        call    delay1
        clrwdt
        movlw   D'5'
        movwf   PORTA
        movf    LINE6,0
        movwf   PORTB
        call    delay1
        clrwdt
        movlw   D'6'
        movwf   PORTA
        movf    LINE7,0
        movwf   PORTB
        call    delay1
        clrwdt
        movlw   D'7'
        movwf   PORTA
        movf    LINE8,0
        movwf   PORTB
        call    delay1
        clrwdt
        movlw   D'8'
        movwf   PORTA
        movf    LINE9,0
        movwf   PORTB
        call    delay1
        clrwdt
        movlw   D'9'
        movwf   PORTA
        movf    LINE10,0
        movwf   PORTB
        call    delay1
        clrwdt
        movlw   D'10'
        movwf   PORTA
        movf    LINE11,0
        movwf   PORTB
        call    delay1
        clrwdt
        movlw   D'11'
        movwf   PORTA
        movf    LINE12,0
        movwf   PORTB
        call    delay1
        clrwdt
        movlw   D'12'
        movwf   PORTA
        movf    LINE13,0
        movwf   PORTB
        call    delay1
        clrwdt
        movlw   D'13'
        movwf   PORTA
        movf    LINE14,0
        movwf   PORTB
        call    delay1
        clrwdt
        movlw   D'14'
        movwf   PORTA
        movf    LINE15,0
        movwf   PORTB
        call    delay1
        clrwdt
        movlw   D'15'
        movwf   PORTA
        movf    LINE16,0
        movwf   PORTB
        call    delay1
        movlw   H'00'
        movwf   PORTB
        RETURN
SETCPUPORTSTATUS
        bsf     STATUS,RP0
        movlw   H'00'
        movwf   TRISB           ;PORTB pins : O-O-O-O-O-O-O-O
        movlw   B'00000000'
        movwf   TRISA           ;PORTA pins : X-X-X-O-O-O-O-O
        bcf     STATUS,RP0
        movlw   H'00'
        movwf   PORTA
        movwf   PORTB
RETURN
;*-     Delay Routines                                                     -*
vlong
   movlw   0xff            ;very long delay, approx 200msec
        movwf   msb
        goto    d1
        movlw   .26
        movwf   msb
        CLRWDT
        CALL    RUNTIME
        goto    d1
delay20                         ;20 msec delay
        movlw   .26
        movwf   msb
        goto    d1
delay16                         ;16 msec delay
        movlw   .21
        movwf   msb
        goto    d1
delay1                          ;approx 750nsec delay
        movlw   .1
        movwf   msb
d1      movlw   0xff
        movwf   lsb
d2      decfsz  lsb,F
        goto    d2
        decfsz  msb,F
        goto    d1
        return
FINISH
        goto    START
end
-Given: 405
-Receive: 545
« Reply #1 on: December 26, 2008, 05:24:08 05:24 »
READ THE DATASHEET ABOUT THE COMPARATOR
and how to turn it off (make it like a 16F84)
-Given: 834
-Receive: 4322
« Reply #2 on: December 26, 2008, 06:43:53 18:43 »
You may also want to Google replace 16F84 with 16F628
sohel
-Given: 167
-Receive: 149
« Reply #3 on: December 27, 2008, 10:51:52 10:51 »
Have u any design with proteus? i think this code comes from turkis friend. can u send me all thing with design.  Huh
savnik20
-Given: 37
-Receive: 401
« Reply #4 on: December 27, 2008, 12:51:52 12:51 »
Put at the begin of your code this lines:
   movlw   0x07
   movwf   CMCON
-Given: 834
-Receive: 4322
« Reply #5 on: December 27, 2008, 03:18:56 15:18 »
   movlw   0x07
   movwf   CMCON
nice post, but what has the original poster gained by it, how to cut&paste, or how to search and learn.?
tAhm1D
-Given: 103
-Receive: 180
« Reply #6 on: January 08, 2009, 03:28:21 15:28 »
Hi aehandasa,
Being new, you should not just follow the code of others, rather, you should try to learn/understand the tidbits of the Program itself. You are not even clear about how configuration bits are placed in the program and many unnecessary things are included in the program. The person who has written this program, is also not clear about writing program in ASM. I tried to rewrite your program for pic 16F628A for you but I found that it is of  12 page long and many irrelevant things are included. Please give the design/schematic of what you want to do and I will make a concise program in ASM for both 16F84 and 16F628A for your easy understanding. Good luck.
« Last Edit: January 08, 2009, 03:31:46 15:31 by tAhm1D » Logged
aehandasa
-Given: 12
« Reply #7 on: January 08, 2009, 03:55:17 15:55 »
Thnx fo all
pickit2, i have searched for disabling comparator and found the mentioned result above, but the program doesn't run in the right way.
this circuit is from turkish site ( i think ) and this is the schematic "attached"
NOTE : int the diagram, Q7 is in the false position. i think you know the right one  Grin   , And the collectors of Q17-Q23 is connected to Vcc.
« Last Edit: January 08, 2009, 03:57:31 15:57 by aehandasa » Logged
aehandasa
-Given: 12
« Reply #8 on: January 08, 2009, 05:19:09 17:19 »
This is the site link :  http://elektronikce.com/7_16.html
sohel
-Given: 167
-Receive: 149
« Reply #9 on: January 09, 2009, 07:47:34 19:47 »
go here for ur project.
http://www.sonsivri.com/forum/index.php?topic=4872.0;all
and also look at ur file which now work for both.
please step by step by urself and see what  he want  to show u. Huh Wink
here new updeted for ur design
« Last Edit: January 25, 2009, 03:04:23 15:04 by sohel » Logged
aehandasa
-Given: 12
« Reply #10 on: January 24, 2009, 02:32:02 02:32 »
Thank you very much sohel , i'll try the provided code.
Thnx AgIaN
aehandasa
-Given: 12
« Reply #11 on: January 25, 2009, 04:15:07 04:15 »
OK,
I tested the modified code and the result was that the first two columns is flashing and want to run but it cant, i note that when i youch any ground terminal the "TUR" test only appears and return to run these letters again plus the 3rd row from bottom is not powered.
You can see all things in this clip :                     http://www.youtube.com/watch?v=sdXcbmHhDkM
i tried two PICs (16f628A)  while  i tested it with the original F84A and it worked well.
i dont know if the reason is some thing like stray capacitance or electric properties of F628A that is differ from F84A, but i will search and hope if you know to tell me, at least think with me.
-Given: 834
-Receive: 4322
« Reply #12 on: February 08, 2009, 12:11:05 00:11 »
I think your problem is setting the config fuses, I would have your code just switch row B0 on, and light the 16 leds in that row at a rate you can see whats happening, in a runnig led or in count up mode. (...*....) or (....*.**)
when you have top row running led move to B1, and so on. till all rows are proven.
