samir_1982
Warned
-Given: 30
-Receive: 76
« Reply #1 on: December 24, 2008, 06:00:19 06:00 » |
Hi 2,Copy the license files there! I not found this license file. pls share license file tnx
praksk
-Given: 289
-Receive: 1302
« Reply #2 on: December 24, 2008, 06:10:02 06:10 » |
Please go through install_nfo. The license files are available in the archive.
ajak
-Given: 199
-Receive: 77
« Reply #3 on: December 24, 2008, 06:27:33 06:27 » |
Read the instruction please.. It is very easy to do..
sonsivritwchen
-Receive: 15
« Reply #4 on: December 24, 2008, 08:22:02 08:22 » |
The rapidshare is very very slow, could someone upload to other sites. Please.
samir_1982
Warned
-Given: 30
-Receive: 76
« Reply #5 on: December 24, 2008, 08:49:42 08:49 » |
OK Best regard tnx
spasbyspas
-Given: 735
-Receive: 366
« Reply #6 on: December 24, 2008, 09:31:59 09:31 » |
CCS_PCWHD v4.084 Other link: http://ifile.it/9ny4uli
ajak
-Given: 199
-Receive: 77
« Reply #7 on: December 24, 2008, 09:32:19 09:32 » |
Here it is, for those who cannot download in rapidshare... http://ifile.it/9ny4uli/ccs_4.084.rar
preatorian
-Given: 16
« Reply #8 on: December 24, 2008, 12:04:59 12:04 » |
duende_azul
-Given: 117
-Receive: 1262
« Reply #9 on: December 24, 2008, 03:30:43 15:30 » |
FriskyFerret
-Given: 513
-Receive: 360
Put it in, take it out.
« Reply #10 on: December 24, 2008, 03:57:00 15:57 » |
Did you test that the keygen can create a valid license for v4.084?
preatorian
-Given: 16
« Reply #11 on: December 24, 2008, 04:08:46 16:08 » |
Hi all, I installed it over the previous version 4.074 and the existing reg files are doing great job.
sfabris
-Given: 8
-Receive: 23
« Reply #12 on: December 24, 2008, 05:58:18 17:58 » |
Hi all,
finally PCWHD == we can build also on dspic and pic24. I was missing this!
Thanks,
sf
LithiumOverdosE
-Given: 383
-Receive: 588
« Reply #13 on: December 25, 2008, 02:58:43 02:58 » |
I tried installing this version over previous 4.074 PCWHD and it downgraded it to only PCW. Then I deinstalled everything, cleaned up registry and made a fresh install using provided license files. It also reported PCW version.
Are you sure this is PCWHD version at all? It sure looks like it's a PCW...
« Last Edit: December 25, 2008, 03:01:49 03:01 by LithiumOverdosE »
yahoo
-Given: 56
-Receive: 111
« Reply #14 on: December 25, 2008, 04:40:28 04:40 » |
After the installation check HELP -> ABOUT and you will see what compiler versions are installed. For me - all changed from 4.074 to 4.084. For sure it is a full update!
praksk
-Given: 289
-Receive: 1302
« Reply #15 on: December 25, 2008, 05:50:35 05:50 » |
I tried a PIC24 project and it works.
pc04
-Given: 254
« Reply #16 on: December 25, 2008, 08:15:13 08:15 » |
hi, working ok for me thanks pc04
LithiumOverdosE
-Given: 383
-Receive: 588
« Reply #17 on: December 26, 2008, 02:06:24 14:06 » |
Yeah, I know all versions got updated to 4.084 but the overall version is PCW and not PCWHD. I tried fresh install on other PC and the same result was achieved- it is a PCW version. I say so also at the top of the screen. Same thing happens when I used keygen. With the 4.074 version everything is fine and it registers as PCWHD.
duende_azul
-Given: 117
-Receive: 1262
« Reply #18 on: December 27, 2008, 06:32:04 18:32 » |
Yes I test and work fine. Yeah, I know all versions got updated to 4.084 but the overall version is PCW and not PCWHD. I tried fresh install on other PC and the same result was achieved- it is a PCW version. I say so also at the top of the screen. Same thing happens when I used keygen. With the 4.074 version everything is fine and it registers as PCWHD.
This version is PCWHD, I installed over a previous version (4.074, and in "about dialog box" appears PCD compiler.
LithiumOverdosE
-Given: 383
-Receive: 588
« Reply #19 on: December 28, 2008, 04:23:38 16:23 » |
Hm, now that's strange. It really does say PCWHD in the About box. However top status bar still shows only PCW. However it does compile dsPic projects so I guess it really is PCWHD.
mitsos
-Given: 3090
-Receive: 4596
« Reply #20 on: December 28, 2008, 07:34:56 19:34 » |
hi
just look at the Devices folder of the installation. Are there files for dspics? Are you try to compile a simple program with any type of the supported dspics? Both answers are yes, so don't discuss anymore for this last version PCWHD.
regards mitsos
Dembo
« Reply #21 on: December 29, 2008, 04:19:22 16:19 » |
Hi All
On 4.084 ICDS doesn't work - can't connect to ICD (tested with Microchip ICD1, 20MHz/40MHZ modified) - it was OK with 4.078 Any idea? Does someone have also such problem?
mitsos
-Given: 3090
-Receive: 4596
« Reply #22 on: December 30, 2008, 11:19:58 11:19 » |
hi
I agree, in the mplab simulator for dspics is working ok, I have problems when I try the simulation in proteus. So, it's a little bit confussing if the compiler supports, like the previous 4.068 version, the dspics.
I waiting any comments that clear this topic.
regards mitsos
kiashee
-Given: 80
« Reply #23 on: December 31, 2008, 05:16:28 17:16 » |
Hi... I just intalled this version over my 4.074 which was fixed by the keygen from 4.068. it worked fine for me. PCWHD were all updated.
pama
-Receive: 28
« Reply #24 on: January 01, 2009, 11:52:24 23:52 » |
Hi, on this new version 4.084, the ICD stand alone soft. is not working with my icd clone (serial with the ftdi converter). I get something 'wrong response from the ICD unit..' But is stil working without problem on PCW environment! So there are some changes on the ICD software. I'm also interested to know the reason.
