mhtplsh
-Given: 46
-Receive: 61
« Reply #25 on: April 05, 2009, 12:22:43 12:22 » |
If u can go to Kolkatta in India u can get many things u require. It is most near to u. To best of my knowledge, few dealers in Kolkatta & Bangladesh hv good arrangements. Just try it. I think even dhala dealer hving contact in Kolkatta can get u the items u require.
sohel
-Given: 169
-Receive: 149
« Reply #26 on: April 06, 2009, 08:49:58 20:49 » |
can u help me to get which u advice (chemical or hammer or core or drill)? which one?
jzaghal
-Given: 502
-Receive: 55
« Reply #27 on: April 07, 2009, 04:59:24 04:59 » |
Hi Guys,
I wish to share my little experience here.
If I want to dismantle a ferrite transformer, I usually do not use chemicals!!
Best method to use, is get yourself a small toaster oven and use it to heat up the ferrite thing.
after say ten minutes you can take the whole ferrite apart in no time.
Try to increase the temp. gradually for the first time, to see which temp. works for you??
I have success 100% all the time.
Cheers.
download_crux
-Given: 48
-Receive: 63
« Reply #28 on: April 07, 2009, 07:42:56 07:42 » |
tAhm1D
-Given: 103
-Receive: 180
« Reply #29 on: April 08, 2009, 07:17:39 19:17 » |
Hi, Using chemical to dismantle a Ferrite Transformer is clearly illustrated in EPE magazine of July,2006 in page no.34. But I found the system is inefficient and could not be successful in dismantling even keeping the core for the whole night inside a pot filled with chemical. But the system mentioned by jzaghal is somehow is efficient. In that method, when I tried,my success rate was cent percent. I used slightly different method. First, put a steel plate ( locally known as Taba, on which Chapatti is heated) on gas stove/fire. Then put few Ferrite Cores on the plate and keep on heating and after few minutes when a chit chit sound can be heard, then remove the cores from the plate and using some cloth/glove to cover hand as the cores are heated, take the 2 parts of the Core apart safely. Use good hand gloves and use both the hands to make the Core apart with applying necessary force. In this method, you can reuse the copper wire by unwinding the wire from the Bobbin but for that you must have good patience. Hope, this will solve your problem.
« Last Edit: April 08, 2009, 07:22:31 19:22 by tAhm1D »
sohel
-Given: 169
-Receive: 149
« Reply #30 on: April 08, 2009, 07:37:24 19:37 » |
Hi Guys,
Cheers.
Yes U r right, its work 110% with microwave oven  thanks
« Last Edit: April 09, 2009, 01:30:52 13:30 by sohel »
jzaghal
-Given: 502
-Receive: 55
« Reply #31 on: April 09, 2009, 05:58:05 17:58 » |
Sohel,
I mentioned a toaster oven. I wouldn't dare put it in a microwave!!
Did you really put it in a microwave?? or are you joking!!
Cheers.
sohel
-Given: 169
-Receive: 149
« Reply #32 on: April 10, 2009, 07:09:20 07:09 » |
yes and not for 10 min only 40 sec . i am not joking. try it. its a very easy way without chit chit sound.
rajudp
« Reply #33 on: April 10, 2009, 07:59:33 07:59 » |
you mean you place the all unit ( metal parts including coils and pins ) . but i heard we cant keep metal parts in microwave
sohel
-Given: 169
-Receive: 149
« Reply #34 on: April 10, 2009, 08:37:30 08:37 » |
which metal part u mention? surface coper plate? why u not go for expriment, my mother also afraid for her oven, then i buy one for that and test it without any damege. it works.  please note on " DANGER  High temp" if u burnt ur hand u cant claim to sonsivri.
tAhm1D
-Given: 103
-Receive: 180
« Reply #35 on: April 10, 2009, 08:53:44 08:53 » |
Hi mhtplsh, Can you please help me to find out some source for ferrite core type EE/ETD/EI in Kolkata, so that I can collect those from Kolkata. Last time I tried from Kolkata, but could not get it and hence collected from Delhi. In Bangladesh, only ETD39/ECL40 and EI 33 available. So, I had to test high power smps inverter with those using in series. But, it will be better if large sized cores are used. Please help regarding address if possible on your part. I require ETD45/55 or EE45/55 type.
tAhm1D
-Given: 103
-Receive: 180
« Reply #36 on: April 10, 2009, 10:11:04 10:11 » |
Hi rajudp, Experiment by keeping Ferrite Core inside Microwave Oven creates a serious security hazard and should be avoided in any case. The reasons are as follows: Microwave cannot penetrate Metal. Microwave cannot penetrate Metal and object like Ferrite Core. So, if you put any metal container with food inside the Microwave oven, the food cannot be heated and so the wave cannot be absorbed by the food inside. That’s why, metal container is not used inside the Microwave Oven. In this case, if you put Ferrite Core inside the Oven the serious hazard will be the resonance of the magnetron tube itself. Here,the microwave is run without an object to absorb the radiation, and hence a standing wave will form. The energy is reflected back and forth between the tube and the cooking chamber. This may cause the Magnetron tube to 'cook' itself and burn out. A serious fire hazard will be there. Electric Currents. Microwaves are a form of electromagnetic waves, which are oscillating electric and magnetic fields. The oscillating electric fields cause electric currents in metals and other conductors. These currents may cause harm in the walls of the cooking chamber, which may cause fire and damage the Oven itself by damaging the walls of the cooking chamber. Moreover,in this case,the severe electric field may damage the internal structure of the Ferrite Metal itself. So, better avoid experimenting by placing Ferrite Core inside Microwave Oven. It is very dangerous. Better use the Toaster advised by jzaghal or use electric/gas oven.  The effects of severe electrical discharge through the metal if placed inside Microwave Oven.
« Last Edit: April 10, 2009, 10:16:56 10:16 by tAhm1D »
sohel
-Given: 169
-Receive: 149
« Reply #37 on: April 10, 2009, 05:24:05 17:24 » |
hmm
its your choice, dont test with micro oven. its true that two E55 disassemble with goodluck. its burnt small wire. please dont test it with microwave oven and also sorry for exprement.
« Last Edit: April 11, 2009, 08:37:05 08:37 by sohel »
HackerNo.1
-Receive: 27
« Reply #38 on: April 25, 2009, 05:42:16 17:42 » |
Hi, I think heating on steel plate is better system. I applied this system and successfully dismantle some EE44. According to the advice of Sohel did not try with Micro Oven.
tAhm1D
-Given: 103
-Receive: 180
« Reply #39 on: July 03, 2009, 08:38:21 20:38 » |
Here is a circuit for PSU for 24V @ 1.5A and 5V @ 1A. It is made using TOP246 from TOP-GX series of flyback converter ICs from Power Integrations Co. of USA. I, practically made a power supply with this circuit and still it is working fine. As it is a reliable circuit, one can try this. I have uploaded it to ifile.it. Here is the link: http://ifile.it/rse43zu
tAhm1D
-Given: 103
-Receive: 180
« Reply #40 on: July 09, 2009, 08:49:11 08:49 » |
Hi all, Please find here a sine wave inverter made using PIC microcontroller. The context includes both hardware and software. Enjoy! http://rapidshare.com/files/253699178/Sine_Wave_Inverter_with_PIC.PDF
« Last Edit: July 09, 2009, 08:52:46 08:52 by tAhm1D »
arash_tah
« Reply #41 on: July 14, 2009, 04:14:25 04:14 » |
Hi every body I noticed the second edition of "Switch mode Power Supply Hand book by Keith Billing" have been released. who has this new edition? please share REGARD
qolpa
-Given: 19
« Reply #42 on: August 11, 2009, 07:59:13 07:59 » |
links dead  could anyone upload them again please? thanks in advance regards
when everthing else fails, read the instructions
arash_tah
« Reply #43 on: August 11, 2009, 03:56:10 15:56 » |
Please upload again
BRANCA
-Given: 127
-Receive: 68
« Reply #44 on: August 12, 2009, 02:11:06 14:11 » |
for tAhm1D Can you reup all circuits and SMPS books,especially Maniktala?No link working! Also-maybe in your collection is available Sanjaya Maniktala Troubleshooting Switching Power Converters.
G.A.Chaudhry
« Reply #47 on: March 23, 2010, 11:52:37 11:52 » |
Plz upload this book: Power-Switching Converters Second Edition Simon Ang, Alejandro Oliva CRC Press 2005 thanks in advance
carbontracks
-Given: 20
« Reply #48 on: April 17, 2010, 03:25:55 15:25 » |
I gotta second this request. I've read his articles and they're fantastic; I'd love an entire reference book by him. Also, the first edition link is dead. Thanks
mastertushar
-Given: 19
« Reply #49 on: May 28, 2010, 04:21:39 04:21 » |
Hi, I've decided to open a thread to share some of the SMPS resources I have in my collection. Here's a boost-circuits collection of mine: http://rapidshare.com/files/175180866/Boost_Circuits.rarMore to come.... EDIT:NO coded links there is no need for them now, the 7 posting rule went ages agao wizpic links r dead can u reupload??
