November 29, 2024, 03:34:34 03:34
Author Topic: problem with lcd  (Read 3230 times)
alejandro
« on: October 04, 2006, 06:11:01 18:11 »
Hi, I hope someone can help me
I have built an automatic trasnfer switch for genset
it makes all necesary to turn on the motor of the
generator when the mains goes down.
The circuit has a 18f452 and an LCD 2x16 Truly
the problem is that sometimes the lcd after hours of working ok
hangs up and the display becomes black ( the pic still works ok)
I put big capacitors in the power source (4700uF - 7805-4700uF)
but the problem persists
nikhilele
-Receive: 22
« Reply #1 on: November 04, 2006, 09:37:17 09:37 »
Have u tried connecting a different new lcd.
what others things u can do provide a switch (Transistor based) to LCD
and reinit lcd after some fixed intervals like in few minutes.
hansolo
« Reply #2 on: November 04, 2006, 01:28:59 13:28 »
This is a common problem with LCD.
The LCD driver circuit tend to hang when large load sharing the same line switches on/off.
What you can do is keep re-initilise the LCD after every few minutes irrespective weather the LCD hang or not. That is what I do.
alejandro
« Reply #3 on: April 08, 2008, 12:51:22 12:51 »
hansolo
thank you very much, your advice was the solution
Epegic
« Reply #4 on: April 18, 2008, 08:28:52 08:28 »
"The LCD driver circuit tend to hang when large load sharing the same line switches on/off."
I don't agree with this statement, there must be something wrong with the software. Re-initilse periodically can cover up the real problem but not a proper solution.
