chithanh04dt2
-Given: 97
« on: December 14, 2008, 05:53:56 17:53 » |
Hello everyone. i'm building project with ps2 keyboard. i'm using flowcode to programming ps2 keyboard interface with 16f877a, then display character on LCD. But i have some error when pic 16f877a receive data, when i press "A" on keyboard, LCD display "L".  Sorry for my Englis. Thanks.
Sorry for my English. Regard !
h96089
« Reply #1 on: January 15, 2009, 05:55:51 05:55 » |
i have deal with ps2 computer pheripheral last time in my final year project. I wish to check your code for error, but i cant read your asm code properly. Can you upload your assembly code with text file format. By the way, from direct inspection of the error that you show to me, i think you most likely are having error in look up table pointer, which means that your controller do accept the correct keyboard signal, but in the process to map it to the actual display character, your code some how map it wrongly.
kayvee
-Given: 105
-Receive: 362
« Reply #2 on: January 19, 2009, 01:05:13 13:05 » |
I find it useful in this type of project where you are attempting to track down a problematic section of code, is to include some simple debug routines and hardware. On that device it is a simple matter to add a debug routine to intercept the data from your keyboard routine and transmit it out with the onboard hardware UART via a MAX232 to your PC com port. I normally have a MAX232 board lying around which I can tack on in the event that it's needed. This way you can isolate where the problem lies.
Are you receiving and displaying other keypresses correctly, by the way?
sukumar
-Receive: 47
« Reply #3 on: February 06, 2009, 06:32:50 06:32 » |
Hi all,
Interfacing PS2 keyboard is not that much difficult. Here is the algorithm,
1. Store the PS2 keyboards "key values" in a array. 2. Initialise the capture module for every falling edge....capture pin sholud be connected to CLK(not data). 3. Wait for the first falling edge by polling CCPxIF for 1 and clear interrupt flag 4. detect the next falling edge and read the data from the data pin.....collect it in a variable 5. Disable capture 6. wait for 40ms 7. process the data......suppose the data is 20---read the character from 19th position of the array.
note: This is algorithm for all the languages...you can directly write assembly,c codes by using this algorithm
Regards, sukumar
Regards, M.Sukumar Never say No
chithanh04dt2
-Given: 97
« Reply #4 on: February 18, 2009, 03:39:03 03:39 » |
Ok, thanhk all member for your help. My project was successfully
kayvee
-Given: 105
-Receive: 362
« Reply #5 on: February 18, 2009, 07:20:44 07:20 » |
That is good news, chithanh04dt2, good job. Can you tell us what the problem was, how you resolved it, etc. It may be useful to someone else too.
newboy
-Given: 42
-Receive: 20
« Reply #6 on: February 18, 2009, 09:01:28 09:01 » |
Can you share this succesfull project with us  I like to make it. Hope you dont mind to share it. Thanks
DarthPic
-Given: 751
-Receive: 75
« Reply #7 on: February 18, 2009, 09:44:09 09:44 » |
Hi everyone  I have done a similar project in Jan-09 for my robot and it work well. The source are attached to the post. Just the German keyboard Layout is done , for the English and French ASCII code you have just to modify them in the keyboard.h file.(ATM it's a copy/paste from the German one) That is coded in C with CCS for a little PIC16F688  It use only a little part of the cpu flash , so you can add other country kb without problem in extending the keyboard.h file if needed. The file name say "USB_Keyboard_16F688" but it's for PS2 too. Regards. PS : sorry for my English
Theory is when we know everything but nothing work ... Practice is when everything work but no one know why  ...
chithanh04dt2
-Given: 97
« Reply #8 on: February 23, 2009, 03:15:29 15:15 » |
Actually my program very nice, i had a mistake between Keyboard PS2 code and ASCII code, so have differrent when i press key on the keyboard and then print it on LCD.
I use crystal 20MHz, adding Look up Table (LUT)
@newboy.
It very easy to make, see post's sukumar and other, me too.
« Last Edit: February 23, 2009, 03:19:30 15:19 by chithanh04dt2 »
mr_byte31
-Given: 75
-Receive: 144
« Reply #9 on: March 02, 2009, 12:49:20 00:49 » |
look you can use mukroC it contains lib for ps2 as i think try it
DarthPic
-Given: 751
-Receive: 75
« Reply #10 on: March 02, 2009, 01:22:27 13:22 » |
@ chithanh04dt2 I have get the same strange PS2 -> ASCII when i have start my project. That is a relevant error , it depend if your rs232 data are normal or inverted. For use one of the rs232 mode i have add a extra rs232 setup in my code . Then i just comment or uncomment the setup i need ... Here the rs232 setup from my project coded with CCS C: for invert mode i do ... //#use rs232(baud=9600, xmit=PIN_C4, rcv=PIN_C5, FORCE_SW, BITS=8, STOP=1, PARITY=N) #use rs232(baud=9600, xmit=PIN_C4, rcv=PIN_C5, FORCE_SW, BITS=8, STOP=1, PARITY=N, INVERT)
for normal mode i do ... #use rs232(baud=9600, xmit=PIN_C4, rcv=PIN_C5, FORCE_SW, BITS=8, STOP=1, PARITY=N) //#use rs232(baud=9600, xmit=PIN_C4, rcv=PIN_C5, FORCE_SW, BITS=8, STOP=1, PARITY=N, INVERT)
I hope it will resolve your problem
chithanh04dt2
-Given: 97
« Reply #11 on: March 06, 2009, 04:47:08 04:47 » |
Thank DarthPic, but my project was finished ago one month. Your way is nice,
