December 24, 2024, 01:17:09 13:17
Author Topic: Work MMC C Code & Proteus Sim File - Tested  (Read 16899 times)
Rafet32
-Given: 22
-Receive: 24
« on: July 26, 2006, 09:41:37 09:41 »
Download file include  tested mmcdos.c code, example program and proteus simulation files.
This paragraph is Turkish
[indent]Merhaba
 MMC ile ilgili denediğim çalışan bir uygulamayı sizlerle paylaşmak istedim.
 Ekteki dosyalarda kaynak kodları (CCS), mmcdos.c ve Proteus 6.9 ile yapılmış simülasyon  dosyası mevcuttur.
Proteus 6.9 sp4 de mmc kütüphanesi mevcuttur.
Faydalı olmak dileği ile....
[/indent]Turkish paragraph end.
CCS and Proteus 6.9SP4 simulation File : Download
Proteus circuits
Simulation screen
WiriyaMcE07
« Reply #1 on: July 26, 2006, 10:20:17 10:20 »
i can't download Form rapidshare.
your can send to mail                [email protected]
thank you
Rafet32
-Given: 22
-Receive: 24
« Reply #2 on: July 26, 2006, 11:02:15 11:02 »
File ise atachment message
Future
« Reply #3 on: July 26, 2006, 07:13:52 19:13 »
can this code create and write new files?
__jerek__
« Reply #4 on: July 27, 2006, 10:34:48 10:34 »
excuse-me but, how can I instal this file in my Protues? In the file don't have the model or library file.
thank you
Rafet32
-Given: 22
-Receive: 24
« Reply #5 on: July 27, 2006, 01:37:07 13:37 »
I'm use Proteus 6.9 sp4. This version include mmc library.
Old version proteus mmc library atachment message.
MMC library web site: http://www.advdigitaltech.com/index.php?PHPSESSID=c62312f7200de950ae6ca05944aab4cf
nomilayyah
« Reply #6 on: July 27, 2006, 02:50:22 14:50 »
i am not able to work on proteus .file is not running on rs232 window.only first line run.how to run
Rafet32
-Given: 22
-Receive: 24
« Reply #7 on: July 27, 2006, 06:18:05 18:18 »
Run simulation.
Use menu Debug -> Virtual Terminal open virtual terminal windows.
nomilayyah
« Reply #8 on: July 28, 2006, 05:11:39 05:11 »
i had service pack 4 proteus 6.9 but i had downloaded from the same site at  http://www.sonsivri.com.but may be this crack is not  working.i am getting only first line that is hadi hayirlist umairm calisir.but not more then one line.wht is problem.i had opened vertiual terminal but only one line.plz help me
also i am attaching cof file to ur programe.thanks
nomilayyah
« Reply #9 on: July 28, 2006, 06:27:17 06:27 »
or if u had working proteus 6.9sp4 then plz upload it to oxyshare.com
Rafet32
-Given: 22
-Receive: 24
« Reply #10 on: July 28, 2006, 08:29:06 08:29 »
Proteus 6.9 sp4 download
This version is debug problem. Run time simulation is fine work.
ikamaly
« Reply #11 on: December 11, 2006, 02:12:49 14:12 »
thank you
[indent]Merhaba
Proteus circuits
Simulation screen
Rafet32
-Given: 22
-Receive: 24
« Reply #12 on: December 26, 2006, 07:32:18 07:32 »
hi ikamaly
im send files your mail adress.
Rafet32
-Given: 22
-Receive: 24
« Reply #13 on: January 28, 2007, 09:32:05 21:32 »
Old download link deleted.
New download link is belove:
http://rapidshare.com/files/13846919/Forum_mmc.rar.html
consent
-Given: 8
« Reply #14 on: April 15, 2007, 08:14:12 20:14 »
thank u rafet32..
yavuz
-Given: 62
-Receive: 216
WCSCG?
« Reply #15 on: July 21, 2007, 10:03:12 22:03 »
thank you very much
eyvallah kardeş, çok makbule geçti Smiley
timurak
« Reply #16 on: December 30, 2007, 11:43:32 11:43 »
verdiğiniz bilgiler için teşekkür ederim.
tenir
« Reply #17 on: January 06, 2008, 12:21:54 12:21 »
did you try this on hardware. can you read datas when you put your card to pc by means of a card reader, or windows says "not formatted card"
Rafet32
-Given: 22
-Receive: 24
« Reply #18 on: January 06, 2008, 03:00:32 15:00 »
No im not test hardware. This sample code write 512 bytes first block (start adres 0x00000000 end adres 0x00000200). This adres area fat system header sector. Sample code change this area so plug mmc card  pc windows says "not formatted card". Actually you get  "not formatted card" message, show your hardware work Smiley
neer4evr
« Reply #19 on: February 13, 2008, 02:11:06 14:11 »
hey did anyone checkout proteus 7.2 sp2 it has a sample design for MMC card as a USB mass storage device. It is quite cool.
mabd
-Receive: 16
« Reply #20 on: February 15, 2008, 09:10:38 09:10 »
might be of interest
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1999&ty=&dty=&section=&NextRow=&ssUserText=an1045
El_Guitre
« Reply #21 on: February 16, 2008, 11:23:58 23:23 »
Hola muy interesante el post anterior muchas gracias
