April 29, 2025, 10:14:39 22:14
Author Topic: ··DOWNLOAD·· PIC Simulator IDE v6.34  (Read 11301 times)
Soter
-Given: 24
« on: July 24, 2006, 06:54:41 06:54 »
PIC Simulator IDE is powerful application that supplies PIC developers with user-friendly graphical development environment for Windows with integrated simulator (emulator), Basic compiler, assembler, disassembler and debugger. PIC Simulator IDE currently supports the following microcontrollers from the Microchip PICmicro 12F and 16F product lines: 12F629, 12F675, 12F683, 16F627, 16F627A, 16F628, 16F628A, 16F630, 16F648A, 16F676, 16F684, 16F688, 16F72, 16F73, 16F74, 16F76, 16F77, 16F737(*), 16F747(*), 16F767(*), 16F777(*), 16F83, 16F84, 16F84A, 16F87, 16F88, 16F818, 16F819, 16F870, 16F871, 16F872, 16F873, 16F873A, 16F874, 16F874A, 16F876, 16F876A, 16F877, 16F877A. (* - simulation module not available for these devices - supported in basic compiler only). The plan for further development of this application is to complete support for all models from these three chip families.
PIC Simulator IDE v6.34 + Keygen:
http://rapidshare.de/files/30745480/PIC_simulator_IDE_v6.34.zip.html
Enjoy!
« Last Edit: August 27, 2006, 02:56:01 02:56 by Soter » Logged
Rego
-Receive: 320
The power is back
« Reply #1 on: July 24, 2006, 06:20:56 18:20 »
worng section...
 and  a repost.....
plz make a search b4 posting........
warning : " read the rules"
Smiley ....THE POWER IS BACK.... Smiley
....REGO....
Soter
-Given: 24
« Reply #2 on: August 25, 2006, 08:30:47 20:30 »
New version 6.34
- Scrollbar in Watch Variables window
- New Require All Arguments option in Assembler
- New Use Voltage for Analog Inputs option for Microcontroller View windows
- Support for 4 new devices: 16F685, 16F687, 16F689, 16F690
- Several small and/or invisible improvements
- F2 (Step) will work when Breakpoints Manager window is in focus
- Breakpoints Manager will load MPASMWIN listing files
- New Compact Microcontroller View option
- Generate Basic Code command in Configuration Bits window
- Simulation support for 16F737, 16F747, 16F767 and 16F777
- Improved internal disassembler (disassembling with labels)
- Improved internal assembler (upper,high,low argument prefixes and banksel macro)
- Basic compiler new feature: address can be specified during variable declaration (Dim variable As Byte @ 0x050, for example)
- Basic compiler new feature: working register can be operand in assign statements (WREG = variable, variable = WREG, useful when using inline assembler parts of code)
- New parameter for DEFINE directive: I2CCLOCK_STRETCH
- Two new functions for external modules: GETPIC and GETPATH
- New option for basic compiler: Generate MPASMWIN Compatible Listing
PIC Simulator IDE main features:
- Main simulation interface showing internal microcontroller architecture,
- FLASH program memory viewer, EEPROM data memory editor, hardware stack viewer,
- Microcontroller pinout interface for simulation of digital I/O and analog inputs,
- Variable simulation rate, simulation statistics,
- Breakpoints manager for code debugging with breakpoints support,
- PIC assembler, interactive assembler editor for beginners, PIC disassembler,
- Powerful PIC Basic compiler with smart Basic source editor,
- PIC Basic compiler features: three basic data types (1-bit, 1-byte, 2-byte), optional 4-byte (32-bit) data type with 32-bit arithmetics, arrays, all standard PIC Basic language elements, optional support for structured language (procedures and functions), high level language support for using internal EEPROM memory, using internal A/D converter module, using interrupts, serial communication using internal hardware UART, software UART implementation, I2C communication with external I2C devices, interfacing character LCDs, interfacing graphical LCDs with 128x64 dot matrix, R/C servos, 1-Wire devices, DS18S20, using internal PWM modules ...
- Configuration bits editor,
- PC's serial port terminal for communication with real devices connected to serial port,
- LCD module simulation interface for character LCD modules,
- Graphical LCD module simulation interface for 128x64 graphical LCD modules,
- Hardware UART simulation interface,
- Software UART simulation interface for software implemented UART routines,
- Oscilloscope and signal generator simulation tools,
- 7-segment LED displays simulation interface,
- Support for external simulation modules,
- Extensive program options, color themes, ...
Rego
-Receive: 320
The power is back
« Reply #3 on: August 26, 2006, 12:44:44 00:44 »
Hey ... U Canot Read Or What Huh?  :mad:
I SAID THIS IS THE WRONG SECTION....
AND ALSO A REPOST ..... :mad:
THIS IS MY LAST WARNNING....
READ THE RULES OR NEXT TIME U WILL BE BANNED.... :mad:
....REGO....
Soter
-Given: 24
« Reply #4 on: August 26, 2006, 08:25:56 20:25 »
Ok. Sorry rego. Is the last time:D
vlada70
« Reply #5 on: January 20, 2008, 10:46:49 22:46 »
Pic Ide v 6.4
http://rapidshare.com/files/85286745/PIC_Simulator_IDE.rar
pass: sonsivri
